LAN8720A 不能获取IP,求RT-Thread的驱动
本帖最后由 dongly 于 2022-6-18 11:31 编辑[*]问题: 在rt-thread 最新版下,加入LAN8720A的支持,不能获取IP,但2个网络指示灯亮,debug时,有收发数据
[*]硬件: AT32F407VGT7 + LAN7820A,RMII_RX为PC4,PC5,LAN8720A 自带25MHz晶振
[*]用雅特力的例程可以工作,说明硬件没问题
[*]求指导,或移植好的驱动
[*]drv_emac.h/*
* Copyright (c) 2006-2021, RT-Thread Development Team
* SPDX-License-Identifier: Apache-2.0
* Change Logs:
* Date Author Notes
* 2022-05-16 shelton first version
#ifndef __DRV_EMAC_H__
#define __DRV_EMAC_H__
#include "drv_common.h"
#include <rtdevice.h>
#include <rthw.h>
#include <rtthread.h>
/* the phy basic control register */
#define PHY_BASIC_CONTROL_REG 0x00U
#define PHY_RESET_MASK (1 << 15)
#define PHY_AUTO_NEGOTIATION_MASK (1 << 12)
/* the phy basic status register */
#define PHY_BASIC_STATUS_REG 0x01U
#define PHY_LINKED_STATUS_MASK (1 << 2)
#define PHY_AUTONEGO_COMPLETE_MASK (1 << 5)
/* the phy id one register */
#define PHY_ID1_REG 0x02U
/* the phy id two register */
#define PHY_ID2_REG 0x03U
/* the phy auto-negotiate advertise register */
#define PHY_AUTONEG_ADVERTISE_REG 0x04U
#if defined(PHY_USING_DM9162)
#define PHY_CONTROL_REG (0x00) /*!< basic mode control register */
#define PHY_STATUS_REG (0x01) /*!< basic mode status register */
#define PHY_SPECIFIED_CS_REG (0x11) /*!< specified configuration and status register */
/* phy control register */
#define PHY_AUTO_NEGOTIATION_BIT (0x1000) /*!< enable auto negotiation */
#define PHY_LOOPBACK_BIT (0x4000) /*!< enable loopback */
#define PHY_RESET_BIT (0x8000) /*!< reset phy */
/* phy status register */
#define PHY_LINKED_STATUS_BIT (0x0004) /*!< link status */
#define PHY_NEGO_COMPLETE_BIT (0x0020) /*!< auto negotiation complete */
/* phy specified control/status register */
#define PHY_FULL_DUPLEX_100MBPS_BIT (0x8000) /*!< full duplex 100 mbps */
#define PHY_HALF_DUPLEX_100MBPS_BIT (0x4000) /*!< half duplex 100 mbps */
#define PHY_FULL_DUPLEX_10MBPS_BIT(0x2000) /*!< full duplex 10 mbps */
#define PHY_HALF_DUPLEX_10MBPS_BIT(0x1000) /*!< half duplex 10 mbps */
#define PHY_DUPLEX_MODE \
(PHY_FULL_DUPLEX_100MBPS_BIT | PHY_FULL_DUPLEX_10MBPS_BIT) /*!< full duplex mode */
#define PHY_SPEED_MODE (PHY_FULL_DUPLEX_10MBPS_BIT | PHY_HALF_DUPLEX_10MBPS_BIT) /*!< 10 mbps */
/*the phy interrupt source flag register. */
#define PHY_INTERRUPT_FLAG_REG 0x15U
/*the phy interrupt mask register. */
#define PHY_INTERRUPT_MASK_REG 0x15U
#define PHY_LINK_CHANGE_FLAG (1 << 2)
#define PHY_LINK_CHANGE_MASK (1 << 9)
#define PHY_INT_MASK 0
#elif defined(PHY_USING_DP83848)
#define PHY_SPECIFIED_CS_REG (0x10) /*!< phy status register */
#define PHY_DUPLEX_MODE (0x0004) /*!< full duplex mode */
