lvben5d 发表于 2022-10-17 14:31
KF8 8位机数据类型 一个结构体的成员变量不能超过128字节[否则报错]
typedef unsigned char      u8;
typedef unsigned short int u16;
typedef unsigned char      uint8_t;
typedef unsigned short int uint16_t;
typedef unsigned int      u32;          //注意 因为是8位机这里不是4个字节了!!
typedef unsigned long      ul32;      //这个才是4字节!!
u16 C={0,0,0,0,0};
u16 D={100000,65534,3,4,5};   //这里100000 大于65535溢出了,但是编译器不会报错~自己要注意数值范围
void f(u16 *p)
      u8 i;
      for(i=0; i<8; i++)C = *p++ ;
2.    kF8 编译器支持的 结构体成员变量   占内存不能超过128字节,否则就报错!估计是硬件内存分页引起!
typedef struct{
      u8 key;       //Byte N of Secret; Secret Begins at Address 80h (see Figure 5)
      u8 _PP;      //Byte N of Memory Page; Memory Pages begin at 00h, 20h, 40h and 60h (see Figure 5)
      u8 _SP;       //Byte N of Scratchpad
      u8 _MP;          //MP = 00000b, MP = T
      u8 _RN;       //Byte N of Registration Number. The CRC byte of the registration number is not used.
}SHA1Para_t;
typedef struct
      ul32_M;
      ul32_H;
}SHA1Para2_t;
   原本是这样
/* sha1参数 */
typedef struct
uint8_t _SS;       //Byte N of Secret; Secret Begins at Address 80h (see Figure 5)
uint8_t _PP;      //Byte N of Memory Page; Memory Pages begin at 00h, 20h, 40h and 60h (see Figure 5)
uint8_t _SP;       //Byte N of Scratchpad
uint8_t _MP;          //MP = 00000b, MP = T
uint8_t _RN;       //Byte N of Registration Number. The CRC byte of the registration number is not used.
uint32_t _M;
uint32_t _H;
}SHA1Para_t;         这里超过了128字节编译就不过!!!!
gggggggggx 发表于 2022-10-18 16:13
受益匪浅
页: [1]
查看完整版本: KF8 8位机数据类型 一个结构体的成员变量不能超过128字节[否则报错]
