广芯BCT8937兼容艾为AW8737完全PIN✓PIN 应用:手机,平板,POS...
本帖最后由 ldj17727812840 于 2022-4-24 17:31 编辑#技术资源# #申请原创# 1.广芯BCT8937兼容艾为AW8737完全PIN✓PIN 应用:手机,平板,POS机,可穿戴设备
Constant large volume, Upgrade Seventh generation Class KAudioAmplifier
AW8737S is designed to enhance smart mobile phone sound quality, which is a new high efficiency, low noise, ultra-low distortion, constant large volume, upgrading seventh generation class K audio amplifier. Using a new generation K-Chargepump technology, efficiency reaches 93%, power amplifier’s overall efficiency is up to 80%, greatly prolong the mobile phone usage time. The AW8737S noise floor is as low as to 53μV, with 97dB high signal-to-noise-ratio(SNR). The ultra-low distortion 0.008% and unique no-crack-noise (NCN) technology brings high quality music enjoyment. AW8737S has 0.6W, 0.8W, 1W and 1.2W four selectable speaker-guard output power levels, recommended using rated power of 0.5W and above speakers. AW8737S integrated unique NCN technology, the output power cannot drop along with lithium battery voltage lower down. Within lithium battery voltage range (3.3V--4.35V), output power is constant, preventing the voice becomes smaller and smaller during usage of cell phone. The AW8737S uses Awinic proprietary TDD-Noise suppression technology and EMI suppression technology, effectively restrain TDD-Noise and EMI interference.CharacteristicDatasheetComparisonPackage informationCharacteristic
l Low noise: 53μV
l Power amplifier overall efficiency 80%
l Ultra-low distortion: 0.008%
l Within Lithium battery voltage range, output power is maintained constant
l Selectable speaker-guard power level: 0.6w, 0.8W,1W, 1.2W
l No-crack-noise (NCN) technology
l Super TDD-Noise suppression
l Excellent pop-click suppression
l One wire pulse control
l High PSRR: -68dB( 217Hz)
l ESD protection: ±6kV (HBM)
l Small 0.4mm pitch 1.6mm×1.68mm
应用:手机,平板,POS机,可穿戴设备等产品 更多详细资料,可以私信留言,合作共赢,共创辉煌,互相学习共同进步,用芯成就专业,专业承载重托。 龙生;177-2781-2840
啥玩意??? xdqfc 发表于 2022-4-15 11:22
啥玩意???
BCT8937替换艾为AW8737
页:
[1]
