tlled 发表于 2022-4-6 00:11
国芯N32G457代替STM32F107驱动LCD显示屏
#申请原创#
    测试下使用N32F457芯片代替STM32F107芯片,通过驱动LCD测试来看下移植过程。
    一、硬件部分
    1.1、N32G457与STM32F107(一样的LQFP100封装)
    1.1.1、STM32F107芯片引脚定义
    1.1.2、N32G457芯片引脚定义
    从引脚定义上看,两款芯片的引脚是完全兼容的。
    STM32F107芯片内核是M3,主频最大72MHz。
    n32g457芯片内核是M4+FPU,主频可达144MHz。
    2、显示屏硬件驱动LCD部分电路
    驱动LCD方式是使用16位总线,模拟时序来驱动的,使用到的端口如下:
    3、硬件电路焊接对比
    3.1、N32G457
    3.2、STM32F107
    二、程序部分
    之前是使用STM32F107的库文件程序来配置驱动设置端口,移植驱动主要是外部端口的配置,移植到N32G457有那些改动,下面开始对比。
    2.1、STM32驱动端口的配置
void LCD_Pins_Config(void)
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOE | RCC_APB2Periph_GPIOD , ENABLE);
// DB15--0
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_All;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_Init(GPIOE, &GPIO_InitStructure);
//LCD_Pin_WRPB15
      //LCD_Pin_RSPB14
      //LCD_Pin_CSPB10
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10 | GPIO_Pin_14 |GPIO_Pin_15;
GPIO_Init(GPIOB, &GPIO_InitStructure);
      //LCD_Pin_RSTPD11
//LCD_Pin_RDPD15
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11 | GPIO_Pin_15;
GPIO_Init(GPIOD, &GPIO_InitStructure);
      //LCD_BKPA3
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
GPIO_Init(GPIOA, &GPIO_InitStructure);
      GPIO_SetBits(GPIOA,GPIO_Pin_3);
void ST7789_BUS_OutPut(void)
// DE15--0
void LCD_DB_AS_InPut(void)
// DE15--0
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
    2.2、N32G457驱动端口的配置
      //N32G457设置如下
      GPIO_InitType GPIO_InitStructure;
      RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_GPIOA | RCC_APB2_PERIPH_GPIOB | RCC_APB2_PERIPH_GPIOD |RCC_APB2_PERIPH_GPIOE, ENABLE);
// DB15--0
      GPIO_InitStructure.Pin      = GPIO_PIN_ALL;
      GPIO_InitStructure.GPIO_Mode= GPIO_Mode_Out_PP;
      GPIO_InitPeripheral(GPIOE, &GPIO_InitStructure);
//LCD_Pin_WRPB15
      //LCD_Pin_RSPB14
      //LCD_Pin_CSPB10
GPIO_InitStructure.Pin = GPIO_PIN_10 | GPIO_PIN_14 |GPIO_PIN_15;
GPIO_InitPeripheral(GPIOB, &GPIO_InitStructure);
      //LCD_Pin_RSTPD11
//LCD_Pin_RDPD15
GPIO_InitStructure.Pin = GPIO_PIN_11 | GPIO_PIN_15;
GPIO_InitPeripheral(GPIOD, &GPIO_InitStructure);
      //LCD_BKPA3
GPIO_InitStructure.Pin = GPIO_PIN_3;
GPIO_InitPeripheral(GPIOA, &GPIO_InitStructure);
      GPIO_SetBits(GPIOA,GPIO_PIN_3);
// DB15--0
// DB15--0
}    从库文件端口配置来看,驱动程序函数定义名称是很相似的,名称定义的大小写有点区别,比如
    STM32 -- 使用的引脚定义名称是GPIO_Pin_10
    N32G-- 使用的引脚定义名称是GPIO_PIN_10
    修改比较容易,程序移植的工作量小。
    2.3、显示屏驱动
    2.3.1、st7789.c
#include <stdio.h>
#include "main.h"
//#include "lcd.h"
#include "Image.h"
#include "delay.h"
#include "font.h"
#include "st7789.h"
#include "delay.h"
//LCD的画笔颜色和背景色
u16 POINT_COLOR=0x0000;      //画笔颜色
u16 BACK_COLOR=0xFFFF;//背景色
//管理LCD重要参数
//默认为竖屏
_lcd_dev lcddev;
//设置LCD显示方向
//dir:0,竖屏;1,横屏
void LCD_Display_Dir(u8 dir)
      if(dir==0)                        //竖屏
                lcddev.dir=0;      //竖屏
                lcddev.width=240;
                lcddev.height=320;
      }else                                 //横屏
                lcddev.dir=1;      //横屏
                lcddev.width=320;
                lcddev.height=240;
      //LCD_Scan_Dir(DFT_SCAN_DIR);      //默认扫描方向
      //N32G457设置如下
// DB15--0
//LCD_Pin_WRPB15
      //LCD_Pin_RSPB14
      //LCD_Pin_CSPB10
      //LCD_Pin_RSTPD11
