1、从官网下载ISE
到官网注册,然后下载linux版本的ISE14.7。
链接:http://www.xilinx.com/support/do ... v/design-tools.html
到官网注册,然后下载linux版本的ISE。
2、解压 一定要在linux下解压 [python] view plaincopy
$ sudo tar xvf Xilinx_ISE_DS_Lin_14.6_P.68d_3.tar
[sudo] password for yunz:
#unpakging......
$ cd Xilinx_ISE_DS_Lin_14.6_P.68d_3/
$ ls
bin data idata labtools msg planahead_wp webpack xsetup
common edk ise lib planahead sysgen xinfo
$ sudo chmod +x xsetup //用这种方法反复安装都不对,最后采用另外一个xsetup文件就可以了(bin目录下的32位安装)。
$ ./xsetup
#unpakging......
$ ls
$ ./xsetup 3、安装 下面就是图形界面安装了,和windows下没什么不同 但要注意到这里的时候 不要点选 [python] view plaincopy
Install cable drivers
直接点Next 记下Install summary [plain] view plaincopy
Install Location(s):
/usr/14.6/ISE_DS
Edition : ISE Design Suite System Edition
Option: Acquire or Manage a License Key
ISE DS Common
Install Location: /usr/14.6/ISE_DS/common
Module: ISE DS Common
EDK
Install Location: /usr/14.6/ISE_DS/EDK
Module: EDK
PlanAhead Analysis Tool
Install Location: /usr/14.6/ISE_DS/PlanAhead
Module: PlanAhead Common Files
Option: setupEnv.sh
ISE
Install Location: /usr/14.6/ISE_DS/ISE
Module: Design Environment Tools
Module: WebPACK Devices
Module: Edition Devices
Option: Ensure Linux System Generator Symlinks
Option: Install Linux System Generator Info XML
Option: Configure WebTalk
Option: Enable WebTalk to send software, IP and device usage statistics to Xilinx (Always enabled for WebPACK license)
System Generator
Install Location: /usr/14.6/ISE_DS/SysGen
Module: System Generator
Option: Version Equalizer
/usr/14.6/ISE_DS
Option: Acquire or Manage a License Key ISE DS Common
Module: ISE DS Common EDK
Module: EDK PlanAhead Analysis Tool
Option: setupEnv.sh ISE
Option: Enable WebTalk to send software, IP and device usage statistics to Xilinx (Always enabled for WebPACK license) System Generator
