litao411 发表于 2022-3-8 10:53
OPA2369AIDGKR 双路、1.8V、700nA、零交叉、轨至轨 I/O ...
封装信息
封装 | 引脚VSSOP (DGK) | 8
包装数量 | 包装:2,500 | LARGE T&R
工作温度范围 (℃)-40 to 85
OPA2369 的特性
[*]nanoPOWER:
[*]OPA369: 800nA
[*]OPA2369: 700nA/ch.
[*]LOW OFFSET VOLTAGE: 250µV
[*]ZERO-CROSSOVER
[*]LOW OFFSET DRIFT: 0.4µV/°C
[*]DC PRECISION:
[*]CMRR: 114dB
[*]PSRR:106dB
[*]AOL: 134dB
[*]GAIN-BANDWIDTH PRODUCT: 12kHz
[*]SUPPLY VOLTAGE: 1.8V to 5.5V
[*]microSIZE PACKAGES:
[*]SC70-5, SOT23-5, MSOP-8
[*]APPLICATIONS
[*]BATTERY-POWERED INSTRUMENTS
[*]PORTABLE DEVICES
[*]MEDICAL INSTRUMENTS
[*]TEST EQUIPMENT
[*]LOW-POWER SENSOR SIGNAL CONDITIONING
OPA2369 的说明The OPA369 and OPA2369 are ultra-low-power, low-voltage operational amplifiers from TexasInstruments designed especially for battery-powered applications.The OPAx369 operates on a supply voltage as low as 1.8V and has true rail-to-rail operation that makes it useful for a wide range of applications. The zerø-crossover feature resolves the problem of input crossover distortion that becomes very prominent in low voltage (< 3V), rail-to-rail input applications.In addition to microsize packages and very low quiescent current, the OPAx369 features 12kHz bandwidth, low offset drift (1.75µV/°C, max), and low noise 3.6µVPP (0.1Hz to 10Hz).The OPA369 (single version) is offered in an SC70-5 package. The OPA2369 (dual version) comes in both MSOP-8 and SOT23-8 packages
页: [1]
查看完整版本: OPA2369AIDGKR 双路、1.8V、700nA、零交叉、轨至轨 I/O ...
