wenfen 发表于 2022-6-11 15:30
8个IF语句
8个IF语句,怎样变简单些?
chuxh 发表于 2022-6-11 15:32
楼主程序可以公开吗?贴程序看下吧,这么说看不出什么原因
wenfen 发表于 2022-6-11 15:34
原意是8个结构变量只要不为0,并且err_chl_date.chl_date的8个不同的位,置1为真,那么数组g_AckBuf的8个位分别置1.要不就为0
if((err_pra.err_name_date!=0) && ((err_chl_date.chl_date &= 0x01)==0x01))
        g_AckBuf|=0x01;
                                                               else {
                     g_AckBuf&=0xf7;
        if((err_pra.err_name_date!=0) && ((err_chl_date.chl_date &= 0x02)==0x01))
        g_AckBuf|=0x02;
                                                               else {
                     g_AckBuf&=0xfd;
                if((err_pra.err_name_date!=0) && ((err_chl_date.chl_date &= 0x04)==0x01))
        g_AckBuf|=0x04;
                                                               else {
                     g_AckBuf&=0xfb;
        if((err_pra.err_name_date!=0) && ((err_chl_date.chl_date &= 0x08)==0x01))
        g_AckBuf|=0x08;
                                                               else {
                     g_AckBuf&=0xf7;
                if((err_pra.err_name_date!=0) && ((err_chl_date.chl_date &= 0x10)==0x01))
        g_AckBuf|=0x10;
                                                               else {
                     g_AckBuf&=0xef;
        if((err_pra.err_name_date!=0) && ((err_chl_date.chl_date &= 0x20)==0x01))
        g_AckBuf|=0x20;
                                                               else {
                     g_AckBuf&=0xdf;
                if((err_pra.err_name_date!=0) && ((err_chl_date.chl_date &= 0x40)==0x01))
        g_AckBuf|=0x40;
                                                               else {
                     g_AckBuf&=0xbf;
        if((err_pra.err_name_date!=0) && ((err_chl_date.chl_date &= 0x80)==0x01))
        g_AckBuf|=0x80;
                                                         else {
                     g_AckBuf&=0x7f;
                g_AckBuf|=0x01;
         else {
                     g_AckBuf&=0xf7;
if((err_pra.err_name_date!=0) && ((err_chl_date.chl_date &= 0x02)==0x02))
                g_AckBuf|=0x02;
      else {
                     g_AckBuf&=0xfd;
if((err_pra.err_name_date!=0) && ((err_chl_date.chl_date &= 0x04)==0x04))
                              g_AckBuf|=0x04;
         else {
                     g_AckBuf&=0xfb;
if((err_pra.err_name_date!=0) && ((err_chl_date.chl_date &= 0x08)==0x08))
                        g_AckBuf|=0x08;
else {
             g_AckBuf&=0xf7;
if((err_pra.err_name_date!=0) && ((err_chl_date.chl_date &= 0x10)==0x10))
                        g_AckBuf|=0x10;
else {
               g_AckBuf&=0xef;
if((err_pra.err_name_date!=0) && ((err_chl_date.chl_date &= 0x20)==0x20))
                g_AckBuf|=0x20;
else {
            g_AckBuf&=0xdf;
if((err_pra.err_name_date!=0) && ((err_chl_date.chl_date &= 0x40)==0x40))
                        g_AckBuf|=0x40;
      else {
                     g_AckBuf&=0xbf;
if((err_pra.err_name_date!=0) && ((err_chl_date.chl_date &= 0x80)==0x80))
                g_AckBuf|=0x80;
      else {
                     g_AckBuf&=0x7f;
shimx 发表于 2022-6-11 15:39
可以变成一条赋值语句,效率也可以提高一点,但会变得难于理解
kangzj 发表于 2022-6-11 15:41
哦。。。。不行。
你的括弧里面有赋值,不能弄掉。。。
chuxh 发表于 2022-6-11 15:44
来个for循环。。。
xxrs 发表于 2022-6-11 15:46
#define MAX_NUM(unsigned char)0xff
#define CNT         (unsigned char)0x08
const unsigned char Tab = {0x01, 0x02, 0x04 ,0x08, 0x10, 0x20, 0x40, 0x80};
unsigned char u8Loop = 0;
for (; u8Loop < CNT; u8Loop++)
      if (0 != err_pra.err_name_date)
               if (Tab== (err_chl_date.chl_date & Tab))
                        g_AckBuf |= ab;
               else
                         g_AckBuf &= (MAX_NUM - ab);
      else
wenfen 发表于 2022-6-11 15:48
高手啊,牛X
kangzj 发表于 2022-6-11 15:50
楼主写代码发现有很多代码重复的时候首先要考虑到的就是能不能用查表法,自己做个表通过索引值查表
diweo 发表于 2022-6-11 15:50
        for(int i=0;i<8;i++)
                uin8_t mask = 1<<i;
                if((err_pra.err_name_date != 0) && ((err_chl_date.chl_date &= mask) == 0x01))
                        g_AckBuf |= mask;
                else
                        g_AckBuf &= ~mask;
renyaq 发表于 2022-6-11 15:53
用switch语句试试
yszong 发表于 2022-6-11 16:00
或者看看有没有重复项合并下
renyaq 发表于 2022-6-11 16:02
当然可以了
heweibig 发表于 2022-6-11 16:04
if里边嵌套for就可以
wyjie 发表于 2022-6-11 16:07
if 嵌套for 然后在for里边嵌套if就行了
chuxh 发表于 2022-6-11 16:10
嵌套多了 会不会速度变慢
pengf 发表于 2022-6-11 16:13
这种有规律的直接用查表法,和函数指针打包成一个结构体,代码清晰干净
wenfen 发表于 2022-6-11 16:16
好的,我明天去单位试一下,多谢各位大侠了哈
kiwis66 发表于 2022-6-19 14:34
if少用,容易头晕
页: [1]
查看完整版本: 8个IF语句