//LCD_Pin_RDPD15
      //LCD_BKPA3
// DB15--0
// DB15--0
void delay_ms(u16 nms)
      systick_delay_ms(nms);
void LCD_Init(void)
LCD_Pins_Config();
void TFT_24_7789_Write_Data(u16 dat)
      LCD_SetRs();//rs=1
LCD_ClrCs();//cs=0
LCD_SetRd();//rd=1
      LCD_ClrWr();//wr=0
      GPIO_Write(GPIOE, dat);
      LCD_SetWr();   //wr=1
LCD_SetCs();   //cs=1
void TFT_24_7789_Write_Command(u16 cmd)
      LCD_ClrCs();//cs=0
LCD_ClrRs();//rs=0
      LCD_SetRd();//rd=1
LCD_ClrWr();//wr=0
      GPIO_Write(GPIOE, cmd);
LCD_SetWr();   //wr=1
LCD_SetCs();   //cs=1
      LCD_SetRs();   //rs=1
void ST7789_WriteData(u16 dat)
      LCD_SetRs();//rs=1
LCD_ClrCs();//cs=0
LCD_SetRd();//rd=1
      LCD_ClrWr();//wr=0
      LCD_SetWr();   //wr=1
LCD_SetCs();   //cs=1
void ST7789_WriteCommand(u16 cmd)
      LCD_ClrCs();//cs=0
LCD_ClrRs();//rs=0
      LCD_SetRd();//rd=1
LCD_ClrWr();//wr=0
LCD_SetWr();   //wr=1
LCD_SetCs();   //cs=1
      LCD_SetRs();   //rs=1
//void TFT_24_7789_Read_Data(void)
//      uint16_t id=0;
//      TFT_24_7789_Write_Command(0x0004);
//      LCD_DB_AS_InPut();
//      GPIO_ResetBits(GPIOB, GPIO_Pin_10);//CS=0
//      GPIO_SetBits(GPIOB, GPIO_Pin_14);//RS=1
//      GPIO_SetBits(GPIOB, GPIO_Pin_15);         //WR=1
//      //GPIO_SetBits(GPIOD, GPIO_Pin_15);    //RD=1
//GPIO_ResetBits(GPIOD, GPIO_Pin_15);         //RD=0
//      //GPIO_Write(GPIOE, dat);//when using 16-bit interface (DB17:10,DB8:1)//when using 8-bit interface (DB17:10)
//      id=LCD_Read();
//      delay_ms(1);
//      GPIO_SetBits(GPIOD, GPIO_Pin_15);   //RD=1;
//      delay_ms(1);
//      printf("\n\r ######DeviceIdCode = 0x%x ###### ", id);
//      LCD_DB_AS_OutPut();
static void ST7789_Reset(void)
    LCD_SetRst();
    delay_ms(1);
    LCD_ClrRst();
    delay_ms(100); // Delayms 10ms               // This delay time is necessary
    LCD_SetRst();
    delay_ms(120); // Delayms 120 ms
void ST7789_Init(void)
      int n;
      LCD_Pins_Config();
      ST7789_Reset();
      ST7789_WriteCommand(0x0011);                //exit SLEEP mode
      delay_ms(120);
      ST7789_WriteCommand(0x0036);
      ST7789_WriteData(0x0060);                        //MADCTL: memory data access control
      ST7789_WriteCommand(0x003A);
      ST7789_WriteData(0x0005);                        //COLMOD: Interface Pixel format *** I use 262K-colors in 18bit/pixel format when using 8-bit interface to allow 3-bytes per pixel
//      TFT_24_7789_Write_Command(0x003A);TFT_24_7789_Write_Data(0x0055);//COLMOD: Interface Pixel format*** I use 65K-colors in 16bit/pixel (5-6-5) format when using 16-bit interface to allow 1-byte per pixel
      ST7789_WriteCommand(0x00B2);
      ST7789_WriteData(0x000C);
      ST7789_WriteData(0x0000);
      ST7789_WriteData(0x0033);
      ST7789_WriteData(0x0033);                        //PORCTRK: Porch setting
      ST7789_WriteCommand(0x00B7);
      ST7789_WriteData(0x0035);                        //GCTRL: Gate Control
      ST7789_WriteCommand(0x00BB);
      ST7789_WriteData(0x001c);                        //VCOMS: VCOM setting
      ST7789_WriteCommand(0x00C0);
      ST7789_WriteData(0x002C);                        //LCMCTRL: LCM Control
      ST7789_WriteCommand(0x00C2);
      ST7789_WriteData(0x0001);
      ST7789_WriteData(0x00FF);                        //VDVVRHEN: VDV and VRH Command Enable
