[APM32F0] DMA_ADC多通道采集数据如何获取?
1928|17
 楼主| skylinyk 发表于 2022-7-26 23:27 | 显示全部楼层 |阅读模式
官网例程都是单通道,有没有大神有做过多通道的可以指教一下,目前想用ADC8--PB0,ADC9--PB1两个ADC进行双通道采样,例如在DMA-ADC例程内如何设置?
* @file        main.c
* @brief       Main program body
* @version     V1.0.1
* @date        2021-07-01
* @attention
*  Copyright (C) 2020-2022 Geehy Semiconductor
*  You may not use this file except in compliance with the
*  GEEHY COPYRIGHT NOTICE (GEEHY SOFTWARE PACKAGE LICENSE).
*  The program is only for reference, which is distributed in the hope
*  that it will be usefull and instructional for customers to develop
*  their software. Unless required by applicable law or agreed to in
*  writing, the program is distributed on an "AS IS" BASIS, WITHOUT
*  ANY WARRANTY OR CONDITIONS OF ANY KIND, either express or implied.
*  See the GEEHY SOFTWARE PACKAGE LICENSE for the governing permissions
*  and limitations under the License.
#include "Board.h"
#include "stdio.h"
#include "apm32f0xx_gpio.h"
#include "apm32f0xx_misc.h"
#include "apm32f0xx_dma.h"
#include "apm32f0xx_adc.h"
/** printf function configs to USART2*/
#define DEBUG_USART  USART1
/** define Tramismit Buf Size*/
#define BufSize 0x100
/** Delay */
void Delay(void);
/** ADC Init */
void APM_MINI_ADC_Init(void);
/** DMA Init */
void APM_MINI_DMA_Init(uint32_t* Buf);
* @param       None
* @retval      None
* @note
int main(void)
     /** DMA value from ADC*/
    uint32_t DMA_ConvertedValue = 0;
     /** ADC convert to volatage*/
    float    ADC_ConvertedValue = 0;
    APM_MINI_LEDInit(LED2);
    APM_MINI_LEDInit(LED3);
    APM_MINI_COMInit(COM1);
    APM_MINI_ADC_Init();
    APM_MINI_DMA_Init(&DMA_ConvertedValue);
    /** start conversion*/
    while(!ADC_ReadStatusFlag(ADC_FLAG_ADRDY));
    ADC_StartConversion();
    for(;;)
         /** convert value*/
        ADC_ConvertedValue = (float)DMA_ConvertedValue/4096*3.3;
        printf("\r\n  AD value = 0x%04X \r\n", DMA_ConvertedValue);
        printf("\r\n  AD value = %f V \r\n"  ,ADC_ConvertedValue);
        Delay();
* @brief       DMA_ADC Init
* @param       None
* @retval      None
* @note
void APM_MINI_ADC_Init()
    GPIO_Config_T gpioConfig;
    ADC_Config_T  adcConfig;
    /** RCM Enable*/
    RCM_EnableAHBPeriphClock(RCM_AHB_PERIPH_GPIOB);
    RCM_EnableAPB2PeriphClock(RCM_APB2_PERIPH_ADC1);
    RCM_EnableAPB2PeriphClock(RCM_APB2_PERIPH_SYSCFG);
    /** GPIO Configuration */
    gpioConfig.pin = GPIO_PIN_0;
    gpioConfig.mode = GPIO_MODE_AN;
    gpioConfig.pupd = GPIO_PUPD_PU;
    GPIO_Config(GPIOB, &gpioConfig);
    /** ADC Configuration */
    ADC_Reset();
    ADC_ConfigStructInit(&adcConfig);
    /** Set resolution*/
    adcConfig.resolution = ADC_RESOLUTION_12B;
    /** Set dataAlign*/
    adcConfig.dataAlign = ADC_DATA_ALIGN_RIGHT;
    /** Set scanDir*/
    adcConfig.scanDir = ADC_SCAN_DIR_UPWARD;
    /** Set convMode continous*/
    adcConfig.convMode = ADC_CONVERSION_CONTINUOUS;
    /** Set extTrigConv*/
    adcConfig.extTrigConv = ADC_EXT_TRIG_CONV_TRG0;
    /** Set TrigEdge*/
    adcConfig.extTrigEdge = ADC_EXT_TRIG_EDGE_NONE;
    ADC_Config(&adcConfig);
    ADC_ConfigChannel(ADC_CHANNEL_8, ADC_SAMPLE_TIME_239_5 );
    /** Calibration*/
    ADC_ReadCalibrationFactor();
    ADC_EnableDMA();
    /** Enable ADC*/
    ADC_Enable();
* @brief       DMA Init
* @param       None
* @retval      None
* @note
