LT8911EXB/高性能EVB_MIPI2EDP/分辨率1080P@60/低成本
LT8911EXB1. General Description
The Lontium LT8911EXB MIPI®DSI/CSI to eDP converter features a single-port MIPI receiver with 1 clock lane and 4 data lanes operating at maximum 2.0Gbps per data lane; a maximum input bandwidth of 8.0Gbps. The converter decodes the input MIPI® DSI 16/18/24/30/36-bit RGB packets and converts the formatted video data stream to a single-link VESA eDP1.4 compliant output with 1/2/4configurable data lanes, supporting RBR(1.62Gbps) and HBR(2.7Gbps) link speeds. The build-in optional SSC function reduces EMI effect on EMI-concerned system application.
2. Features
• Single-Port MIPI® DSI Receiver
• eDP1.4 Transmitter
• Miscellaneous
3.APPLICATIONS
• Mobile systems
• Cellular handsets
• Digital video cameras
• Digital still cameras
• Personal media players
• Gaming
LontiumLT9711 QFN-76双端口MIPI / LVDS到eDP / DP1.2
LontiumLT8718 QFN-88RGB(TTL)至eDP / DP1.2
LontiumLT9721 QFN-64单端口MIPI DSI至eDP / DP1.2
LontiumLT87101 QFN-40DP / eDP中继器,最高5.4Gb / s
LontiumLT87101DC QFN-40DP / eDP到C型转换器
LontiumLT86101CH QFN-40C型到DP / eDP转换器
LontiumLT8712X QFN-76具有音频的Type-C / DP1.2至HDMI2.0和VGA转换器
LontiumLT8711V QFN-48C型转VGA音频,支持PD控制器/快速充电/带有2 CC,QFN48,6x6的广告牌
LontiumLT8711HE QFN-64C型转HDMI 2.0,支持PD控制器/快速充电/广告牌/带有2 CC,QFN48、7.5x7.5的U2开关
LontiumLT8711EH-C QFN-64C型(DP)到带有CC的HDMI 2.0转换器,分辨率高达4Kx2K,60HzLontiumLT7911D QFN-64Type-C转2端口MIPI CSI / DSI,通过音频和PD控制器支持3D
LontiumLT8711H-C QFN-64C型(DP)到带有CC的HDMI 1.4转换器
LontiumLT87101CD QFN-40C型到DP / eDP转换器
LontiumLT7911B BGA-144Type-C / DP1.2到带音频的四端口MIPI DSI / CSI
LontiumLT7911 QFN-128C / DP / eDP到4端口MIPI CSI / DSI,通过音频和PD控制器支持3D
LontiumLT7211B BGA-144具有音频的Type-C / DP1.2至四端口LVDS
LontiumLT7211 QFN-128Type C / DP / eDP至4端口LVDS,支持3D音频和PD控制器
LontiumLT8712EXC QFN-88Type-C / DP转HDMI 2.0和VGA和音频,支持MST,带有2*CC的PD控制器,符合HDCPLontiumLT8712 LQFP-128Type-C / DP转2 HDMI1.4输出和1 VGA输出带音频,支持MST
LontiumLT8711 QFN-64双模式DP-VGA转换器,符合HDMI 1.4规格,支持IIS 2通道或SPDIF音频输出
LontiumLT8611SXD QFN-32双模DP到HDMI 1.4转换器,QFN32,3x6
LontiumLT8611SXA/B/C QFN-48/40双模DP到HDMI 1.4转换器,QFN40,5x5
LontiumLT86101X QFN-40HDMI1.4 / 2.0重新驱动器和DP ++至HDMI电平转换器
LontiumLT7211D QFN-64Type-C转2端口LVDS,通过音频和PD控制器支持3D
LontiumLT9211 QFN-64MIPI/2-Port LVDS Transimitter
LontiumLT6911UXC QFN-64HDMI2.0 to Dual-Port MIPI DSI/CSI with Audio
LontiumLT6911UX QFN-128HDMI2.0 to Quad-Port MIPI DSI/CSI with Audio
LontiumLT7911D QFN-64Type-C to 2 port MIPI CSI/DSI, support 3D with Audio and PD Controller
LontiumLT6911 QFN-128HDMI 1.4 to 4 port MIPI DSI/CSI
LontiumLT7911B BGA-144Type-C/DP1.2 to Quad-port MIPI DSI/CSI with Audio
LontiumLT7911 QFN-128Type C /DP/eDP to 4 port MIPI CSI/DSI, support 3D with Audio and PD Controller
LontiumLT7211B BGA-144Type-C/DP1.2 to Quad-port LVDS with Audio
LontiumLT7211 QFN-128Type C /DP/eDP to 4 port LVDS, support 3D with Audio and PD Controller
LontiumLT6911C QFN-64HDMI 1.4 to 2 port MIPI DSI/CSI
LontiumLT8918L QFN-64Dual-Port LVDS to MIPI DSI/CSI-2 Bridge
LontiumLT8918 QFN-64MIPI DSI/CSI-2 TransmitterLontiumLT6911B BGA-144HDMI 1.4 to 4 port MIPI DSI/CSI
LontiumLT89101 QFN-64/BGA-81MIPI DSI/CSI, LVDS Repeater
LontiumLT89101L QFN-64MIPI-to-LVDS Level Shifter
LontiumLT8911EXB QFN-48MIPI® DSI/CSI Bridge to eDP
LontiumLT8911EX QFN-64Dual-Port LVDS Bridge to eDP
LontiumLT8912B QFN-64Single-Channel MIPI DSI Bridge to LVDS/HDMI
LontiumLT8668EX LQFP-128LCD控制器,支持HDMI1.4 / DP ++和VGA输入,四通道LVDS输出,分辨率高达4Kx2K,30Hz或1080P,120Hz支持音频PCM输入和PCM,I2S,SPDIF输出。
LontiumLT9211R QFN-128具有旋转功能的双端口LVDS到MIPI转换器
LontiumLT2911R-D QFN-76具有帧率转换和旋转功能的MIPI / TTL / 2端口LVDS到MIPI / TTL / 2端口LVDS转换器LontiumLT2911R QFN-128具有旋转功能的双端口LVDS到MIPI转换器....等等,更多其它型号,欢迎您咨询!
好的方案,好的分享。支持下。 有没有能支持7K的EDP桥接芯片方案呀,前端用FPGA模拟的MIPI接口,需要驱动一个7K的EDP接口屏
页:
[1]