#define PHY_SPEED_MODE (0x0002) /*!< 10 mbps */
#define PHY_INTERRUPT_FLAG_REG 0x12U
#define PHY_LINK_CHANGE_FLAG (1 << 13)
/*the phy interrupt control register. */
#define PHY_INTERRUPT_CTRL_REG 0x11U
#define PHY_INTERRUPT_EN ((1 << 0) | (1 << 1))
#define PHY_INTERRUPT_MASK_REG 0x12U
#define PHY_INT_MASK (1 << 5)
#elif defined(PHY_USING_LAN8720A)
#define PHY_SPECIFIED_CS_REG (0x1F) /*!< phy status register */
#define PHY_DUPLEX_MODE (0x0100) /*!< full duplex mode */
#define PHY_SPEED_MODE(0x2000) /*!< 100 mbps */
#define PHY_FULL_DUPLEX_100MBPS_BIT (0x0018) /*!< full duplex 100 mbps */
#define PHY_HALF_DUPLEX_100MBPS_BIT (0x0008) /*!< half duplex 100 mbps */
#define PHY_FULL_DUPLEX_10MBPS_BIT(0x0014) /*!< full duplex 10 mbps */
#define PHY_HALF_DUPLEX_10MBPS_BIT(0x0004) /*!< half duplex 10 mbps */
#define PHY_DUPLEX_MBPS_MSK (0x001C)
/*The PHY interrupt source flag register. */
#define PHY_INTERRUPT_FLAG_REG (0x01DU)
#endif
#endif /* __DRV_EMAC_H__ */
* Change Logs:
* Date Author Notes
#include "drv_emac.h"
#include <netif/ethernetif.h>
#include <lwipopts.h>
/* debug option */
// #define EMAC_RX_DUMP
// #define EMAC_TX_DUMP
#define DRV_DEBUG
#define LOG_TAG "drv.emac"
#include <drv_log.h>
/* emac memory buffer configuration */
#define EMAC_NUM_RX_BUF 4 /* 0x1800 for rx (4 * 1536 = 6k) */
#define EMAC_NUM_TX_BUF 2 /* 0x0600 for tx (2 * 1536 = 3k) */
#define MAX_ADDR_LEN 6
struct rt_at32_emac
/* inherit from ethernet device */
struct eth_device parent;
#ifndef PHY_USING_INTERRUPT_MODE
rt_timer_t poll_link_timer;
#endif
/* interface address info, hw address */
rt_uint8_t dev_addr;
/* emac_speed */
emac_speed_type emac_speed;
/* emac_duplex_mode */
emac_duplex_type emac_mode;
static emac_dma_desc_type *dma_rx_dscr_tab, *dma_tx_dscr_tab;
extern emac_dma_desc_type *dma_rx_desc_to_get, *dma_tx_desc_to_set;
static rt_uint8_t *rx_buff, *tx_buff;
static struct rt_at32_emac at32_emac_device;
static uint8_t phy_addr = 0xFF;
static struct rt_semaphore tx_wait;
static rt_bool_t tx_is_waiting = RT_FALSE;
#if defined(EMAC_RX_DUMP) || defined(EMAC_TX_DUMP)
#define __is_print(ch) ((unsigned int)((ch) - ' ') < 127u - ' ')
static void dump_hex(const rt_uint8_t *ptr, rt_size_t buflen)
unsigned char *buf = (unsigned char *)ptr;
int i, j;
for (i = 0; i < buflen; i += 16)
rt_kprintf("%08X: ", i);
for (j = 0; j < 16; j++)
if (i + j < buflen)
rt_kprintf("%02X ", buf);
else
rt_kprintf(" ");
rt_kprintf(" ");
if (i + j < buflen)
rt_kprintf("%c", __is_print(buf) ? buf : '.');
rt_kprintf("\n");
#endif
// * @brief phy reset
// static void phy_reset(void)
// gpio_init_type gpio_init_struct;
// #if defined (SOC_SERIES_AT32F437)
