meiyaolei 发表于 2022-8-8 14:51
【N32G430开发板试用】+点数码管+ADC
@安小芯
感谢论坛给与测评机会,得到板块爱不释手。感谢论坛袁大神的指导file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image001.gif
1.下面我先上原理图:原计划使用原理图:
2.核心板与功能板飞线,理解一下,为什么要档住相关的。3.功能:结果只用了串口,ADC,数码管,灯,按键;点亮LED,按健控制数码管显示,串口打印相关的值(ADC)和固定的字,定时器。4.上一个才艺:a:点亮LED说明功能跑起来了。
#define LED1_GPIO_PORT   GPIOA                      #define LED1_GPIO_CLK      RCC_AHB_PERIPH_GPIOA#define LED1_GPIO_PIN         GPIO_PIN_1
#define LED2_GPIO_PORT   GPIOA                     #define LED2_GPIO_CLK      RCC_AHB_PERIPH_GPIOA#define LED2_GPIO_PIN         GPIO_PIN_7
#define LED1_ON                {LED1_GPIO_PORT->PBSC =LED1_GPIO_PIN;}   #define LED2_ON                {LED2_GPIO_PORT->PBSC = LED2_GPIO_PIN;}
LED_Initialize(LED1_GPIO_PORT,LED1_GPIO_PIN | LED2_GPIO_PIN );//GPIOA
LED1_ON;LED2_ON;
b:定时器6使LED2闪烁      TIM_TimeBaseInitTypeTIM_TimeBaseStructure;//      NVIC_InitTypeNVIC_InitStructure;//
      RCC_Pclk1_Config(RCC_HCLK_DIV4);//APB14分频 得到Pclk1为32MHz      RCC_APB1_Peripheral_Clock_Enable(RCC_APB1_PERIPH_TIM6);//使能Timer6的时钟
NVIC_InitStructure.NVIC_IRQChannel = TIM6_IRQn;      NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority= 2;      NVIC_InitStructure.NVIC_IRQChannelSubPriority= 0;      NVIC_InitStructure.NVIC_IRQChannelCmd= ENABLE;      NVIC_Initializes(&NVIC_InitStructure);
      TIM_Base_Struct_Initialize(&TIM_TimeBaseStructure);      TIM_TimeBaseStructure.Period   = period;//周期      TIM_TimeBaseStructure.Prescaler= prescaler;//预分频      TIM_TimeBaseStructure.ClkDiv   = 0;      TIM_TimeBaseStructure.CntMode= TIM_CNT_MODE_UP;//向上计数      TIM_Base_Initialize(TIM6,&TIM_TimeBaseStructure);
      TIM_Base_Reload_Mode_Set(TIM6,TIM_PSC_RELOAD_MODE_IMMEDIATE);//立即重装载
      TIM_Interrupt_Enable(TIM6,TIM_INT_UPDATE);
TIM_On(TIM6);
在中断中TIM6_IRQHandlerLED2_TOGGLE;部分略过。c:串口打印
配我就不发出来了。      if(USART_Interrupt_Status_Get(USART1, USART_INT_RXDNE) != RESET)      {         /*Read one byte from the receive data register */         CH= USART_Data_Receive(USART1);         Usart1_Printf("%c",CH);         USART_Interrupt_Status_Clear(USART1,USART_INT_RXDNE);//clearUSART_INT_RXDNE flag      }d:ADC检测NTC的值
用的是PB13PB14脚。此处又略过配置ADC_Value =Get_ADC_Average(ADC_Channel_15_PB13,5);    //ADC_IN15   pcb NTCADC_Valuea =Get_ADC_Average(ADC_Channel_16_PB14,5);//ADC_IN16外部NTCe:按键控制数码亮         if(KEYi== 1){               COM0_OFF;               SEG0_OFF;SEG1_OFF;SEG2_OFF;SEG4_OFF;SEG6_OFF;               SEG3_ON;SEG5_ON;         }else         if(KEYi== 2){               COM0_OFF;               SEG5_OFF;SEG2_OFF;SEG6_OFF;               SEG3_ON;SEG4_ON;SEG1_ON;SEG0_ON;SEG6_ON;         }else         if(KEYi== 3){               COM0_OFF;               SEG0_OFF;SEG2_OFF;               SEG4_ON;SEG3_ON;SEG1_ON;SEG5_ON;SEG6_ON;         }else         if(KEYi== 4){               COM0_OFF;               SEG4_OFF;SEG6_OFF;SEG0_OFF;               SEG2_ON;SEG3_ON;SEG1_ON;SEG5_ON;         }else         if(KEYi== 5){               COM0_OFF;               SEG3_OFF;SEG0_OFF;               SEG4_ON;SEG2_ON;SEG1_ON;SEG5_ON;SEG6_ON;         }else{               SEG3_OFF;SEG0_OFF;               SEG4_OFF;SEG2_OFF;SEG1_OFF;SEG5_OFF;SEG6_OFF;         }         if(GPIO_Input_Pin_Data_Get(KEY2_PORT,KEY2_PIN) == PIN_RESET)         {               SysTick_Delay_Ms(50);               if(GPIO_Input_Pin_Data_Get(KEY2_PORT,KEY2_PIN) == PIN_RESET)               {                                KEYi++;               }               while(GPIO_Input_Pin_Data_Get(KEY2_PORT,KEY2_PIN) == PIN_RESET);         }就只弄了这些,有些配置没有上传上来,太多了,等下长篇大论了。
duo点 发表于 2022-8-8 15:42
坐等长篇大论了
袁胜富 发表于 2022-8-12 19:10
二楼
二楼
{:titter:}不要看我笑话啊
vivilyly 发表于 2022-11-1 09:38
这个使用dma+adc实现的吗
minzisc 发表于 2022-11-1 09:54
12bit最高采样速率高达4.7Msps的高精度ADC。
sanfuzi 发表于 2022-11-1 10:10
N32G430的ADC支持高达16个外部采样通道
jackcat 发表于 2022-11-1 10:36
N32G430的ADC稳定行怎么样
beacherblack 发表于 2022-11-1 11:10
N32G430系列MCU是国民技术近期推出的新品。
timfordlare 发表于 2022-11-1 11:56
支持单端模式和差分模式采样吗?
minzisc 发表于 2022-11-1 15:45
adc的触发方式是什么
AloneKaven 发表于 2022-11-4 22:18
这个使用dma+adc实现的吗
土土土 发表于 2022-11-10 11:34
楼主可以参考看看你的工程吗?
wwppd 发表于 2022-12-1 19:25
支持多少个外部采样通道?
phoenixwhite 发表于 2022-12-1 20:15
这个芯片是否兼容stm32的芯片呢?
olivem55arlowe 发表于 2022-12-1 22:08
单片机入门的首先
eefas 发表于 2022-12-2 19:58
是否有自带蓝牙或者wifi的芯片呢?
minzisc 发表于 2022-12-2 20:58
芯片自带烧录工具,非常的实用。
芯片自带烧录工具,非常的实用。
是的,很方便
是否有自带蓝牙或者wifi的芯片呢?
没有呢
页: [1] 2
查看完整版本: 【N32G430开发板试用】+点数码管+ADC