      ST7789_WriteCommand(0x00C3);
      ST7789_WriteData(0x000B);                        //VRHS: VRH Set
      ST7789_WriteCommand(0x00C4);
      ST7789_WriteData(0x0020);                        //VDVS: VDV Set
      ST7789_WriteCommand(0x00C6);
      ST7789_WriteData(0x000F);                        //FRCTRL2: Frame Rate control in normal mode
      ST7789_WriteCommand(0x00D0);
      ST7789_WriteData(0x00A4);
      ST7789_WriteData(0x00A1);                        //PWCTRL1: Power Control 1
      ST7789_WriteCommand(0x00E0);
      ST7789_WriteData(0x00D0);
      ST7789_WriteData(0x0003);
      ST7789_WriteData(0x0009);
      ST7789_WriteData(0x0013);
      ST7789_WriteData(0x003a);
      ST7789_WriteData(0x0055);
      ST7789_WriteData(0x0048);
      ST7789_WriteData(0x0018);
      ST7789_WriteData(0x0012);
      ST7789_WriteData(0x000e);
      ST7789_WriteData(0x0019);
      ST7789_WriteData(0x001e);                        //PVGAMCTRL: Positive Voltage Gamma control
      ST7789_WriteCommand(0x00E1);
      ST7789_WriteData(0x0025);
      ST7789_WriteData(0x0050);
      ST7789_WriteData(0x003d);
      ST7789_WriteData(0x001d);
      ST7789_WriteCommand(0x0029);                              //display ON
      ST7789_WriteCommand(0x002c);
      LCD_Display_Dir(1);
void LCD_WriteOneDot(u16 color)
    TFT_24_7789_Write_Data(color);
void Lcd_SetBox(u16 xStart,u16 yStart,u16 xlong,u16 ylong)
      u16 xEnd=0, yEnd=0;
      xEnd=xStart+xlong-1;
      yEnd=yStart+ylong-1;
      TFT_24_7789_Write_Command(0x2a);
      TFT_24_7789_Write_Data(xStart>>8);
      TFT_24_7789_Write_Data(xStart);
      TFT_24_7789_Write_Data(xEnd>>8);
      TFT_24_7789_Write_Data(xEnd);
      TFT_24_7789_Write_Command(0x2b);
      TFT_24_7789_Write_Data(yStart>>8);
      TFT_24_7789_Write_Data(yStart);
      TFT_24_7789_Write_Data(yEnd>>8);
      TFT_24_7789_Write_Data(yEnd);
      TFT_24_7789_Write_Command(0x2c);
void Lcd_SetBox1(u16 xStart,u16 xEnd,u16 yStart,u16 yEnd)
void LCD_Clear(u16 Color)
   u32 i;
   Lcd_SetBox(0,0,320,240);
   for(i=0;i<78900;i++){
       LCD_WriteOneDot(Color);
void LCD_Picture(u16 x,u16 y,u16 width,u16 height,const unsignedchar *color)
      u16 i,j,temp;
      j=width*height;
      Lcd_SetBox(x,y,width,height);
         for(i=0;i<j;i++)
          temp=color<<8&0xFF00;
          temp+=color;
          LCD_WriteOneDot(temp);
void LCD_Clear1(u16 xStart,u16 yStart,u16 xlong,u16 ylong,u16 Color)
   u32 i,j;
   j=xlong*ylong;
   Lcd_SetBox(xStart,yStart,xlong,ylong);
   for(i=0;i<j;i++){
函数名:LCD_write_english
功能:选定Lcd上写一个英文或数字
入口参数:data 要写的字符
          color 字符的颜色
          xcolor 字符的背景色
          size字体的大小
返回值:无
static void LCD_write_english(u8 data,u16 color,u16 xcolor ,u8 mode)//写字符
u8 i=0,j=0,n=0;
u8 avl=0;
data -=32;
for (i=0;i<120;i++) //为 20x40字库
    avl=english;
    for (j=0;j<8;j++)
      n++;
      if(avl&0x80)LCD_WriteOneDot(color);
      else if(mode==0) LCD_WriteOneDot(xcolor);
      avl<<=1;
      if(n>19) {
      n=0;
      break;
      }//部分字体如英文20*40,形成的字库3个8位一组,每一组最后4位不显示,用该语句进行判断有几位不需要显示
void LCD_write_english_string(u16 x, u16 y, char *str,u8 mode)//英文字符串显示
u16 k = 0;
while ((*str<='~')&&(*str>=' '))
   Lcd_SetBox(x+k,y,20,40);
   LCD_write_english( *str,WORDCOLOR,BACKCOLOR, mode);