// crm_periph_clock_enable(CRM_GPIOE_PERIPH_CLOCK, TRUE);
// crm_periph_clock_enable(CRM_GPIOG_PERIPH_CLOCK, TRUE);
// gpio_default_para_init(&gpio_init_struct);
// gpio_init_struct.gpio_drive_strength = GPIO_DRIVE_STRENGTH_STRONGER;
// gpio_init_struct.gpio_mode = GPIO_MODE_OUTPUT;
// gpio_init_struct.gpio_out_type = GPIO_OUTPUT_PUSH_PULL;
// gpio_init_struct.gpio_pull = GPIO_PULL_NONE;
// gpio_init_struct.gpio_pins = GPIO_PINS_15;
// gpio_init(GPIOE, &gpio_init_struct);
// gpio_init(GPIOG, &gpio_init_struct);
// gpio_bits_reset(GPIOE, GPIO_PINS_15);
// gpio_bits_reset(GPIOG, GPIO_PINS_15);
// rt_thread_mdelay(2);
// gpio_bits_set(GPIOE, GPIO_PINS_15);
// #endif
// #if defined (SOC_SERIES_AT32F407)
// crm_periph_clock_enable(CRM_GPIOC_PERIPH_CLOCK, TRUE);
// gpio_init_struct.gpio_pins = GPIO_PINS_8;
// gpio_init(GPIOC, &gpio_init_struct);
// gpio_bits_reset(GPIOC, GPIO_PINS_8);
// gpio_bits_set(GPIOC, GPIO_PINS_8);
// #endif
// rt_thread_mdelay(2000);
* @brief reset phy register
static error_status emac_phy_register_reset(void)
uint16_t data = 0;
uint32_t timeout = 0;
uint32_t i = 0;
if(emac_phy_register_write(phy_addr, PHY_CONTROL_REG, PHY_RESET_BIT) == ERROR)
return ERROR;
for(i = 0; i < 0x000FFFFF; i++);
do
timeout++;
if(emac_phy_register_read(phy_addr, PHY_CONTROL_REG, &data) == ERROR)
return ERROR;
} while((data & PHY_RESET_BIT) && (timeout < PHY_TIMEOUT));
for(i = 0; i < 0x00FFFFF; i++);
if(timeout == PHY_TIMEOUT)
return ERROR;
return SUCCESS;
* @brief set mac speed related parameters
static error_status emac_speed_config(emac_auto_negotiation_type nego, emac_duplex_type mode, emac_speed_type speed)
uint16_t data = 0;
if(nego == EMAC_AUTO_NEGOTIATION_ON)
do
timeout++;
if(emac_phy_register_read(phy_addr, PHY_STATUS_REG, &data) == ERROR)
return ERROR;
} while(!(data & PHY_LINKED_STATUS_BIT) && (timeout < PHY_TIMEOUT));
return ERROR;
timeout = 0;
if(emac_phy_register_write(phy_addr, PHY_CONTROL_REG, PHY_AUTO_NEGOTIATION_BIT) == ERROR)
return ERROR;
do
timeout++;
return ERROR;
} while(!(data & PHY_NEGO_COMPLETE_BIT) && (timeout < PHY_TIMEOUT));
return ERROR;
if(emac_phy_register_read(phy_addr, PHY_SPECIFIED_CS_REG, &data) == ERROR)
return ERROR;
#ifdef PHY_USING_DM9162
if(data & PHY_FULL_DUPLEX_100MBPS_BIT)
emac_fast_speed_set(EMAC_SPEED_100MBPS);
emac_duplex_mode_set(EMAC_FULL_DUPLEX);
else if(data & PHY_HALF_DUPLEX_100MBPS_BIT)
emac_duplex_mode_set(EMAC_HALF_DUPLEX);
else if(data & PHY_FULL_DUPLEX_10MBPS_BIT)
emac_fast_speed_set(EMAC_SPEED_10MBPS);
else if(data & PHY_HALF_DUPLEX_10MBPS_BIT)
#endif
#ifdef PHY_USING_DP83848
if(data & PHY_DUPLEX_MODE)
else
if(data & PHY_SPEED_MODE)
else
#endif
