t9080350 发表于 2022-4-11 23:09
HC32L136J8TA 串口0中断
问题描述:串口0使用PA9和PA10,可以发送无法进入接收中断。程序是从官方例程PA2+PA3修改来的,版本1.9.2困扰两三天了,求各位高手指点,万分感谢!!
我的代码:
#include "ddl.h"
#include "uart.h"
#include "gpio.h"
#include "sysctrl.h"
* Local pre-processor symbols/macros ('#define')
#define   T1_PORT               (3)
#define   T1_PIN                  (3)
* Global variable definitions (declared in header file with 'extern')
* Local type definitions ('typedef')
* Local function prototypes ('static')
* Local variable definitions ('static')                                    *
volatile static uint8_t u8RxData;
volatile static uint8_t u8TxCnt=0;
volatile static uint8_t u8RxCnt=0;
* Function implementation - global ('extern') and local ('static')
void App_UartCfg(void);
void App_PortInit(void);
** \briefMain function of project
** \return uint32_t return value, if needed
** This sample
int32_t main(void)
    //串口引脚配置
    App_PortInit();
    //串口配置
    App_UartCfg();
    while(1)
      if(u8RxCnt>=1)
            u8RxCnt = 0;
            Uart_SendDataIt(M0P_UART0, ~u8RxData); //启动UART0发送第一个字节
//UART0中断函数
void Uart0_IRQHandler(void)
    if(Uart_GetStatus(M0P_UART0, UartRC))         //UART0数据接收
      Uart_ClrStatus(M0P_UART0, UartRC);      //清中断状态位
      u8RxData = Uart_ReceiveData(M0P_UART0);   //接收数据字节
      u8RxCnt++;
    if(Uart_GetStatus(M0P_UART0, UartTC))         //UART0数据发送
      Uart_ClrStatus(M0P_UART0, UartTC);      //清中断状态位
      u8TxCnt++;
//串口引脚配置
    stc_gpio_cfg_t stcGpioCfg;
    DDL_ZERO_STRUCT(stcGpioCfg);
    Sysctrl_SetPeripheralGate(SysctrlPeripheralGpio,TRUE); //使能GPIO模块时钟
    ///<TX
    stcGpioCfg.enDir = GpioDirOut;
    Gpio_Init(GpioPortA, GpioPin9, &stcGpioCfg);
    Gpio_SetAfMode(GpioPortA, GpioPin9, GpioAf1);          //配置PA09 端口为URART1_TX
    ///<RX
    stcGpioCfg.enDir = GpioDirIn;
    Gpio_Init(GpioPortA, GpioPin10, &stcGpioCfg);
    Gpio_SetAfMode(GpioPortA, GpioPin10, GpioAf1);          //配置PA10 端口为URART1_RX
//串口配置
    stc_uart_cfg_t    stcCfg;
    DDL_ZERO_STRUCT(stcCfg);
    ///< 开启外设时钟
    Sysctrl_SetPeripheralGate(SysctrlPeripheralUart0,TRUE);///<使能uart0模块时钟
    ///<UART Init
    stcCfg.enRunMode      = UartMskMode3;          ///<模式3
    stcCfg.enStopBit      = UartMsk1bit;         ///<1bit停止位
    stcCfg.enMmdorCk      = UartMskEven;         ///<偶检验
    stcCfg.stcBaud.u32Baud= 9600;                  ///<波特率9600
    stcCfg.stcBaud.enClkDiv = UartMsk8Or16Div;       ///<通道采样分频配置
    stcCfg.stcBaud.u32Pclk= Sysctrl_GetPClkFreq(); ///<获得外设时钟(PCLK)频率值
    Uart_Init(M0P_UART0, &stcCfg);                   ///<串口初始化
    ///<UART中断使能
    Uart_ClrStatus(M0P_UART0,UartRC);                ///<清接收请求
    Uart_ClrStatus(M0P_UART0,UartTC);                ///<清接收请求
    Uart_EnableIrq(M0P_UART0,UartRxIrq);             ///<使能串口接收中断
    Uart_EnableIrq(M0P_UART0,UartTxIrq);             ///<使能串口接收中断
    EnableNvic(UART0_IRQn, IrqLevel3, TRUE);       ///<系统中断使能
* EOF (not truncated)
官方库使用UART1(PA2+PA3)的代码:
#include "ddl.h"
#include "uart.h"
#include "gpio.h"
#define   T1_PORT               (3)
#define   T1_PIN                  (3)
** This sample
int32_t main(void)
    //串口引脚配置
    App_PortInit();
    //串口配置
    App_UartCfg();
    while(1)
      if(u8RxCnt>=1)
            u8RxCnt = 0;
            Uart_SendDataIt(M0P_UART1, ~u8RxData); //启动UART1发送第一个字节
//UART1中断函数
void Uart1_IRQHandler(void)
    if(Uart_GetStatus(M0P_UART1, UartRC))         //UART1数据接收
      Uart_ClrStatus(M0P_UART1, UartRC);      //清中断状态位
      u8RxData = Uart_ReceiveData(M0P_UART1);   //接收数据字节
      u8RxCnt++;
    if(Uart_GetStatus(M0P_UART1, UartTC))         //UART1数据发送
      Uart_ClrStatus(M0P_UART1, UartTC);      //清中断状态位
      u8TxCnt++;
//串口引脚配置
    ///<TX
    Gpio_Init(GpioPortA, GpioPin2, &stcGpioCfg);
    Gpio_SetAfMode(GpioPortA, GpioPin2, GpioAf1);          //配置PA02 端口为URART1_TX
    ///<RX
    Gpio_Init(GpioPortA, GpioPin3, &stcGpioCfg);
    Gpio_SetAfMode(GpioPortA, GpioPin3, GpioAf1);          //配置PA03 端口为URART1_RX
//串口配置
    ///< 开启外设时钟
    Sysctrl_SetPeripheralGate(SysctrlPeripheralUart1,TRUE);///<使能uart1模块时钟
    ///<UART Init
    Uart_Init(M0P_UART1, &stcCfg);                   ///<串口初始化
    ///<UART中断使能
    Uart_ClrStatus(M0P_UART1,UartRC);                ///<清接收请求
    Uart_ClrStatus(M0P_UART1,UartTC);                ///<清接收请求
    Uart_EnableIrq(M0P_UART1,UartRxIrq);             ///<使能串口接收中断
    Uart_EnableIrq(M0P_UART1,UartTxIrq);             ///<使能串口接收中断
    EnableNvic(UART1_IRQn, IrqLevel3, TRUE);       ///<系统中断使能
mutable 发表于 2022-4-13 13:52
找官网的例程直接用啊
七毛钱 发表于 2022-4-24 11:10
楼主这么喜欢走弯路啊,哈哈
wubangmi 发表于 2022-4-26 10:03
换个低版本的keil,估计你的编译器版本太高
页: [1]
查看完整版本: HC32L136J8TA 串口0中断
