wirelesswifi6 发表于 2022-5-7 14:30
IPQ8072/IPQ8074 WiFi 6E Card 4x4 2.4G & 5G 802.11ax -wallys
■ Qualcomm Atheros IPQ8072A AR Quad Core CPU■ On-board 5GHz radio, up to 2475 Mbps physical data rate 8 MB NOR Flash, 256MB NAND Flash■ On-board 2.4GHz radio, up to 1147Mbps physical data rate■ Support 802.11ac TX Beamforming■ Support 802.11ac/802.11ax MU-MIMO DL and UL■ Support OFDMA DL and UL■ Tri-band support with 5G SBS (4x4/5GHz ) + 4x4/2.4GHz■ Supports Dynamic Frequency Selection (DFS)
Absolute Maximum Rating
ParameterRatingUnit
Operating Temperature Range-20 to +70ºC
Storage Temperature Range-40 to +90ºC
Operating Humidity Range5 to +95 (non-condensing)%
Storage Humidity Range0 to +90 (non-condensing)%
Hardware Specifications
Symbol
Parameter
CPU
Qualcomm Atheros Quad Core ARM Cortex 64-bit A53 Processor IPQ8072A 2.2GHz CPU
CPU Frequency
Derived from Qualcomm Atheros AP.HK09
System Memory
1x 512MB, DDR4 2400MHz 16-bit interface
Frequency Range
2.412~2.472GHz,
5.150~5.825GHz
MiniPCIe Slot
1x MiniPCIe Slot with PCIe 3.0
Modulation Techniques
OFDMA: BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM, 1024-QAM
Environmental Temperature
Operating: -20ºC to 70ºC,
Storage: -40ºC to 90ºC
Flash
NOR Flash: 8 MB
NAND Flash: 256MB
Wireless
On-board 4x4 2.4GHz MU-MIMO OFDMA 802.11b/g/n/ax, max 17dBm per chain
On-board 4x4 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 17dBm per chain
8x U.FL Connectors
Reset Buttons
1x S/W Reset Button
DC Jack Input
1x DC Jack Connector: 12V
Interface
4x 1Gbps Ethernet Port,
2x 2.5Gbps Ethernet Port
2x USB 3.0 Port
1x JTAG 20 Pin Connector
1x Serial Port 4 Pin Connector
LED
2x RGB LED Indicators
Power Consumption
TBD
Wallys Communications (Suzhou) Co LTDdevelops, designs and manufactures wireless communication products, including routers, network cards, AP and antennas. Customization is also supported, The market is global, welcome to consult.EMAIL:sales@wallystech.com
页: [1]
查看完整版本: IPQ8072/IPQ8074 WiFi 6E Card 4x4 2.4G & 5G 802.11ax -wallys
