qq7643066 发表于 2022-6-5 16:25
rk358 android11点屏流程
rk3568 芯片非常强大,可以支持的屏幕接口有很多,显示接口支持可是非常丰富的,
sunychip-rk3568开发板支持 MIPI 接口的屏幕,接口如下图所示:
1 屏幕点亮流程点亮屏幕基本的流程是一致的,一般是背光使能---->背光点亮---->屏幕使能---->reset 引脚按照指定的时序/波形拉高或者拉低---->初始化序列命令发送。流程主要是以下几步需要向屏幕厂商要一些屏幕关键参数和资料进行关键引脚对应进行设备树配置进行驱动配置源码编译,烧写镜像测试15.2.1关键引脚对应15.2.2屏幕关键参数15.2.3屏幕初始化序列改写2根据屏参和硬件设计填写 dts这一部分是重点,全部之前的工作全为此处进行准备。我们新建一个 dtsi 文件特意放屏幕相关的:kernel/arch/arm64/boot/dts/rockchip/topeet_rk3568_lcds.dtsi然后在kernel/arch/arm64/boot/dts/rockchip/rk3568-evb1-ddr4-v10.dts 文件中加入这个头文件,如下图所示:
另注意,由于 DTS 文件设计到层层包含(DTS 文件可以包含后缀为.dtsi 的文件,作用就像 C 语言中的.h 文件),故建议重要配置及板卡特性配置写到最后一级的 DTS 文件中,防止由于在较高层级的 dtsi 配置后手误在后面又进行了配置,导致配置被错误覆盖。共需要以下几个重点内容:dsi, route_dsi, backlight, vcc_lcd,dsi_in_vopb,dsi_in_vopl,vopb。2.1 dsi节点mipi 屏幕我们使用 dsi1 接口,所以需要在设备树里面查找 dsi 节点,如下图所示:kernel/arch/arm64/boot/dts/rockchip/rk3568.dtsi
(瑞芯微写好的)kernel/arch/arm64/boot/dts/rockchip/rk3568.dtsi(瑞芯微写好的)
dsi1: dsi@fe070000 {compatible = "rockchip,rk3568-mipi-dsi";reg = <0x0 0xfe070000 0x0 0x10000>;interrupts = <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>;clocks = <&cru PCLK_DSITX_1>, <&cru HCLK_VO>, <&video_phy1>;clock-names = "pclk", "hclk", "hs_clk";resets = <&cru SRST_P_DSITX_1>;reset-names = "apb";phys = <&video_phy1>;phy-names = "mipi_dphy";power-domains = <&power RK3568_PD_VO>;rockchip,grf = <&grf>;#address-cells = <1>;#size-cells = <0>;status = "disabled";ports {#address-cells = <1>;#size-cells = <0>;dsi1_in: port@0 {reg = <0>;#address-cells = <1>;dsi1: dsi@fe070000 {compatible = "rockchip,rk3568-mipi-dsi";reg = <0x0 0xfe070000 0x0 0x10000>;interrupts = <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>;clocks = <&cru PCLK_DSITX_1>, <&cru HCLK_VO>, <&video_phy1>;clock-names = "pclk", "hclk", "hs_clk";resets = <&cru SRST_P_DSITX_1>;reset-names = "apb";phys = <&video_phy1>;phy-names = "mipi_dphy";power-domains = <&power RK3568_PD_VO>;rockchip,grf = <&grf>;#address-cells = <1>;#size-cells = <0>;status = "disabled";ports {#address-cells = <1>;#size-cells = <0>;dsi1_in: port@0 {reg = <0>;#address-cells = <1>;#size-cells = <0>;dsi1_in_vp0: endpoint@0 {reg = <0>;remote-endpoint = <&vp0_out_dsi1>;status = "disabled";};dsi1_in_vp1: endpoint@1 {reg = <1>;remote-endpoint = <&vp1_out_dsi1>;status = "disabled";};};};};
};默认的源码中是配置了 dsi1 节点的,是适配的瑞芯微的屏幕。现在我们要适配迅为的MIPI 7 寸屏,所以我们在修改之前,要删掉瑞芯微之前适配的屏幕节点。在下图的设备树中找到&dsi1 以及和 dsi1 相关的注释掉。
我们使用 dsi1 绑定到 vp1 上,所以 dsi1_in_vp0 节点为 disabled,dsi1_in_vp1 节点为 okay当 dsi1 使能的时候,video_phy1 要使能,video_phy0 要关闭。设备树 topeet_rk3568_lcds.dtsi
中添加如下图所示:
2.2 Backlight背光常用的有三种情况:一是 常开。二是 背光 IC 使能后,输入 PWM 信号调光。三是 背光 IC 使能后,通过 FB 获得反馈自动进行调光。
设备树里面配置背光。首先根据原理图,我们知道使用的是 pwm5,
pwms = <&pwm5 0 25000 0>; 配置 pwm,使用 pwm5,25000 是周期,pwm 为正极性。brightness-levels 属性:配置背光亮度数组,一般以值 255 为一个 scale,当 pwm 设置为正极时,从 0~255 表示背光为正极,占空比从 0%~100%变化,,255~0 为负极性,占空比从100%~0%变化,当 pwm 设置为负极性时,反之。default-brightness-level 属性,时开机时默认背光亮度,范围是 0~2552.3 ** 显示设备树kernel/scripts/dtc/include-prefixes/arm64/rockchip/rk3568.dtsi 中节点如下:
所以我们要使用 route_dsi1 显示通路,绑定到 vp1 上,修改kernel/scripts/dtc/include-prefixes/arm64/rockchip/topeet_rk3568_lcds.dtsi文件,添加如下所示:
3 Config 配置RK3568 SDK 下 kernel/arch/arm64/configs/*_defconfig 已经把 LCD 相关的配置设置好了,如果自己做了修改,修改kernel/arch/arm64/configs/rockchip_defconfig 配置文件,增加如下所示:CONFIG_DRM_ROCKCHIP=yCONFIG_ROCKCHIP_DW_MIPI_DSI=yCONFIG_DRM_PANEL_SIMPLE=y4烧写验证4.1测试显示重新编译 android 源码,烧写镜像,发现 mipi 屏幕显示正常。如下图所示:4.2 背光亮度调节测试目前还没有配置屏幕触摸,我们可以在开发板上插上鼠标,进入”设置”APP,依次点击“显示”,“亮度”,拖动滑条可以调节亮度。也可以使用命令行来设置屏幕亮度,数值可以在 0~250 中设置,数字越大,亮度越高。
echo 100 >/sys/class/backlight/backlight/brightness
页: [1]
查看完整版本: rk358 android11点屏流程
