JLKJ18338421851 发表于 2022-3-24 14:35
龙迅LT86104SXE是第4代4端口HDMI/DVI分配器
1. 描述LT86104SXE是Lontium的第4代4端口HDMI/DVI分配器,可以将一个HDMI/DVI信号重复到4个HDMI/DVI信号集,支持多达4个不同的HDMI/DVI接收/显示终端。基于cleardedgeÔ 技术,每通道最高支持3.4Gbps的数据速率,符合HDMI 1.4/DVI 1.0规范。2. 特性•兼容HDMI 1.4/2.0和DVI 1.0规格•支持3D视频格式和4Kx2K扩展分辨率格式,高达3.4Gbps数据速率和4Kx2K @60Hz YCbCr 4:2:0格式•自适应均衡和去强调,以补偿长电缆损耗•odt和校准•集成HDCP中继器引擎符合HDCP 1.4规范•完全硬件控制或可选软件控制的HDCP操作•预先编程的HDCP密钥集或外部EEPROM存储的密钥集•集成CEC控制器•集成EDID影子RAM和嵌入式EDID•允许5v电压的DDC接口•1个HDMI/DVI输入端口,最多4个HDMI/DVI输出端口•无限级联更多输出端口或信号重复128引脚LQFP封装3.应用程序•多显示器/电视支持•HDMI/DVI信号拆分/重复1. Description
The LT86104SXE is Lontium’s 4rd generation 4-port HDMI/DVI splitter which can repeat one HDMI/DVI signal to 4 HDMI/DVI signal sets, support up to 4 different HDMI/DVI receiving/display terminals. Based on ClearedEdgeÔ technology, it supports up to 3.4Gbps data rate per channel, compliant with the HDMI 1.4/DVI 1.0 specifications.
2. Features
• HDMI 1.4/2.0 & DVI 1.0 specifications compliant
• Support 3D video formats and 4Kx2K extended resolution formats up to 3.4Gbps data rate and 4Kx2K @60Hz YCbCr 4:2:0 format
• Adaptive equalization and de-emphasis to compensate long cable losses
• ODTs and calibration
• Integrated HDCP repeater engine compliant with HDCP 1.4 specification
• Fully hardware-controlled or optional software-controlled HDCP operations
• Pre-programmed HDCP key sets or external EEPROM stored key sets
• Integrated CEC controller
• Integrated EDID shadow RAM and embedded EDID
• 5V-tolerant DDC interfaces
• 1 HDMI/DVI input port, up to 4 HDMI/DVI output ports
• Unlimited cascading for more output ports or signal repeating
• 128-pin LQFP package
3. Application
• Multiple display/TV support
• HDMI/DVI signal splitting/repeating九黎科技是龙讯授权代理商,如需获取更多产品资料PDF,电路图或样品,技术疑问(原厂技术支持)欢迎随时与我们取得联系!!Email:bcxu.jl@foxmail.com
页: [1]
查看完整版本: 龙迅LT86104SXE是第4代4端口HDMI/DVI分配器
