wanduzi 发表于 2022-6-23 10:57
发现一个开发51很给力的软件,开源免费
哈哈,比用Keil好用,软件比较小,编译速度快。
wanduzi 发表于 2022-6-23 10:58
* Very very simple demonstration code written in C language
* @file demo_c_0.c
// This file defines registers available in AT89x51 MCUs
// See /usr/share/sdcc/include/mcs51/ for alternatives
#include <at89x51.h>
unsigned long some_variable=0;        ///< Documentation for this variable comes here
int i;                                ///< General purpose interator
* These lines are a doxygen documentation for this function
* See doxygen manual for more details (http://www.stack.nl/~dimitri/doxygen/manual.html)
* Note: Try to click on the 1st line of the function declaration and then press Ctrl+E
* <b style="color: #FF0000">Some bold text</b>
* @param somevalue Some agrument
void someFunction(unsigned char somevalue)
        // P1 and P3 are variables defined in "at89x51.h"
        P1=somevalue;
        P3=somevalue^0xFF;
/** Main loop */
int main()
        // Infinite loop
        while(1) {
                for(i=0; i<255; i++) {
                        someFunction(i+2);
                        some_variable++;
                some_variable-=22;
        // Report success
        return 0;
void delay(unsigned int x)
        while(x--);
void main(void)
int i=0;
        while(1)
                P0=~(1<<i);
                delay(10000);
                i++;
                if(i==8) i=0;
烧录使用
WoodData 发表于 2022-6-23 17:02
软件在哪?
页: [1]
查看完整版本: 发现一个开发51很给力的软件,开源免费
