CH32V307VCT6 多通道DMA
/********************************** (C) COPYRIGHT ******************************** File Name : main.c
* Author : WCH
* Version : V1.0.0
* Date : 2021/06/06
* Description : Main program body.
*@NOTE
ADC使用DMA采样例程:
ADC通道2(PA2),规则组通道通过DMA获取 ADC连续1024次转换数据。
#definelength5
#include "debug.h"
//extern u16 ADC_ConvertedValue;
u16 ADC_ConvertedValue={0,0,0};
/* Global Variable */
u16 TxBuf;
s16 Calibrattion_Val = 0;
* Function Name: ADC_Function_Init
* Description : Initializes ADC collection.
* Input : None
* Return : None
void ADC_Function_Init(void)
ADC_InitTypeDef ADC_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA |RCC_APB2Periph_ADC1 , ENABLE ); //使能GPIOA时钟和ADC
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5; //PA1~5对应ADC通道1~5
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN; //GPIO模式为模拟输入
GPIO_Init(GPIOA, &GPIO_InitStructure);
ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;//配置ADC为独立模式
ADC_InitStructure.ADC_ScanConvMode = ENABLE; //多通道模式下开启扫描模式
ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;//设置开启连续转换模式
ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None; //设置转换不是由外部触发启动,软件触发启动
ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right; //设置ADC数据右对齐
ADC_InitStructure.ADC_NbrOfChannel = length; //规则转换的ADC通道的数目
ADC_Init(ADC1, &ADC_InitStructure); //根据ADC_InitStructure中指定的参数初始化ADC1寄存器
RCC_ADCCLKConfig(RCC_PCLK2_Div6); //设置ADC时钟分频为6分频
ADC_Cmd(ADC1, ENABLE); //使能ADC1
ADC_ResetCalibration(ADC1); //重置ADC1校准寄存器。
while(ADC_GetResetCalibrationStatus(ADC1)); //等待复位校准结束
ADC_StartCalibration(ADC1); //开启AD校准
while(ADC_GetCalibrationStatus(ADC1)); //等待校准结束
* Function Name: Get_ADC_Val
* Description : Returns ADCx conversion result data.
* Input : ch: ADC channel.
* ADC_Channel_0: ADC Channel0 selected. PA0
* ADC_Channel_1: ADC Channel1 selected. PA1
* ADC_Channel_2: ADC Channel2 selected. PA2
* ADC_Channel_3: ADC Channel3 selected. PA3
* ADC_Channel_4: ADC Channel4 selected. PA4
* ADC_Channel_5: ADC Channel5 selected. PA5
* ADC_Channel_6: ADC Channel6 selected. PA6
* ADC_Channel_7: ADC Channel7 selected. PA7
* ADC_Channel_8: ADC Channel8 selected. PB0
* ADC_Channel_9: ADC Channel9 selected. PB1
* ADC_Channel_10: ADC Channel10 selected. PC0
* ADC_Channel_11: ADC Channel11 selected. PC1
* ADC_Channel_12: ADC Channel12 selected. PC2
* ADC_Channel_13: ADC Channel13 selected. PC3
* ADC_Channel_14: ADC Channel14 selected. PC4
* ADC_Channel_15: ADC Channel15 selected. PC5
* ADC_Channel_16: ADC Channel16 selected.
* ADC_Channel_17: ADC Channel17 selected.
* Return : val: The Data conversion value.
u16 Get_ADC_Val(u8 ch)
u16 val;
ADC_RegularChannelConfig(ADC1, ch, 1, ADC_SampleTime_239Cycles5 );
ADC_SoftwareStartConvCmd(ADC1, ENABLE);
while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC ));
val = ADC_GetConversionValue(ADC1);
return val;
* Function Name: DMA_Tx_Init
* Description : Initializes the DMAy Channelx configuration.
* Input : DMA_CHx:
* x can be 1 to 7.
* ppadr: Peripheral base address.
* memadr: Memory base address.
* bufsize: DMA channel buffer size.
