GD32F103CBT6如何配置PB0和PB1输出PWM波?
#include "gd32f10x.h"#include "gd32f10x_libopt.h"
#include "systick.h"
void T0_init(void)
timer_oc_parameter_struct timer_ocintpara;
timer_parameter_struct timer_initpara;
rcu_periph_clock_enable(RCU_GPIOB);
rcu_periph_clock_enable(RCU_AF);
gpio_init( GPIOB, GPIO_MODE_AF_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_0);
rcu_periph_clock_enable(RCU_TIMER0);
timer_deinit(TIMER0);
/* TIMER0 configuration */
timer_initpara.prescaler =108-1;
timer_initpara.alignedmode = TIMER_COUNTER_EDGE;
timer_initpara.counterdirection= TIMER_COUNTER_UP;
timer_initpara.period = 16000-1;
timer_initpara.clockdivision = TIMER_CKDIV_DIV1;
timer_initpara.repetitioncounter = 0;
timer_init(TIMER0,&timer_initpara);
/* CH1 configuration in PWM mode1 */
timer_ocintpara.ocpolarity = TIMER_OC_POLARITY_HIGH;
timer_ocintpara.outputstate= TIMER_CCX_ENABLE;
timer_ocintpara.ocnpolarity= TIMER_OCN_POLARITY_HIGH;
timer_ocintpara.outputnstate = TIMER_CCXN_DISABLE;
timer_ocintpara.ocidlestate= TIMER_OC_IDLE_STATE_LOW;
timer_ocintpara.ocnidlestate = TIMER_OCN_IDLE_STATE_LOW;
timer_channel_output_config(TIMER0,TIMER_CH_1,&timer_ocintpara);
/* CH1 configuration in PWM mode1,duty cycle 25% */
timer_channel_output_pulse_value_config(TIMER0,TIMER_CH_1,9999);
timer_channel_output_mode_config(TIMER0,TIMER_CH_1,TIMER_OC_MODE_PWM0);
timer_channel_output_shadow_config(TIMER0,TIMER_CH_1,TIMER_OC_SHADOW_DISABLE);
timer_primary_output_config(TIMER0,ENABLE);
/* auto-reload preload enable */
timer_auto_reload_shadow_enable(TIMER0);
timer_enable(TIMER0);
int main(void)
rcu_ahb_clock_config(RCU_AHB_CKSYS_DIV1);
systick_config();
T0_init();
while(1)
页:
[1]
