GD32F330串口发送数据和实际不符
用的是GD便准库写,收到的是C4,35.。。。Gpio_Init();systick_config();
Usart0_Init(115200);
while(1)
gpio_bit_write(GPIOB, GPIO_PIN_7, SET);
delay_1ms(1000);
usart_data_transmit(USART0,0xAC);
gpio_bit_write(GPIOB, GPIO_PIN_7, RESET);
delay_1ms(1000);
gpio_bit_write(GPIOB, GPIO_PIN_6, RESET);
usart_data_transmit(USART0,0xBA);
delay_1ms(1000);
gpio_bit_write(GPIOB, GPIO_PIN_6, SET);
usart_data_transmit(USART0,0x23);
void Usart0_Init(uint32_t BaudRate)
rcu_periph_clock_enable(RCU_GPIOA);
rcu_periph_clock_enable(RCU_USART0);
gpio_af_set(GPIOA, GPIO_AF_1, GPIO_PIN_9);
gpio_af_set(GPIOA, GPIO_AF_1, GPIO_PIN_10);
/*PA9TX*/
gpio_mode_set(GPIOA, GPIO_MODE_AF, GPIO_PUPD_PULLDOWN, GPIO_PIN_9);
gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_9);
gpio_mode_set(GPIOA, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_10);
gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_10);
usart_deinit(USART0);
usart_baudrate_set(USART0,BaudRate);
usart_parity_config(USART0,USART_PM_NONE); /*奇偶校验*/
usart_word_length_set(USART0,USART_WL_8BIT); /*USART字长*/
usart_stop_bit_set(USART0,USART_STB_1BIT); /*配置USART停止位*/
usart_data_first_config(USART0,USART_MSBF_MSB); /*配置数据传输时低位在前或高位在前*/
usart_hardware_flow_rts_config(USART0,USART_RTS_DISABLE);
usart_hardware_flow_cts_config(USART0,USART_CTS_DISABLE);
usart_receive_config(USART0, USART_RECEIVE_ENABLE);
usart_transmit_config(USART0, USART_TRANSMIT_ENABLE);
usart_enable(USART0);
data:image/png;base64,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**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
页:
[1]
