QNX环境使用iperf获取网络性能参数
代码,头文件:
#ifndef __IPERF_COLLECTION_H__
#define __IPERF_COLLECTION_H__
#include <map>
#include <pthread.h>
#include "macros.h"
using namespace std;
typedef void ( * port_performance_calback_t ) ( void * data ) ;
template<typename T>
class Singleton{
public:
static T& get_instance(){
static T instance;
return instance;
virtual ~Singleton(){
std::cout<<"destructor called!"<<std::endl;
Singleton(const Singleton&)=delete;
Singleton& operator =(const Singleton&)=delete;
protected:
Singleton(){
std::cout<<"constructor called!"<<std::endl;
class IperfCollection:public Singleton<IperfCollection> {
friend class Singleton<IperfCollection>;
public:
//static shared_ptr<IperfCollection> getInstance(){
// return _instance;
int Init(port_performance_calback_t cb);
private:
int createFifo();
int stringParsing(string str,int port);
static void *iperfDataCollection(void *data);
IperfCollection():_callback(NULL){}
~IperfCollection(){}
pthread_t _threadId;
port_performance_calback_t _callback;
//static shared_ptr<IperfCollection> _instance;
map<int,string> _portFifo;
map<int,int> _portFd;
#endif
.cpp文件:
#include <fstream>
#include <fcntl.h>
#include <iostream>
#include<regex>
#include "IperfCollection.h"
int IperfCollection::createFifo()
ifstream fin("ethernetTest.sh");
string::const_iterator itStart;
string::const_iterator itEnd;
string scriptLine;
int ret;
regex filePath("/var/fifo_(\\d*)");
while( getline(fin,scriptLine) ){
itStart = scriptLine.begin();
itEnd = scriptLine.end();
smatch result;
if (regex_search(itStart, itEnd, result, filePath)) {
string str_port = result;
int port = atoi(str_port.c_str());
cout << "+++++ file path: " << result << " num: " << port << endl;
string filepath = result;
ret = mkfifo(filepath.c_str(),S_IRUSR | S_IWUSR);
cout << "ret: " << ret << endl;
_portFifo = filepath;
} else {
cout << "--- no search ---" << endl;
return 0;
struct rtl9072_port_status
uint32_t port ;
uint32_t tx_speed ;
uint32_t tx_pack_drop_rate ;
uint32_t rx_speed ;
uint32_t rx_pack_drop_rate ;
int IperfCollection::stringParsing(string str, int port)
struct rtl9072_port_status status;
smatch result;
port_performance_calback_t call = (port_performance_calback_t)_callback;
regex BandwidthMbits("-?((((\\d*)|(\\d)|(0))\\.((\\d*)|()\\d))|(0)|(\\d*))\\sMbits");
regex BandwidthKbits("-?((((\\d*)|(\\d)|(0))\\.((\\d*)|()\\d))|(0)|(\\d*))\\sKbits");
regex BandwidthGbits("-?((((\\d*)|(\\d)|(0))\\.((\\d*)|()\\d))|(0)|(\\d*))\\sGbits");
regexPackageloss("\\(-?((\\d*\\.\\d*)|(0\\.\\d*\\d*)|(\\d*))\\%\\)");
string::const_iterator iterStart = str.begin();
string::const_iterator iterEnd = str.end();
string temp,value;
if (regex_search(iterStart, iterEnd, result, BandwidthMbits))
temp = result;
cout << "==" << port << "== BandwidthMbits: " << result << endl;
//iterStart = result.second;
} else if (regex_search(iterStart, iterEnd, result, BandwidthKbits)) {
temp = result;
cout << "==" << port << "== bandwidthKbits: " << result << endl;
} else if (regex_search(iterStart, iterEnd, result, BandwidthGbits)) {
temp = result;
cout << "==" << port << "== BandwidthGbits: " << result << endl;
if (regex_search(iterStart, iterEnd, result, Packageloss))
temp = result;
cout << "==" << port << "== package loss: " << result << endl;
if(call != NULL)
call(&status);
return 0;
void * IperfCollection::iperfDataCollection(void *data)
int ret,fd;
IperfCollection *collection = (IperfCollection *)data;
map<int,string>::iterator iter_pf;
for(iter_pf = (collection->_portFifo).begin();iter_pf != (collection->_portFifo).end();iter_pf ++) {
string file = iter_pf->second;
int port = iter_pf->first;
fd = open(file.c_str(),O_RDONLY | O_NONBLOCK,0);
if(fd < 0){
cout << "open error!\n" ;
return NULL;
collection->_portFd = fd;
char buf1;
while(1) {
ssize_t s = read(collection->_portFd,buf1,sizeof(buf1)-1);
if(s > 0) {
buf1 = 0;
string row = buf1;
cout << row << endl;
//test1(row,port);
collection->stringParsing(row,port);
} else if (s == 0) {
cout << "client quit,exit ..." << endl;
continue;
sleep(1);
close(ret);
return NULL;
int IperfCollection::Init(port_performance_calback_t cb)
int ret;
ret = this->createFifo();
if (ret != 0) {
cout << "createFifo error" << endl;
return ret;
if(cb != NULL)
_callback = cb;
pthread_create(&_threadId, NULL, &iperfDataCollection ,this);
return 0;
main.cpp
void callback(void *data)
cout << "======== call back =====" << endl;
int main(void)
IperfCollection* collection;
collection = &IperfCollection::get_instance();
collection->Init(callback);
auto re = system("./ethernetTest.sh");
cout << "re = " << re << endl;
string line;
pthread_t thread_id;
//test();
string s;
int ret,fd;
string::const_iterator itStart;// = fp.begin();
string::const_iterator itEnd;// = fp.end();
cout << "==============================" << endl;
while( getline(fin,s) ){
itStart = s.begin();
itEnd = s.end();
smatch result;
fifo_port = filepath;
} else {
pthread_create(&thread_id, NULL, &iperfDataCollection ,NULL);
for(iter_pf = fifo_port.begin();iter_pf != fifo_port.end();iter_pf ++) {
if(fd < 0){
return -1;
port_fd = fd;
char buf1;
while(1) {
//cout << "please waiting...\n";
ssize_t s = read(port_fd,buf1,sizeof(buf1)-1);
if(s > 0) {
buf1 = 0;
string row = buf1;//" 38.0-39.0 sec11.5 MBytes96.4 Mbits/sec 0.294 ms 11/ 8208 (0.13%)";//buf1;
test1(row,port);
continue;
sleep(1);
close(ret);*/
while(1) {
sleep(10);
参考:
C++的单例模式 参考:
智能指针
页:
[1]