#ifdef PHY_USING_LAN8720A
if ((data & PHY_DUPLEX_MBPS_MSK) == PHY_FULL_DUPLEX_100MBPS_BIT)
if ((data & PHY_DUPLEX_MBPS_MSK) == PHY_HALF_DUPLEX_100MBPS_BIT)
if ((data & PHY_DUPLEX_MBPS_MSK) == PHY_FULL_DUPLEX_10MBPS_BIT)
#endif
else
if(emac_phy_register_write(phy_addr, PHY_CONTROL_REG, (uint16_t)((mode << 8) | (speed << 13))) == ERROR)
return ERROR;
if(speed == EMAC_SPEED_100MBPS)
else
if(mode == EMAC_FULL_DUPLEX)
else
return SUCCESS;
* @brief initialize emac phy
static error_status emac_phy_init(emac_control_config_type *control_para)
emac_clock_range_set();
if(emac_phy_register_reset() == ERROR)
return ERROR;
if(emac_speed_config(control_para->auto_nego, control_para->duplex_mode, control_para->fast_ethernet_speed) == ERROR)
return ERROR;
emac_control_config(control_para);
return SUCCESS;
* @brief emac initialization function
static rt_err_t rt_at32_emac_init(rt_device_t dev)
emac_control_config_type mac_control_para;
emac_dma_config_type dma_control_para;
/* check till phy detected */
while(phy_addr == 0xFF)
rt_thread_mdelay(1000);
/* emac reset */
emac_reset();
/* software reset emac dma */
emac_dma_software_reset_set();
while(emac_dma_software_reset_get() == SET);
emac_control_para_init(&mac_control_para);
mac_control_para.auto_nego = EMAC_AUTO_NEGOTIATION_ON;
if(emac_phy_init(&mac_control_para) == ERROR)
LOG_E("emac hardware init failed");
return -RT_ERROR;
else
LOG_D("emac hardware init success");
emac_transmit_flow_control_enable(TRUE);
emac_zero_quanta_pause_disable(TRUE);
/* set mac address */
emac_local_address_set(at32_emac_device.dev_addr);
/* set emac dma rx link list */
emac_dma_descriptor_list_address_set(EMAC_DMA_RECEIVE, dma_rx_dscr_tab, rx_buff, EMAC_NUM_RX_BUF);
/* set emac dma tx link list */
emac_dma_descriptor_list_address_set(EMAC_DMA_TRANSMIT, dma_tx_dscr_tab, tx_buff, EMAC_NUM_TX_BUF);
/* emac interrupt init */
emac_dma_config(&dma_control_para);
emac_dma_interrupt_enable(EMAC_DMA_INTERRUPT_NORMAL_SUMMARY, TRUE);
emac_dma_interrupt_enable(EMAC_DMA_INTERRUPT_RX, TRUE);
nvic_irq_enable(EMAC_IRQn, 0x07, 0);
/* enable emac */
emac_start();
return RT_EOK;
static rt_err_t rt_at32_emac_open(rt_device_t dev, rt_uint16_t oflag)
LOG_D("emac open");
return RT_EOK;
static rt_err_t rt_at32_emac_close(rt_device_t dev)
LOG_D("emac close");
return RT_EOK;
static rt_size_t rt_at32_emac_read(rt_device_t dev, rt_off_t pos, void *buffer, rt_size_t size)
LOG_D("emac read");
rt_set_errno(-RT_ENOSYS);
return 0;
static rt_size_t rt_at32_emac_write(rt_device_t dev, rt_off_t pos, const void *buffer, rt_size_t size)
LOG_D("emac write");
return 0;
static rt_err_t rt_at32_emac_control(rt_device_t dev, int cmd, void *args)
