ZCC5145 替代HT7463
1 DESCRIPTIONThe ZCC5145 is a monolithic, step-down,
switch- mode converter with a built-in power
MOSFET. It achieves a 0.6A peak-output
current over a wide input supply range with
excellent load and line regulation. Current-mode
operation provides a fast transient response and
eases
loop
stabilization.
Fault
condition
protections include cycle-by-cycle current limiting
and thermal shutdown.
The ZCC5145 requires a minimal number of
readily-available external components. The
ZCC5145 is available in a TSOT23-6 package.
2 FEATURES
0.6A Peak Output Current
0.6Ω Internal Power MOSFET
Capable to Start Up with Big Output
Capacitor
Stable with Low-ESR Ceramic Output
Capacitors
Up to 94% Efficiency
Fixed 1.2MHz Frequency
Cycle-by-Cycle Over-Current Protection
Wide 4.2V-to-45V Operating Input Range
Output Adjustable from 4.5V to 0.94xVIN
Available
页:
[1]
