两只袜子 发表于 2022-10-28 14:58
STM32CubeProg API 开发环境QT配置失败问题
STM32CubeProgrammer 的版本为 V2.7.0操作系统版本版本为win10 64bit
根据 相对路径:..\STMicroelectronics\STM32Cube\STM32CubeProgrammer\api 文件夹内
..\api\doc 内文档 STM32CubeProgrammer_API.chm 描述
The Qt projects are developed with Qt Creator 4.7.1, Qt 5.11.2 and MinGW 32 bit compiler and also it can be compiled by MinGW x64.
使用example例程内 UART_Example
[*]int main()
[*]      int ret = 0;
[*]    const char* loaderPath = "./.";
[*]    displayCallBacks vsLogMsg;
[*]    /* Set device loaders path that contains FlashLoader and ExternalLoader folders*/
[*]      setLoadersPath(loaderPath);
[*]    /* Set the progress bar and message display functions callbacks */
[*]      vsLogMsg.logMessage = DisplayMessage;
[*]      vsLogMsg.initProgressBar = InitPBar;
[*]      vsLogMsg.loadBar = lBar;
[*]    setDisplayCallbacks(vsLogMsg);
[*]    /* Set DLL verbosity level */
[*]    setVerbosityLevel(verbosityLevel = VERBOSITY_LEVEL_1);
[*]    //ret = Example1();
[*]    //ret = Example2();
[*]    //ret = Example3();
[*]    //ret = I2C_Example();
[*]    //ret = CAN_Example();
[*]    //ret = SPI_Example();
[*]    ret = UART_Example();
[*]    //ret = USB_Example();
[*]    //ret = TSV_Flashing();
[*]    std::cout << "\n" << "Press enter to continue...";
[*]      std::cin.get() ;
[*]      return ret;
复制代码
使用QT 5.11.2 MinGW 5.3.0 32bit 报错
使用QT 5.12.0 MinGW 7.3.064bit 或者更高版本均提示
CubeProgrammer_API.dll 使用qt library 版本为 5.11.2 ,QT不能使用更高版本。
请问怎么才能正确配置API的开发环境?
页: [1]
查看完整版本: STM32CubeProg API 开发环境QT配置失败问题