    /** Enable DMA clock */
    RCM_EnableAHBPeriphClock(RCM_AHB_PERIPH_DMA1);
    /** DMA Configure */
    DMA_Config_T dmaConfig;
    /** size of buffer*/
    dmaConfig.bufferSize = 1;
    /** set memory Data Size*/
    dmaConfig.memoryDataSize = DMA_MEMORY_DATASIZE_HALFWORD;
    /** Set peripheral Data Size*/
    dmaConfig.peripheralDataSize = DMA_PERIPHERAL_DATASIZE_HALFWORD;
    /** Enable Memory Address increase*/
    dmaConfig.memoryInc = DMA_MEMORY_INC_DISABLE;
    /** Disable Peripheral Address increase*/
    dmaConfig.peripheralInc = DMA_PERIPHERAL_INC_DISABLE;
    /** Reset Circular Mode*/
    dmaConfig.circular = DMA_CIRCULAR_ENABLE;
    /** Disable M2M*/
    dmaConfig.memoryTomemory = DMA_M2M_DISABLE;
    /** set priority*/
    dmaConfig.priority = DMA_PRIORITY_LEVEL_HIGHT;
    /** read from peripheral*/
    dmaConfig.direction = DMA_DIR_PERIPHERAL;
    /** Set memory Address*/
    dmaConfig.memoryAddress = (uint32_t)Buf;
    /** Set Peripheral Address*/
    dmaConfig.peripheralAddress = (uint32_t)&ADC->DATA;
    DMA_Config(DMA1_CHANNEL_1,&dmaConfig);
    /** Clear DMA TF flag*/
    DMA_ClearIntFlag(DMA1_INT_FLAG_TF1);
    /** Enable DMA Interrupt*/
    DMA_EnableInterrupt(DMA1_CHANNEL_1,DMA_INT_TFIE);
    NVIC_EnableIRQRequest(DMA1_CH1_IRQn,2);
    DMA_Enable(DMA1_CHANNEL_1);
* @brief       DMA_Interrupt
* @param       None
* @retval      None
* @NOTE        This function need to put into DMA1_CH1_IRQHandler in apm32f0xx_int.c
void DMA_Isr(void)
    if(DMA_ReadStatusFlag(DMA1_FLAG_TF1))
        /** do something*/
        DMA_ClearStatusFlag(DMA1_FLAG_TF1);
* @brief       Delay
* @param       None
* @retval      None
* @note
void Delay(void)
    volatile uint32_t delay = 0xFFFFF;
    while(delay--);
* @brief       Redirect C Library function printf to serial port.
*              After Redirection, you can use printf function.
* @param       ch:  The characters that need to be send.
* @param       *f:  pointer to a FILE that can recording all information
*              needed to control a stream
* @retval      The characters that need to be send.
* @note
int fputc(int ch, FILE *f)
        /** send a byte of data to the serial port */
        USART_TxData(DEBUG_USART,(uint8_t)ch);
        /** wait for the data to be send  */
        while (USART_ReadStatusFlag(DEBUG_USART, USART_FLAG_TXBE) == RESET);
        return (ch);
Fanexs168 发表于 2022-7-27 10:16 | 显示全部楼层
最新版F0xx SDK里,DMA例程目录那有配套ADC使用的例程。可以再看看
Fanexs168 发表于 2022-7-27 11:25 | 显示全部楼层
或者参考下我这个例程配置。多通道ADC+DMA+TMR硬件定时器触发,能用的都用了。
文件放到SDK的ADC例程文件夹下解压缩编译使用
ADC_TMRTrigger_DMA.rar
30.09 KB, 下载次数: 21
 楼主| skylinyk 发表于 2022-7-27 19:25 | 显示全部楼层
文件放到SDK的ADC例程文件夹 ...
非常感谢!感激之情无以言表,我下来看看
lajfda001 发表于 2022-8-16 10:24 | 显示全部楼层
非常感谢楼主的分享。谢谢。
lajdfla001 发表于 2022-8-16 10:27 | 显示全部楼层
感谢二楼的分享,不错的例程。
udaidfa002 发表于 2022-8-16 11:05 | 显示全部楼层
感谢分享。不错的资料。。。。
lzbf 发表于 2022-8-16 20:16 | 显示全部楼层
直接配置寄存器和数组就行。
kkzz 发表于 2022-8-16 20:38 | 显示全部楼层
你需要采集几路数据呢
pklong 发表于 2022-8-17 15:52 | 显示全部楼层
dma直接转换的
houjiakai 发表于 2022-8-20 13:01 | 显示全部楼层
感觉DMA好用很多,ADC不需要考虑问题。
linfelix 发表于 2022-8-20 19:29 | 显示全部楼层
最大的转换速度是多少?
saservice 发表于 2022-8-20 21:01 | 显示全部楼层
DMA_ADC多通道采集会有信号之间的干扰吗
robertesth 发表于 2022-8-21 20:27 | 显示全部楼层
这个有什么问题吗
BDW杜兰特 发表于 2022-9-5 10:15 | 显示全部楼层
感谢楼主分享
AloneKaven 发表于 2022-11-4 21:40 | 显示全部楼层
直接配置寄存器和数组就行
Undshing 发表于 2023-1-3 16:07 | 显示全部楼层
最大的转换速度是多少?