switch (cmd)
case NIOCTL_GADDR:
/* get mac address */
if (args)
SMEMCPY(args, at32_emac_device.dev_addr, 6);
else
return -RT_ERROR;
break;
default :
break;
return RT_EOK;
* @brief transmit data
rt_err_t rt_at32_emac_tx(rt_device_t dev, struct pbuf *p)
struct pbuf *q;
rt_uint32_t offset;
while ((dma_tx_desc_to_set->status & EMAC_DMATXDESC_OWN) != RESET)
rt_err_t result;
rt_uint32_t level;
level = rt_hw_interrupt_disable();
tx_is_waiting = RT_TRUE;
rt_hw_interrupt_enable(level);
/* it's own bit set, wait it */
result = rt_sem_take(&tx_wait, RT_WAITING_FOREVER);
if (result == RT_EOK) break;
if (result == -RT_ERROR) return -RT_ERROR;
offset = 0;
for (q = p; q != NULL; q = q->next)
uint8_t *buffer;
/* copy the frame to be sent into memory pointed by the current ethernet dma tx descriptor */
buffer = (uint8_t*)((dma_tx_desc_to_set->buf1addr) + offset);
SMEMCPY(buffer, q->payload, q->len);
offset += q->len;
#ifdef EMAC_TX_DUMP
dump_hex(p->payload, p->tot_len);
#endif
/* prepare transmit descriptors to give to dma */
LOG_D("transmit frame length :%d", p->tot_len);
/* setting the frame length: bits */
dma_tx_desc_to_set->controlsize = (p->tot_len & EMAC_DMATXDESC_TBS1);
/* Setting the last segment and first segment bits (in this case a frame is transmitted in one descriptor) */
dma_tx_desc_to_set->status |= EMAC_DMATXDESC_LS | EMAC_DMATXDESC_FS;
/* enable tx completion interrupt */
dma_tx_desc_to_set->status |= EMAC_DMATXDESC_IC;
/* set own bit of the tx descriptor status: gives the buffer back to ethernet dma */
dma_tx_desc_to_set->status |= EMAC_DMATXDESC_OWN;
/* When Tx Buffer unavailable flag is set: clear it and resume transmission */
if(emac_dma_flag_get(EMAC_DMA_TBU_FLAG) != RESET)
emac_dma_flag_clear(EMAC_DMA_TBU_FLAG);
emac_dma_poll_demand_set(EMAC_DMA_TRANSMIT, 0);
/* selects the next dma tx descriptor list for next buffer to send */
dma_tx_desc_to_set = (emac_dma_desc_type*) (dma_tx_desc_to_set->buf2nextdescaddr);
return ERR_OK;
* @brief receive data
struct pbuf *rt_at32_emac_rx(rt_device_t dev)
struct pbuf *p = NULL;
struct pbuf *q = NULL;
rt_uint32_t offset = 0;
uint16_t len = 0;
uint8_t *buffer;
/* get received frame */
len = emac_received_packet_size_get();
if(len > 0)
LOG_D("receive frame len : %d", len);
/* we allocate a pbuf chain of pbufs from the lwip buffer pool */
p = pbuf_alloc(PBUF_RAW, len, PBUF_POOL);
if(p != NULL)
for (q = p; q != RT_NULL; q= q->next)
/* get rx buffer */
buffer = (uint8_t *)(dma_rx_desc_to_get->buf1addr);
#ifdef EMAC_RX_DUMP
dump_hex(buffer, len);
#endif
/* copy the received frame into buffer from memory pointed by the current ethernet dma rx descriptor */
