Wallys wifi5 router/IPQ4019 openWRT 2.4/5G dual bands 802.11ac
Wallys wifi5 router/IPQ4019 openWRT 2.4/5G dual bands 802.11acFeaturing withindustrial-grade IPQ4019chipsetIntegrated with 2x 2 5G high powerRadio module and 2x2 2.4G high powerRadio moduleSupport 5.180GHz to5.825GHz Frequency Range;Support 2.412GHz to 2.482GHzSupport 2 x 5G MMCX Connectors and 2x2.4G MMCX20MHz/40MHz/80MHz BandwidthSupport 11ABGN/802.11ACRoHS compliance ensure a high levelprotection of human health and the environment from risks that can be posed by
Absolute Maximum Rating
Parameter
Rating
Unit
Supply Voltage
24V~48
V
Operating Temperature Range
-40 to +70
ºC
Storage Temperature Range
-45 to +105
ºC
Operating Humidity Range
5 to +95 (non-condensing)
Storage Humidity Range
0 to +90 (non-condensing)
Hardware Specifications
Symbol
Parameter
CPU
IPQ4019(Quad core ARM Cortex A7 at 716.8 MHz)
Antenna Connector
2 x 5G MMCX connectors;2x2.4G MMCX
10/100/1000Mbps
Gigabit Ethernet
2xRJ45
DC Jack
12 power supply
ROHS Compliance
YES
Dimension
65mmx35mm x 16mm
Max Power
12V x 0.8A= 9.6W
Nor Flash
32MB
DDR
256MB
Radio TX Specifications(5180MHz-5825MHz)
Operating Mode
Data Rate
Power
Tolerance
1 Chain2 Chains
802.11a6 Mbps26dBm29dbm±2dB
54 Mbps22dBm25dbm±2dB
802.11n HT20MCS0, MCS826dBm29dbm±2dB
MCS7, MCS1522dBm25dbm±2dB
802.11n HT40MCS0, MCS825dBm28dbm±2dB
MCS7, MCS1521dBm24dbm±2dB
802.11acMCS0, MCS10,MCS2025dBm28dbm±2dB
MCS9,MCS19,MCS2919dBm22dbm±2dB
Radio RX Specifications(5180MHz-5825MHz)
Operating Mode
Data Rate
Sensitivity
802.11a
6 Mbps-92dBm
54 Mbps-74dBm
802.11n HT20
MCS0, MCS8-91dBm
MCS7, MCS15-72dBm
802.11n HT40
MCS0, MCS8-90dBm
MCS7, MCS15-70dBm
802.11ACHT40
MCS0, MCS10,MCS20-90dBm
MCS9,MCS19,MCS29-67dBm
802.11ACHT80
MCS0, MCS10,MCS20-88dBm
MCS9,MCS19,MCS29-62dBm
Radio TX Specifications(2412MHz-2482MHz)
Operating Mode
Data Rate
PowerTolerance
1 Chain2 Chains
802.11g
6 Mbps25dbm28dbm±2dB
54 Mbps22dbm25dbm±2dB
802.11n HT20
MCS0, MCS825dbm28dbm±2dB
MCS7, MCS1521dbm24dbm±2dB
802.11n HT40
Stable networks guarantee for the ongoing continuity of your video surveillance. Our boards could establish a stable connected wireless environment which is critical for a security surveillance system.
Wallys has been specializing in product design & manufacturing and delivering superior OEM/ODM services in wireless communications. Dedicated to innovative designs for wireless modules. Customization is also supported, We have 90% of the world market, We’re a supplier to Facebook.
EMAIL:sales@wallystech.com
WEB:https://www.wallystech.com/
https://www.youtube.com/channel/UClmu7LBz_OWxe2VckkQr3tw
页:
[1]
