龙讯LT9211高性能转换器,在MIPI DSI / CSI-2 /双端口LVDS...
 楼主| JLKJ18338421851 发表于 2022-3-24 11:49 | 显示全部楼层 |阅读模式
1.说明
Lontium LT9211是一款高性能转换器,可以在MIPI DSI / CSI-2 /双端口LVDS和TTL之间进行相互转换,但24位TTL到24位TTL以及SYNC和DE除外。LT9211对输入的MIPI / LVDS / TTL视频数据进行反序列化,解码数据包,并将经过格式化的视频数据流转换为AP与移动显示面板或摄像机之间的MIPI / LVDS / TTL发送器输出。
LT9211可用作2端口MIPI / LVDS中继器,它支持最大14dB的输入均衡和可编程的预加重,以提高性能。
LT9211还可以用作MIPI / LVDS复用器和分离器。对于MIPI Repeater,Muxer和Splitter,我们不支持CSI RAW格式。
LT9211采用先进的CMOS工艺制造,并以7.5x7.5mm QFN64封装实现。该封装符合RoHS规范,规定工作温度范围为-40°C至+ 85°C。
2.功能
•双端口LVDS
发射器•MIPI发射器
•TTL输出
•双端口LVDS接收器
•TTL输入
•单端口MIPI接收器
•其他
3.应用•移动系统
•蜂窝手持机
•数码相机
•数码摄像机
•平板电脑,笔记本电脑
•车载显示器和摄像头系统
1. Description
The Lontium LT9211 is a high performance convertor which interconvertible between MIPI DSI/CSI-2/Dual-Port LVDS and TTL except for 24bit TTL to 24bit TTL with both SYNC and DE. The LT9211 deserializes input MIPI/LVDS/TTL video data, decodes packets, and converts the formatted video data stream to MIPI/LVDS/TTL transmitter output between AP and mobile display panel or camera.
The LT9211 can be used as 2-Port MIPI/LVDS Repeater which support maximum 14dB input equalization and programmable pre-emphasis to improve performance.
The LT9211 can also be used as MIPI/LVDS Muxer and Splitter. For MIPI Repeater, Muxer and Splitter, we do not support CSI RAW format.
The LT9211 is fabricated in advanced CMOS process and implemented in 7.5x7.5mm QFN64 package. This package is RoHS compliant and specified to operate from -40°C to +85°C.
2. Features
• Dual-Port LVDS Transimitter
• MIPI Transmitter
• TTL Output
• Dual-Port LVDS Receiver
• MIPI Receiver
• TTL Intput
• Single-Port MIPI Receiver
• Miscellaneous
3. Applications
• Mobile systems
• Cellular handsets
• Digital still cameras
• Digital  video cameras
• Tablet PC, Notebook PC
• Car Display and Camera System
如需获取更多产品资料PDF,电路图或样品,技术疑问(原厂技术支持)欢迎随时与我们取得联系!!
深圳市九黎科技有限公司Email:bcxu.jl@foxmail.com
快速回复 返回顶部 返回列表
