t60yz 发表于 2022-4-30 19:57
STM32 ADC DMA数据不稳定的解决方案
在项目开发中,经常需要用到ADC采样的做电压检测,而且多通道ADC检测的情况比较多,所以本篇基于此要求采用了ADC DMA的方法,下面先给出基础代码(STM32F030)!
#define ADC1_DR_Address            0x40012440
//对应需要检测的ADC通道个数
#define ADC_DMA_BUFFER_SIZE   2
//按照通道顺序依次存放得到的ADC值
__IO uint16_t RegularConvData_Tab = {0, 0};
* @briefDMA channel1 configuration
* @paramNone
* @retval None
void DMA_Config(void)
    DMA_InitTypeDef   DMA_InitStructure;
    /* DMA1 clock enable */
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
    /* DMA1 Channel1 Config */
    DMA_DeInit(DMA1_Channel1);
    DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)ADC1_DR_Address;
    DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)RegularConvData_Tab;
    DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
    DMA_InitStructure.DMA_BufferSize = ADC_DMA_BUFFER_SIZE;
    DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
    DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
    DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
    DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
    DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
    DMA_InitStructure.DMA_Priority = DMA_Priority_High;
    DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
    DMA_Init(DMA1_Channel1, &DMA_InitStructure);
    /* DMA1 Channel1 enable */
    DMA_Cmd(DMA1_Channel1, ENABLE);
void ADC_DMA_Config(void)
    ADC_InitTypeDef   ADC_InitStructure;
    GPIO_InitTypeDef    GPIO_InitStructure;
    DMA_Config();
    /* ADC1 DeInit */
    ADC_DeInit(ADC1);
    /* ADC1 Periph clock enable */
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
    /* Configure ADC Channel11 and channel10 as analog input */
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
    GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
    RCC_AHBPeriphClockCmd(P_N_TEST_CLK, ENABLE);
    GPIO_InitStructure.GPIO_Pin = P_N_TEST_PIN ;
    GPIO_Init(P_N_TEST_PORT, &GPIO_InitStructure);
    RCC_AHBPeriphClockCmd(DC5V_TEST_CLK, ENABLE);
    GPIO_InitStructure.GPIO_Pin = DC5V_TEST_PIN ;
    GPIO_Init(DC5V_TEST_PORT, &GPIO_InitStructure);
    /* Initialize ADC structure */
    ADC_StructInit(&ADC_InitStructure);
    /* Configure the ADC1 in continuous mode withe a resolution equal to 12 bits*/
    ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
    ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
    ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;
    ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
    ADC_InitStructure.ADC_ScanDirection = ADC_ScanDirection_Upward;
    ADC_Init(ADC1, &ADC_InitStructure);
    ADC_ChannelConfig(ADC1, DC5V_TEST_channel,ADC_SampleTime_239_5Cycles);
    ADC_ChannelConfig(ADC1, P_N_TEST_channel, ADC_SampleTime_239_5Cycles);
    /* ADC Calibration */
    ADC_GetCalibrationFactor(ADC1);
    /* ADC DMA request in circular mode */
    ADC_DMARequestModeConfig(ADC1, ADC_DMAMode_Circular);
    /* Enable ADC_DMA */
    ADC_DMACmd(ADC1, ENABLE);
    /* Enable the ADC peripheral */
    ADC_Cmd(ADC1, ENABLE);
    /* Wait the ADRDY flag */
    while (!ADC_GetFlagStatus(ADC1, ADC_FLAG_ADRDY));
    /* ADC1 regular Software Start Conv */
    ADC_StartOfConversion(ADC1);
ADC按照通道顺序循环采样并转换数据,然后DMA自动将对应的数据搬运至RegularConvData_Tab[]数组中。
t60yz 发表于 2022-4-30 19:58
使用该方法得到的ADC值有时候波动会比较大,如果不做滤波就直接采用的话,有可能会因为数据波动造成程序误判。如果将ADC值做中值滤波处理,即使有个别数据波动,对程序的影响则大幅度降低。因为DMA搬运新数据时会将旧数据覆盖掉,这里采用DMA中断处理,每发生一次DMA中断时将新的数据缓存起来,存够指定数量后再做中值滤波!void DMA_Config(void)函数加上DMA中断配置的代码如下
* @paramNone
* @retval None
    NVIC_InitTypeDefNVIC_InitStructure;
    /* Enable the DMA1 Interrupt */
    NVIC_InitStructure.NVIC_IRQChannel = DMA1_Channel1_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPriority = 0;
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
    NVIC_Init(&NVIC_InitStructure);
    /* DMA1 interrupt */
    DMA_ITConfig(DMA1_Channel1,DMA_IT_TC,ENABLE);
t60yz 发表于 2022-4-30 20:00
DMA中断处理函数如下
//ADC DMA数据传输完成
void DMA1_Channel1_IRQHandler(void)
    /* Check the status of the specified DMAy flag */
    if ((DMA1->ISR & DMA1_FLAG_TC1) != (uint32_t)RESET)
      ADC_DMA_INTERRUPT_HANDLER();
      //清除标志位
      DMA1->IFCR = DMA1_FLAG_TC1;
void ADC_DMA_INTERRUPT_HANDLER(void)
    u8 i;
    static u8times=0;
    static u16 buffer;
    for (i=0;i<ADC_DMA_BUFFER_SIZE;i++) {
      buffer += RegularConvData_Tab;
    if (++times >= 8) { //取8次平均值
            CalAverConvData_Tab = buffer>>3;
            buffer = 0; //清零
      times = 0;
Pulitzer 发表于 2022-10-6 09:29
代码量小的时候用来做条件判断
Uriah 发表于 2022-10-6 16:30
单片机一般都有内部程序区和数据区
Bblythe 发表于 2022-10-6 19:29
只要内存占用量不超过 256.0 就可以用 small 模式编译
周半梅 发表于 2023-5-1 08:26
可以开始在项目中动手用
Pulitzer 发表于 2023-5-1 09:29
在孔璧内部作金属处理后,可以让内部的各层线路能够彼此连接。
周半梅 发表于 2023-5-1 10:32
small 模式下未指存储类型的变量默认为data型
童雨竹 发表于 2023-5-1 11:25
实际上根本不需要其他块
Wordsworth 发表于 2023-5-1 12:28
分别记录车牌区域的上下高度。然后通过RGB-HSV颜色转换
Clyde011 发表于 2023-5-1 13:31
不要根据不同的参数类型走不同的代码逻辑
万图 发表于 2023-5-1 15:27
内部由寄存器、控制器、运算器和时钟四部分组成,各部分之间通过电信号连通
Uriah 发表于 2023-5-1 16:30
时间片轮的设计思想
帛灿灿 发表于 2023-5-1 18:26
嵌入式软件开发偶尔要收集和分析 log
Bblythe 发表于 2023-5-1 19:29
通过访问寄存器来控制I2C1工作时钟的开启。
页: [1]
查看完整版本: STM32 ADC DMA数据不稳定的解决方案
