加载LCC驱动失败
3282|20
 楼主| zwll 发表于 2022-7-5 21:52 | 显示全部楼层 |阅读模式
测试新建项目时候,GFX Core 选择显示驱动时候,加载LCC驱动失败
zhanghqi 发表于 2022-7-5 21:55 | 显示全部楼层
楼主详细说说怎么回事啊,这么说太笼统了
 楼主| zwll 发表于 2022-7-5 22:00 | 显示全部楼层
软件平台: XIDE 5  +  H3
硬件平台: PIC32MZ2048EFM144   EF START kit  +多媒体版MEB2
 楼主| zwll 发表于 2022-7-5 22:02 | 显示全部楼层
使用新的PDA TB4301 WQVGA LCD和MXT336触摸控制器
dingy 发表于 2022-7-5 22:03 | 显示全部楼层
还有什么现象?能再详细描述下吗?
renyaq 发表于 2022-7-5 22:05 | 显示全部楼层
信息如下
<Configuration Database>[Error]: Failed to activate component: gfx_driver_lcc
<Log>[Error]: Exception cause: Traceback (most recent call last):
  File "E:\microchip\H3\gfx\driver\controller\lcc\config/lcc_controller.py", line 249, in instantiateComponent
    autoSelectDMAChannel(DMAChannelSelected, DMAChannel, OldDMAChannel)
  File "E:\microchip\H3\gfx\driver\controller\lcc\config/lcc_controller.py", line 254, in autoSelectDMAChannel
    enabled = Database.getComponentByID("core").getSymbolByID("XDMAC_CH" + str(channel) + "_ENABLE").getValue();
        at com.microchip.h3.database.scriptinterface.component.ComponentRemoteSymbolInterface.getSymbolByID(ComponentRemoteSymbolInterface.java:22)
        at sun.reflect.GeneratedMethodAccessor372.invoke(Unknown Source)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
        at java.lang.reflect.Method.invoke(Method.java:498)
wangzsa 发表于 2022-7-5 22:07 | 显示全部楼层
32MZEFM图形驱动在H2时候支持LCC,到H3版本不支持了吗?
 楼主| zwll 发表于 2022-7-5 22:10 | 显示全部楼层
对于 EF START kit  +多媒体版MEB2硬件平台+H3,对应PDA TB4301 WQVGA LCD 如何设置显示驱动?
tian111 发表于 2022-7-5 22:13 | 显示全部楼层
配置连线框右侧,对TM4302B进行配置时,配置选项中选择LCC
 楼主| zwll 发表于 2022-7-5 22:15 | 显示全部楼层
也会有以下信息:
<Harmony Database>[Info]: bsp list ['BSP_SAM_E70_Xplained_Ultra', 'BSP_SAM_A5D2_Xplained_Ultra', 'BSP_SAM_E54_Curiosity_Ultra', 'BSP_PIC32MZ_DA_Starter_Kit']
<Harmony Database>[Info]: component list [gfx_hal, sys_input, aria_gfx_pda_tm4301b, core, BSP_PIC32MZ_EF_Starter_Kit, dfp, gfx_disp_pdatm4301b_480x272, aria_gfx_library, gfx_maxtouch_controller, HarmonyCore]
<Harmony Database>[Info]: Configuring for LCC Interface.
<Harmony Database>[Info]: No BSP used, will not configure
pengf 发表于 2022-7-5 22:17 | 显示全部楼层
是否意味着当前H3, 对于 EF START KIT 的BSP 还不支持LCC ?
 楼主| zwll 发表于 2022-7-5 22:21 | 显示全部楼层
对于当前配置,有什么好的解决办法
wyjie 发表于 2022-7-5 22:23 | 显示全部楼层
32的没玩过。
stly 发表于 2022-7-5 22:27 | 显示全部楼层
才测试一下gfx_apps目录下现有的projects,看看啥情况!
https://github.com/Microchip-MPLAB-Harmony/gfx_apps
 楼主| zwll 发表于 2022-7-5 22:29 | 显示全部楼层
H3下,apps 中实例多为 MZ DA系列芯片,和其他系列。框图链接配置方式比树状表体验好多。
juventus9554 发表于 2022-7-5 22:32 | 显示全部楼层
还没有接触过这个型号的
xxrs 发表于 2022-7-5 22:34 | 显示全部楼层
帮楼主顶一下吧
 楼主| zwll 发表于 2022-7-5 22:37 | 显示全部楼层
没继续研究,X IDE用回4.05,MH版本 2.06.
tpgf 发表于 2022-8-2 12:00 | 显示全部楼层
会不会是软硬件平台不匹配啊
gwsan 发表于 2022-8-2 12:12 | 显示全部楼层
软件平台和硬件平台是匹配的吗