   k+=20;
   str++;
static void LCD_write_chinese(u16 data, u16 color, u16 xcolor,u8 mode )//写字符
u8 i=0,j=0;
u32 avl=0;
//data -=' ';                      //(ASCII)- 32 = 字库数组行数
//===========为 48x24字库       32*16=512个像素点保存形式为8位数据故有512/8=64个 每一位代表“字”或“背景”然后再把每个坐标的颜色显示出来==========要是显示在什么位置 显示的大小为什么是32X16看LCD_write_english_string函数其中有个Lcd_SetBox
for (i=0;i<128;i++)
    avl=Chinese;         //取第一个8位
    for (j=0;j<8;j++)            //两个8位组成一个16位循环16次完成16个点的判断 每行显示几个像素点由函数LCD_write_english_string的输入参数定
      else if(mode==0) LCD_WriteOneDot(xcolor);   //“0”显示为背景部分 即 背景颜色
      avl<<=1;
void LCD_write_chinese_string(u16 x, u16 y,u16 address,u16 len,u8 mode)
int i;
u16 k = 0;
for(i=0;i<len;i++)
   Lcd_SetBox(x+k,y,32,32);
   LCD_write_chinese(address,WORDCOLOR,BACKCOLOR, mode);
   k+=32;
   address++;
void ST7789_SetPoint(u16 x,u16 y,u16 color)
      Lcd_SetBox1(x,x+1,y,y+1);
//在指定位置显示一个字符
//x,y:起始坐标
//num:要显示的字符:" "--->"~"
//size:字体大小 12/16/24
//mode:叠加方式(1)还是非叠加方式(0)
void LCD_ShowChar(u16 x,u16 y,u8 num,u8 size,u8 mode)
    u8 temp,t1,t;
      u16 y0=y;
      u8 csize=(size/8+((size%8)?1:0))*(size/2);                //得到字体一个字符对应点阵集所占的字节数
         num=num-' ';//得到偏移后的值(ASCII字库是从空格开始取模,所以-' '就是对应字符的字库)
      for(t=0;t<csize;t++)
                if(size==12)temp=asc2_1206;                  //调用1206字体
                else if(size==16)temp=asc2_1608;      //调用1608字体
                else if(size==24)temp=asc2_2412;      //调用2412字体
                else return;        //没有的字库
                for(t1=0;t1<8;t1++)
                        if(temp&0x80)ST7789_SetPoint(x,y,POINT_COLOR);
                        else if(mode==0)ST7789_SetPoint(x,y,BACK_COLOR);
                        temp<<=1;
                        y++;
                        if(y>=lcddev.height)return;                //超区域了
                        if((y-y0)==size)
                              y=y0;
                              x++;
                              if(x>=lcddev.width)return;      //超区域了
                              break;
//显示字符串
//x,y:起点坐标
//width,height:区域大小
//size:字体大小
//*p:字符串起始地址
void LCD_ShowString(u16 x,u16 y,u16 width,u16 height,u8 size,u8 *p)
      u8 x0=x;
      width+=x;
      height+=y;
    while((*p<='~')&&(*p>=' '))//判断是不是非法字符!
      if(x>=width){x=x0;y+=size;}
      if(y>=height)break;//退出
      LCD_ShowChar(x,y,*p,size,0);
      x+=size/2;
      p++;
    2.3.2、main.c
#include "main.h"
#include <stdio.h>
#include <stdint.h>
#include "led.h"
#include "delay.h"
#include "st7789.h"
int main(void)
      LED_Init();
      ST7789_Init();
      POINT_COLOR=RED;
      LCD_Clear(WHITE);
      LCD_ShowString(30,40,210,24,24,"N32G457");
      LCD_ShowString(30,70,200,16,16,"TFTLCD TEST");
      LCD_ShowString(30,90,200,16,16,"tlled@NATION");
         LCD_ShowString(30,110,200,16,16,"ST7789");
      LCD_ShowString(30,130,200,12,12,"2022/04/05");
      LCD_ShowString(30,150,210,24,24,"www.nationstech.com");
      while (1)
                led0_on();systick_delay_ms(500);
                led0_off();systick_delay_ms(500);
    2.4、程序源码:
    三、运行显示内容
    @21小跑堂
七毛钱 发表于 2022-4-6 16:37
能完美代替st的国产芯片现在真的越来越多了
电子之心 发表于 2022-4-6 22:01
国民代理,需要开发板测试或开发可与我联系 QQ:184530093
WoodData 发表于 2022-5-30 22:17
学习一下
页: [1]
查看完整版本: 国芯N32G457代替STM32F107驱动LCD显示屏
