[APM32F1] Flash——如何将大量字节、字数据写入Flash中
2757|5
 楼主| zjh20070904 发表于 2022-5-3 17:07 | 显示全部楼层 |阅读模式
flash, AG, ui, PA, fm
#技术资源#
1 概述
APM32F103xEFlash只能按照Halfword形式写入,在驱动库中只有写1个写HalfWord数据、1个写Word数据的函数,在现实应用中,有遇到将大量字节、字数据写入Flash的情况,下面记录了调试代码、现象、注意点。
2 参考代码及工程
#include "main.h"
#if defined (APM32F10X_HD)
#define FLASH_PAGE_SIZE    ((uint16_t)0x800)
#else
#define FLASH_PAGE_SIZE    ((uint16_t)0x400)
#endif
#define BANK1_WRITE_START_ADDR  ((uint32_t)0x08008000)
#define BANK1_WRITE_END_ADDR    ((uint32_t)0x0800C000)
enum {FAILED, PASSED};
volatile uint8_t MemoryProgramStatus = PASSED;
*@brief       Main program
*@param       None
*@retval      None
uint32_t gWordData[5010]={0};
uint8_t gByteData[5010]={0};
void Flash_WriteWord(uint32_t addr_start,uint32_t*p_data,uint32_t data_num)
     FMC_STATUS_TFLASHStatus = FMC_STATUS_COMPLETE;
     uint32_tpage_num=0,i=0,addr_temp=0,addr_end;
    page_num= data_num*4/ FLASH_PAGE_SIZE;
     if(data_num*4%FLASH_PAGE_SIZE!=0)
         {page_num++;}
     FMC_Unlock();
   FMC_ClearStatusFlag((FMC_FLAG_T)(FMC_FLAG_OC | FMC_FLAG_PE |FMC_FLAG_WPE));
    for(i =0; i<page_num; i++)
       FLASHStatus = FMC_ErasePage(addr_start + (FLASH_PAGE_SIZE * i));
         while(FLASHStatus!= FMC_STATUS_COMPLETE);
    addr_temp= addr_start;
     for(i=0;i<data_num;i++)
       FLASHStatus = FMC_ProgramWord(addr_temp, p_data);
       addr_temp = addr_temp + 4;
   FMC_Lock();
    //验证写入的数据是否正确
   addr_temp = addr_start;
         if((*(__IOuint32_t*) addr_temp) != p_data)
              break;
         addr_temp+= 4;
void Flash_WriteByte(uint32_t addr_start,uint8_t*p_data,uint32_t data_num)
     uint32_tword_data_temp=0,word_num=0,remainder_data_num=0,data_counter=0;
     page_num= data_num/FLASH_PAGE_SIZE;
     FMC_Unlock();
     if(data_num%FLASH_PAGE_SIZE!=0)
         {page_num++;}
    FMC_ClearStatusFlag((FMC_FLAG_T)(FMC_FLAG_OC| FMC_FLAG_PE | FMC_FLAG_WPE));
     word_num= data_num/4;
     remainder_data_num=data_num%4;
         如果写进入的数据是0x00010203,那在Flash中按字节读取的数据是0x03 0x02 0x01 0x00
         如果写进入的数据是0x03020100,那在Flash中按字节读取的数据是0x00 0x01 0x02 0x03
   data_counter=0;
     for(i=0;i<word_num;i++)
       word_data_temp = (uint32_t)*(p_data+data_counter);
       word_data_temp = word_data_temp |(((uint32_t)*(p_data+data_counter+1))<<8);
       word_data_temp = word_data_temp | (((uint32_t)*(p_data+data_counter+2))<<16);
       word_data_temp = word_data_temp |(((uint32_t)*(p_data+data_counter+3))<<24);
       data_counter=data_counter+4;
       FLASHStatus = FMC_ProgramWord(addr_temp, word_data_temp);
     word_data_temp=0x00;
     if(remainder_data_num!=0)
         for(i=0;i<remainder_data_num;i++)
              word_data_temp= word_data_temp |( ((uint32_t)*(p_data+data_counter+i))<< (i*8));
        for(;i<4;i++)
           word_data_temp = word_data_temp | ((0xFF)<<(i*8));
   FMC_Lock();
    //验证写入的数据是否正确
         if((*(__IOuint8_t*) addr_temp) != p_data)
              break;
         addr_temp++;
int main(void)
     uint32_ti=0;
     for(i=0;i<5000;i++)
         gWordData=i;
         gByteData=(uint8_t)i;
     //Flash_WriteWord(BANK1_WRITE_START_ADDR,gWordData,5000);
     Flash_WriteByte(BANK1_WRITE_START_ADDR,gByteData,5000);
     for(i=0;i<5003;i++)
         gWordData=i*2;
         gByteData=(uint8_t)i*2;
     //Flash_WriteWord(BANK1_WRITE_START_ADDR,gWordData,5003);
     Flash_WriteByte(BANK1_WRITE_START_ADDR,gByteData,5003);
     while(1);
3 现象3.1 5000/5003个字数据的结果
从地址0x08008000开始,写入5000个字数据,最后1个字数据的地址是:0x0800CE1C
过程
现象
1次赋值往Flash中写入5000个字后,从Flash中读取的数据
2次赋值往Flash中写入5003个字后,从Flash中读取的数据
结论
都已正常写入
3.2 5000/5003个字节数据的结果
从地址0x08008000开始,写入5000个字节数据,最后1个数据的地址是:0x08009387
过程
现象
1次赋值往Flash中写入5000个字节后,从Flash中读取的数据
1次赋值往Flash中写入5003个字节后,从Flash中读取的数据
结论
都已正常写入
4 注意点
1)计算擦除page数量时:
①如果字节数不是page的倍数,需要注意多出来的数据会写在下一个page中,因此要多擦除1个page
②数据是字时,计算要擦除的page数量时,需要在字个数乘以4的基础上计算
2)代码中调用的驱动函数是写word,在写字节数据时,需要注意:
①需要将数据按照小端模式将4个字节数据转化为1个字
②遇到数据个数不是4的整数时,不要忘记将剩下的数据写入Flash中
3)代码中等待写Flash状态时用的是死等,撰写不是很严谨,实际应用中可以使用“超时等待退出,并返回错误”
麻花油条 发表于 2022-5-5 11:45 来自手机 | 显示全部楼层
非常棒,收藏
JimN 发表于 2022-5-6 15:51 | 显示全部楼层
刚好有客户用到,推荐给他们
suncat0504 发表于 2022-5-7 14:43 | 显示全部楼层
挺好的,非常有帮助。可以使用flash作为eeprom来使用
 楼主| zjh20070904 发表于 2022-6-13 19:27 | 显示全部楼层
嗯,配合读取的动作,功能上可以模拟一个简易的EEPROM,电气特性上模拟太复杂了,还需要很多代码。
 楼主| zjh20070904 发表于 2022-6-13 19:29 | 显示全部楼层
刚好有客户用到,推荐给他们
认证:极海半导体
29