SMEMCPY(q->payload, (buffer + offset), q->len);
offset += q->len;
else
return p;
/* release descriptors to dma */
dma_rx_desc_to_get->status |= EMAC_DMARXDESC_OWN;
/* when rx buffer unavailable flag is set: clear it and resume reception */
if(emac_dma_flag_get(EMAC_DMA_RBU_FLAG) != RESET)
/* clear rbu ethernet dma flag */
emac_dma_flag_clear(EMAC_DMA_RBU_FLAG);
/* resume dma reception */
emac_dma_poll_demand_set(EMAC_DMA_RECEIVE, 0);
/* update the ethernet dma global rx descriptor with next rx decriptor */
/* chained mode */
if((dma_rx_desc_to_get->controlsize & EMAC_DMARXDESC_RCH) != RESET)
/* selects the next dma rx descriptor list for next buffer to read */
dma_rx_desc_to_get = (emac_dma_desc_type*) (dma_rx_desc_to_get->buf2nextdescaddr);
/* ring mode */
else
if((dma_rx_desc_to_get->controlsize & EMAC_DMARXDESC_RER) != RESET)
/* selects the first dma rx descriptor for next buffer to read: last rx descriptor was used */
dma_rx_desc_to_get = (emac_dma_desc_type*) (EMAC_DMA->rdladdr);
else
dma_rx_desc_to_get = (emac_dma_desc_type*) ((uint32_t)dma_rx_desc_to_get + 0x10 + ((EMAC_DMA->bm & 0x0000007C) >> 2));
return p;
void EMAC_IRQHandler(void)
/* enter interrupt */
rt_interrupt_enter();
/* clear received it */
if(emac_dma_flag_get(EMAC_DMA_NIS_FLAG) != RESET)
emac_dma_flag_clear(EMAC_DMA_NIS_FLAG);
if(emac_dma_flag_get(EMAC_DMA_AIS_FLAG) != RESET)
emac_dma_flag_clear(EMAC_DMA_AIS_FLAG);
if(emac_dma_flag_get(EMAC_DMA_OVF_FLAG) != RESET)
emac_dma_flag_clear(EMAC_DMA_OVF_FLAG);
/* packet receiption */
if (emac_dma_flag_get(EMAC_DMA_RI_FLAG) == SET)
/* a frame has been received */
eth_device_ready(&(at32_emac_device.parent));
emac_dma_flag_clear(EMAC_DMA_RI_FLAG);
/* packet transmission */
if (emac_dma_flag_get(EMAC_DMA_TI_FLAG) == SET)
if (tx_is_waiting == RT_TRUE)
rt_sem_release(&tx_wait);
emac_dma_flag_clear(EMAC_DMA_TI_FLAG);
/* leave interrupt */
rt_interrupt_leave();
enum {
PHY_LINK = (1 << 0),
PHY_10M = (1 << 1),
PHY_FULLDUPLEX= (1 << 2),
static void phy_linkchange()
static rt_uint8_t phy_speed = 0;
rt_uint8_t phy_speed_new = 0;
rt_uint16_t status;
emac_phy_register_read(phy_addr, PHY_BASIC_STATUS_REG, (uint16_t *)&status);
LOG_D("phy basic status reg is 0x%X", status);
if (status & (PHY_AUTONEGO_COMPLETE_MASK | PHY_LINKED_STATUS_MASK))
rt_uint16_t SR = 0;
phy_speed_new |= PHY_LINK;
emac_phy_register_read(phy_addr, PHY_SPECIFIED_CS_REG, (uint16_t *)&SR);
LOG_D("phy control status reg is 0x%X", SR);
if (SR & (PHY_SPEED_MODE))
phy_speed_new |= PHY_10M;
if (SR & (PHY_DUPLEX_MODE))
phy_speed_new |= PHY_FULLDUPLEX;
if (phy_speed != phy_speed_new)
