Wallys 4x4 MU-MIMO 6G moudle/QCN9074 802.11ax wifi6E M.2
Features■ Qualcomm Atheros QCN9074
■ 6GHz, max 23dBm per chain, up to 4949Mbps
■ Single Band 6GHz 4x4 WiFi 6E (802.11ax)
■ 4 spatial streams (4SS)
■ M.2 E Key Interface
■ PCI Express 3.0 Interface
Absolute Maximum Rating
ParameterRatingUnit
Operating Temperature Range-20 to 70ºC
Storage Temperature Range-40 to 90ºC
Operating Humidity Range5 to +95 (non-condensing)%
Storage Humidity Range0 to +90 (non-condensing)%
Hardware Specifications
Symbol
Parameter
Chipset
WLAN Host Interface
System Memory
2Mbit serial I²C bus EEPROM
Standard Operating Voltage
5V
Operating Systems
QSDK
Host Interface
M.2 E Key
Antenna Cable / Port
4 x MMCX Connectors,4T4R
Frequency Range
5.925GHz-7.125GHz
Data Rates for WALN
Channel Spectrum Widths for WLAN
Support 20/40/80/160MHz at 6GHz
Modulation Techniques
OFDMA: BPSK, QPSK, DBPSK, DQPSK,16-QAM, 64-QAM, 256-QAM,1024-QAM, 4096-QAM
Temperature Range
Operating: -20°C to 70°C, Storage: -40°C to 90°C
Humidity
Operating: 5% to 95% (non-condensing), Storage: Max. 90% (non-condensing)
Certification
TBD
Power Consumption
TBD
Reference Design
PN02.7
Dimensions (WxHxD)
57mm x 63mm x 6mm
M.2 Pin Definitions
Pin No.NamePin No.Name
1GND
2VDD3P3_PCIE
4VDD3P3_PCIE
6PCIE_LED0
7GND
8GPIO46_WCI2_UART_TXD_PCIE
9TP19
10GPIO47_WCI2_UART_RXD_PCIE
14
15VDD_XPA_PCIE
16PCIE_LED1
17VDD_XPA_PCIE
18GND
19VDD_XPA_PCIE
20
21VDD_XPA_PCIE
22
23VDD_XPA_PCIE
33GND
32
35PCIE0_RX0_P
34
37PCIE0_RX0_N
36
39GND
38MOD_BT_STS_2
41PCIE0_TX0_P
40MOD_WL_ACT_2
43PCIE0_TX0_N
42PINE_BT_ACT_2
45GND
44MOD_BT_STS
47PCIE0_REFCLK_P
46MOD_WL_ACT
49PCIE0_REFCLK_N
48PINE_BT_ACT
51GND
50
53PCIE0_CLKREQ_3P3_N
52PCIE0_PERST_3P3
55PCIE0_WAKE_3P3_N
54
57GND
56
59PCIE0_RX1_P
58
61PCIE0_RX1_N
60
63GND
62
65PCIE0_TX1_P
64
67PCIE0_TX1_N
66
69GND
68
71
70
73
72VDD3P3_PCIE
75GND
74VDD3P3_PCIE
页:
[1]
