呐咯密密 发表于 2022-9-15 15:09
如何监控各个线程的资源占用情况?
例子multi_thread.c:#define _GNU_SOURCE
#include <pthread.h>
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
// 线程名称最大长度
#define APP_THREAD_NAME_MAX_LEN   32
// 线程索引
typedef enum _app_thread_index
    APP_THREAD_INDEX_TEST0,
    APP_THREAD_INDEX_TEST1,
    APP_THREAD_INDEX_TEST2,
    APP_THREAD_INDEX_TEST3,
    APP_THREAD_INDEX_TEST4,
    APP_THREAD_INDEX_TEST5,
    APP_THREAD_INDEX_MAX
}app_thread_index_e;
// 线程入口函数指针类型
typedef void *(*p_thread_fun)(void *param);
// 线程数据表
typedef struct _app_thread
    pthread_t thread_handle;
    p_thread_fun thread_entry;
    char name;
}app_thread_s;
static void *test0_thread_entry(void *param);
static void *test1_thread_entry(void *param);
static void *test2_thread_entry(void *param);
static void *test3_thread_entry(void *param);
static void *test4_thread_entry(void *param);
static void *test5_thread_entry(void *param);
// 线程表
app_thread_s s_app_thread_table =
    {0, test0_thread_entry, "test0_thread"},
    {0, test1_thread_entry, "test1_thread"},
    {0, test2_thread_entry, "test2_thread"},
    {0, test3_thread_entry, "test3_thread"},
    {0, test4_thread_entry, "test4_thread"},
    {0, test5_thread_entry, "test5_thread"}
    printf("test0_thread running...\n");
    while (1)
      usleep(2 * 1000);
    return NULL;
    printf("test1_thread running...\n");
    while (1)
      usleep(2 * 1000);
    return NULL;
    printf("test2_thread running...\n");
    while (1)
      usleep(2 * 1000);
    return NULL;
    printf("test3_thread running...\n");
    while (1)
      usleep(2 * 1000);
    return NULL;
    printf("test4_thread running...\n");
    while (1)
      usleep(2 * 1000);
    return NULL;
    printf("test5_thread running...\n");
    while (1)
      usleep(2 * 1000);
    return NULL;
static int create_all_app_thread(void)
    int ret = 0;
    for (int i = 0; i < APP_THREAD_INDEX_MAX; i++)
      ret = pthread_create(&s_app_thread_table.thread_handle, NULL, s_app_thread_table.thread_entry, NULL);
      if (0 != ret)
            printf("%s thread create error! thread_id = %ld\n", s_app_thread_table.name, s_app_thread_table.thread_handle);
            return ret;
      else
            printf("%s thread create success! thread_id = %ld\n", s_app_thread_table.name, s_app_thread_table.thread_handle);
            pthread_setname_np(s_app_thread_table.thread_handle, s_app_thread_table.name);
      pthread_detach(s_app_thread_table.thread_handle);
    return ret;
int main(int argc, char **argv)
    create_all_app_thread();
    while (1)
      usleep(2 * 1000);
    return 0;
呐咯密密 发表于 2022-9-15 15:10
我们可以通过top命令来查看。要在top输出中开启线程查看,请调用top命令的“-H”选项,该选项会列出所有Linux线程。
这里我们指定查看multi_thread进程的各线程运行情况,命令:
top -H -p `pidof multi_thread`
注意:
这里的 `号并不是单引号!!!
这里的 `号并不是单引号!!!
这里的 `号并不是单引号!!!
这个符号在键盘上感叹号!键的左边。
我们先运行程序,再使用top命令查看,如:
注意,我们创建线程的时候需要使用 pthread_setname_np 函数设置线程的名字,否则top -H显示不出来具体的线程。
假如我们把上例中的pthread_setname_np屏蔽掉,结果如:
可见,不调用pthread_setname_np设置线程名称的话,top -H查看得到的各线程名称就是进程名。
页: [1]
查看完整版本: 如何监控各个线程的资源占用情况?