phy_speed = phy_speed_new;
if (phy_speed & PHY_LINK)
LOG_D("link up");
if (phy_speed & PHY_10M)
LOG_D("10Mbps");
at32_emac_device.emac_speed = EMAC_SPEED_10MBPS;
else
at32_emac_device.emac_speed = EMAC_SPEED_100MBPS;
LOG_D("100Mbps");
if (phy_speed & PHY_FULLDUPLEX)
LOG_D("full-duplex");
at32_emac_device.emac_mode = EMAC_FULL_DUPLEX;
else
LOG_D("half-duplex");
at32_emac_device.emac_mode = EMAC_HALF_DUPLEX;
/* send link up. */
eth_device_linkchange(&at32_emac_device.parent, RT_TRUE);
else
LOG_I("link down");
eth_device_linkchange(&at32_emac_device.parent, RT_FALSE);
#ifdef PHY_USING_INTERRUPT_MODE
static void emac_phy_isr(void *args)
rt_uint32_t status = 0;
emac_phy_register_read(phy_addr, PHY_INTERRUPT_FLAG_REG, (uint16_t *)&status);
LOG_D("phy interrupt status reg is 0x%X", status);
phy_linkchange();
#endif /* PHY_USING_INTERRUPT_MODE */
static void phy_monitor_thread_entry(void *parameter)
uint8_t detected_count = 0;
/* phy search */
rt_uint32_t i, temp;
for (i = 0; i <= 0x1F; i++)
emac_phy_register_read(i, PHY_BASIC_STATUS_REG, (uint16_t *)&temp);
if (temp != 0xFFFF && temp != 0x00)
phy_addr = i;
break;
detected_count++;
if (detected_count > 10)
LOG_E("No PHY device was detected, please check hardware!");
LOG_D("Found a phy, address:0x%02X", phy_addr);
/* reset phy */
LOG_D("RESET PHY!");
emac_phy_register_write(phy_addr, PHY_BASIC_CONTROL_REG, PHY_RESET_MASK);
emac_phy_register_write(phy_addr, PHY_BASIC_CONTROL_REG, PHY_AUTO_NEGOTIATION_MASK);
phy_linkchange();
/* configuration intterrupt pin */
rt_pin_mode(PHY_INT_PIN, PIN_MODE_INPUT_PULLUP);
rt_pin_attach_irq(PHY_INT_PIN, PIN_IRQ_MODE_FALLING, emac_phy_isr, (void *)"callbackargs");
rt_pin_irq_enable(PHY_INT_PIN, PIN_IRQ_ENABLE);
/* enable phy interrupt */
emac_phy_register_write(phy_addr, PHY_INTERRUPT_MASK_REG, PHY_INT_MASK);
#if defined(PHY_INTERRUPT_CTRL_REG)
emac_phy_register_write(phy_addr, PHY_INTERRUPT_CTRL_REG, PHY_INTERRUPT_EN);
#endif
#else /* PHY_USING_INTERRUPT_MODE */
at32_emac_device.poll_link_timer = rt_timer_create("phylnk", (void (*)(void*))phy_linkchange,
NULL, RT_TICK_PER_SECOND, RT_TIMER_FLAG_PERIODIC);
if (!at32_emac_device.poll_link_timer || rt_timer_start(at32_emac_device.poll_link_timer) != RT_EOK)
LOG_E("Start link change detection timer failed");
extern void phy_reset(void);
/* Register the EMAC device */
static int rt_hw_at32_emac_init(void)
rt_err_t state = RT_EOK;
/* Prepare receive and send buffers */
rx_buff = (rt_uint8_t *)rt_calloc(EMAC_NUM_RX_BUF, EMAC_MAX_PACKET_LENGTH);
if (rx_buff == RT_NULL)
LOG_E("No memory");
state = -RT_ENOMEM;
goto __exit;
tx_buff = (rt_uint8_t *)rt_calloc(EMAC_NUM_TX_BUF, EMAC_MAX_PACKET_LENGTH);