* Return : None
void DMA_Tx_Init( void )
DMA_InitTypeDef DMA_InitStructure;
RCC_AHBPeriphClockCmd( RCC_AHBPeriph_DMA1, ENABLE ); //使能开启DMA时钟
DMA_DeInit(DMA1_Channel1); //复位DMA控制器
DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)&ADC1->RDATAR;//配置外设地址为ADC数据寄存器地址
DMA_InitStructure.DMA_MemoryBaseAddr = (u32)ADC_ConvertedValue; //配置存储器地址为读取ADC值地址
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC; //配置数据源为外设,即DMA传输方式为外设到存储器
DMA_InitStructure.DMA_BufferSize = length; //设置DMA数据缓冲区大小,此处设置为length
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;//设置DMA外设递增模式关闭
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; //设置DMA存储器递增模式开启
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; //设置外设数据大小为半字,即两个字节
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; //设置存储器数据大小为半字,即两个字节
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; //设置DMA模式为循环传输模式
DMA_InitStructure.DMA_Priority = DMA_Priority_High; //设置DMA传输通道优先级为高,当使用一 DMA通道时,优先级设置不影响
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; //因为此DMA传输方式为外设到存储器,因此禁用存储器到存储器传输方式
DMA_Init( DMA1_Channel1, &DMA_InitStructure ); //初始化DMA
DMA_Cmd(DMA1_Channel1 , ENABLE);//使能DMA
// 配置 ADC 通道转换顺序为1,第一个转换,采样时间为55.5个时钟周期
ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 1, ADC_SampleTime_55Cycles5);
ADC_RegularChannelConfig(ADC1, ADC_Channel_2, 2, ADC_SampleTime_55Cycles5);
ADC_RegularChannelConfig(ADC1, ADC_Channel_3, 3, ADC_SampleTime_55Cycles5);
ADC_RegularChannelConfig(ADC1, ADC_Channel_4, 4, ADC_SampleTime_55Cycles5);
ADC_RegularChannelConfig(ADC1, ADC_Channel_5, 5, ADC_SampleTime_55Cycles5);
// 使能ADC DMA 请求
ADC_DMACmd(ADC1, ENABLE);
// 由于没有采用外部触发,所以使用软件触发ADC转换
* Function Name: main
* Description : Main program.
* Input : None
* Return : None
int main(void)
u16 i;
Delay_Init();
USART_Printf_Init(115200);
printf("SystemClk:%d\r\n",SystemCoreClock);
ADC_Function_Init();
printf("CalibrattionValue:%d\n", Calibrattion_Val);
DMA_Tx_Init();
// DMA_Cmd( DMA1_Channel1, ENABLE );
// ADC_RegularChannelConfig(ADC1, ADC_Channel_2, 1, ADC_SampleTime_239Cycles5 );
//Delay_Ms(50);
// ADC_SoftwareStartConvCmd(ADC1, DISABLE);
// for(i=0; i<1024; i++)
// printf( "%04d\r\n", TxBuf+Calibrattion_Val );
// Delay_Ms(10);
// while(1);
while (1)
printf("\r\n The current ADCH1 value = %d \r\n", ADC_ConvertedValue);
printf("\r\n The current ADCH2 value = %d \r\n", ADC_ConvertedValue);
printf("\r\n The current ADCH3 value = %d \r\n", ADC_ConvertedValue);
printf("\r\n The current ADCH4 value = %d \r\n", ADC_ConvertedValue);
printf("\r\n The current ADCH5 value = %d \r\n", ADC_ConvertedValue);
Delay_Ms(500);
如何做多通道ADC? 采集到的数据相互有干扰,该怎么破? 可以同时采集吗? 多通道转换,是怎么样读取转换的结果的 ? 两路数据相同怎么解决 AD转换的DMA方式和非DMA方式有什么不同 adc多通道采集可以不采用dma吗 怎么2个adc一起用 如何使用ADC+DMA每隔一小段时间连续采集两个通道的数据 数据传输适合用DMA吗? 怎么样读取转换的结果的 ? 沁恒CH32V307不错。 DMA寄存器配置可以参考《CH32FV2x_V3x 应用手册》的第11章 CH32V307 一款超实用的MCU adc多通道采集可以不采用dma吗
页:
[1]
