STM32F042F4P6 CAN出现初始化不成功
用的CubeMx配置的CAN模块,自动生存的代码。发现代码在如下位置,过不去,求助。HAL_StatusTypeDef HAL_CAN_Init(CAN_HandleTypeDef* hcan)
uint32_t status = CAN_INITSTATUS_FAILED;/* Default init status */
uint32_t tickstart = 0U;
/* Check CAN handle */
if(hcan == NULL)
return HAL_ERROR;
/* Check the parameters */
assert_param(IS_CAN_ALL_INSTANCE(hcan->Instance));
assert_param(IS_FUNCTIONAL_STATE(hcan->Init.TTCM));
assert_param(IS_FUNCTIONAL_STATE(hcan->Init.ABOM));
assert_param(IS_FUNCTIONAL_STATE(hcan->Init.AWUM));
assert_param(IS_FUNCTIONAL_STATE(hcan->Init.NART));
assert_param(IS_FUNCTIONAL_STATE(hcan->Init.RFLM));
assert_param(IS_FUNCTIONAL_STATE(hcan->Init.TXFP));
assert_param(IS_CAN_MODE(hcan->Init.Mode));
assert_param(IS_CAN_SJW(hcan->Init.SJW));
assert_param(IS_CAN_BS1(hcan->Init.BS1));
assert_param(IS_CAN_BS2(hcan->Init.BS2));
assert_param(IS_CAN_PRESCALER(hcan->Init.Prescaler));
if(hcan->State == HAL_CAN_STATE_RESET)
/* Allocate lock resource and initialize it */
hcan->Lock = HAL_UNLOCKED;
/* Init the low level hardware */
HAL_CAN_MspInit(hcan);
/* Initialize the CAN state*/
hcan->State = HAL_CAN_STATE_BUSY;
/* Exit from sleep mode */
CLEAR_BIT(hcan->Instance->MCR, CAN_MCR_SLEEP);
/* Request initialisation */
SET_BIT(hcan->Instance->MCR, CAN_MCR_INRQ);
/* Get tick */
tickstart = HAL_GetTick();
/* Wait the acknowledge */
while(HAL_IS_BIT_CLR(hcan->Instance->MSR, CAN_MSR_INAK))
{代码一直在这里执行,跳不出去。感觉是硬件没应答,在其他帖子中有看到说是电源不稳,会造成这种情况,我测了电源,确认电源没问题。不知道还有其他什么情况会导致这样。。。
if((HAL_GetTick()-tickstart) > CAN_TIMEOUT_VALUE)
hcan->State= HAL_CAN_STATE_TIMEOUT;
/* Process unlocked */
__HAL_UNLOCK(hcan);
return HAL_TIMEOUT;
/* Check acknowledge */
if (HAL_IS_BIT_SET(hcan->Instance->MSR, CAN_MSR_INAK))
/* Set the time triggered communication mode */
if (hcan->Init.TTCM == ENABLE)
SET_BIT(hcan->Instance->MCR, CAN_MCR_TTCM);
else
CLEAR_BIT(hcan->Instance->MCR, CAN_MCR_TTCM);
/* Set the automatic bus-off management */
if (hcan->Init.ABOM == ENABLE)
SET_BIT(hcan->Instance->MCR, CAN_MCR_ABOM);
else
CLEAR_BIT(hcan->Instance->MCR, CAN_MCR_ABOM);
/* Set the automatic wake-up mode */
if (hcan->Init.AWUM == ENABLE)
SET_BIT(hcan->Instance->MCR, CAN_MCR_AWUM);
else
CLEAR_BIT(hcan->Instance->MCR, CAN_MCR_AWUM);
/* Set the no automatic retransmission */
if (hcan->Init.NART == ENABLE)
SET_BIT(hcan->Instance->MCR, CAN_MCR_NART);
else
CLEAR_BIT(hcan->Instance->MCR, CAN_MCR_NART);
/* Set the receive FIFO locked mode */
if (hcan->Init.RFLM == ENABLE)
SET_BIT(hcan->Instance->MCR, CAN_MCR_RFLM);
else
CLEAR_BIT(hcan->Instance->MCR, CAN_MCR_RFLM);
/* Set the transmit FIFO priority */
if (hcan->Init.TXFP == ENABLE)
SET_BIT(hcan->Instance->MCR, CAN_MCR_TXFP);
else
CLEAR_BIT(hcan->Instance->MCR, CAN_MCR_TXFP);
/* Set the bit timing register */
WRITE_REG(hcan->Instance->BTR, (uint32_t)(hcan->Init.Mode |
hcan->Init.SJW |
hcan->Init.BS1 |
hcan->Init.BS2 |
(hcan->Init.Prescaler - 1U) ));
/* Request leave initialisation */
CLEAR_BIT(hcan->Instance->MCR, CAN_MCR_INRQ);
/* Get tick */
while(HAL_IS_BIT_SET(hcan->Instance->MSR, CAN_MSR_INAK))
__HAL_UNLOCK(hcan);
return HAL_TIMEOUT;
/* Check acknowledged */
if(HAL_IS_BIT_CLR(hcan->Instance->MSR, CAN_MSR_INAK))
status = CAN_INITSTATUS_SUCCESS;
if(status == CAN_INITSTATUS_SUCCESS)
/* Set CAN error code to none */
hcan->ErrorCode = HAL_CAN_ERROR_NONE;
/* Initialize the CAN state */
hcan->State = HAL_CAN_STATE_READY;
/* Return function status */
return HAL_OK;
else
hcan->State = HAL_CAN_STATE_ERROR;
return HAL_ERROR;
} 补充下:端口的配置:
void HAL_CAN_MspInit(CAN_HandleTypeDef* canHandle)
GPIO_InitTypeDef GPIO_InitStruct;
if(canHandle->Instance==CAN)
/* USER CODE BEGIN CAN_MspInit 0 */
/* USER CODE END CAN_MspInit 0 */
/* CAN clock enable */
__HAL_RCC_CAN1_CLK_ENABLE();
/**CAN GPIO Configuration
PA11 ------> CAN_RX
PA12 ------> CAN_TX
GPIO_InitStruct.Pin = GPIO_PIN_11|GPIO_PIN_12;
GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
GPIO_InitStruct.Pull = GPIO_NOPULL;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
GPIO_InitStruct.Alternate = GPIO_AF4_CAN;
HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
/* USER CODE BEGIN CAN_MspInit 1 */
/* USER CODE END CAN_MspInit 1 */
先测试下CAN的回环,通的话在机对机发送
也可以使用CAN分析仪来检测,看下报文
我也遇到过这个问题 后来发现是晶振没有起振
楼主的问题解决了么?我也遇到一样的问题,用的是STM32F413的芯片
单片机BOOT0引脚接个10K电阻到地,解决问题。
BOOT0电平不稳是个隐形问题,的确会产生诸多奇奇怪怪的问题。 boot脚,不是非高即低的么?
页:
[1]