if (tx_buff == RT_NULL)
LOG_E("No memory");
state = -RT_ENOMEM;
goto __exit;
dma_rx_dscr_tab = (emac_dma_desc_type *)rt_calloc(EMAC_NUM_RX_BUF, sizeof(emac_dma_desc_type));
if (dma_rx_dscr_tab == RT_NULL)
LOG_E("No memory");
state = -RT_ENOMEM;
goto __exit;
dma_tx_dscr_tab = (emac_dma_desc_type *)rt_calloc(EMAC_NUM_TX_BUF, sizeof(emac_dma_desc_type));
if (dma_tx_dscr_tab == RT_NULL)
LOG_E("No memory");
state = -RT_ENOMEM;
goto __exit;
// /* phy clock */
// phy_clock_config();
/* enable periph clock */
crm_periph_clock_enable(CRM_EMAC_PERIPH_CLOCK, TRUE);
crm_periph_clock_enable(CRM_EMACTX_PERIPH_CLOCK, TRUE);
crm_periph_clock_enable(CRM_EMACRX_PERIPH_CLOCK, TRUE);
/* interface mode */
gpio_pin_remap_config(MII_RMII_SEL_GMUX, TRUE);
#endif
scfg_emac_interface_set(SCFG_EMAC_SELECT_RMII);
#endif
/* emac gpio init */
at32_msp_emac_init(NULL);
at32_emac_device.emac_mode= EMAC_FULL_DUPLEX;
at32_emac_device.dev_addr = 0x00;
at32_emac_device.dev_addr = 0x66;
at32_emac_device.dev_addr = 0x88;
/* generate mac addr from unique id (only for test). */
at32_emac_device.dev_addr = *(rt_uint8_t *)(0x1FFFF7E8 + 4);
at32_emac_device.dev_addr = *(rt_uint8_t *)(0x1FFFF7E8 + 2);
at32_emac_device.dev_addr = *(rt_uint8_t *)(0x1FFFF7E8 + 0);
at32_emac_device.parent.parent.init = rt_at32_emac_init;
at32_emac_device.parent.parent.open = rt_at32_emac_open;
at32_emac_device.parent.parent.close = rt_at32_emac_close;
at32_emac_device.parent.parent.read = rt_at32_emac_read;
at32_emac_device.parent.parent.write = rt_at32_emac_write;
at32_emac_device.parent.parent.control = rt_at32_emac_control;
at32_emac_device.parent.parent.user_data = RT_NULL;
at32_emac_device.parent.eth_rx = rt_at32_emac_rx;
at32_emac_device.parent.eth_tx = rt_at32_emac_tx;
/* reset phy */
phy_reset();
/* start phy monitor */
rt_thread_t tid;
tid = rt_thread_create("phy",
phy_monitor_thread_entry,
RT_NULL,
1024,
RT_THREAD_PRIORITY_MAX - 2,
2);
if (tid != RT_NULL)
rt_thread_startup(tid);
else
state = -RT_ERROR;
/* register eth device */
state = eth_device_init(&(at32_emac_device.parent), "e0");
if (RT_EOK == state)
LOG_D("emac device init success");
else
LOG_E("emac device init faild: %d", state);
state = -RT_ERROR;
goto __exit;
__exit:
if (state != RT_EOK)
if (rx_buff)
rt_free(rx_buff);
if (tx_buff)
rt_free(tx_buff);
if (dma_rx_dscr_tab)
rt_free(dma_rx_dscr_tab);
if (dma_tx_dscr_tab)
rt_free(dma_tx_dscr_tab);
return state;
INIT_DEVICE_EXPORT(rt_hw_at32_emac_init);
雅特力的例程
我没有找到lan8720a 的例程,楼主方便提供下不
如附件,示例代码演示AT32F407/437 EMAC接不同PHY配置方法使用方法。如下型号PHY已打通
DM9162DP83848C
LAN8720A
AR8032
IP101GR
RTL8201F
YT8512
IP175LL
IP179N
页:
[1]
