jinglixixi 发表于 2022-11-21 09:31
【新定义MCU开发板测评】 + 光照强度检测与显示
前面介绍的温度大气压传感器相近,光照强度传感器BH1750也是一种I2C接口的器件。除了具体的功能处理不同外,其它的基本差不多。BH1750方式与接收字节数据的函数如下:
void BH1750_SendByte(char data1)
    char i;
    OUTPUT_MODE_SET();
    SCLK=0;
    Delay_us(2);
    for (i=0;i<8;i++)
      if(data1&0x80) SDIN=1;
      else SDIN=0;
      data1 <<= 1;
      SCLK=1;
      Delay_us(2);
      SCLK=0;
      Delay_us(2);
char BH1750_RecvByte()
    char i;
    char data1 = 0;
    INPUT_MODE_SET();
    for (i=0;i<8;i++)
      SCLK=0;
      Delay_us(2);
      SCLK=1;
      data1 <<= 1;
      SCLK=1;
      if(SDA_IN ) data1|=0x01;
      Delay_us(2);
    SCLK=0;
    return data1;
写入寄存器的函数为:void Single_Write_BH1750(char REG_Address)
    BH1750_Start();
    BH1750_SendByte(SlaveAddress);
    BH1750_RecvACK();
    BH1750_SendByte(REG_Address);
    BH1750_RecvACK();
    BH1750_Stop();
读取BH1750数据的函数为:
void Multiple_Read_BH1750()
    BH1750_Start();
    BH1750_SendByte(SlaveAddress+1);
    BH1750_RecvACK();
    BUF = BH1750_RecvByte();
    BH1750_SendACK(0);
    BH1750_SendACK(1);
    BH1750_Stop();
    Delay(5);
读取并显示光照强度的函数为:void Get_Sunlight_Value()
    int dis_data=0;
    float temp;
    char i=0;
    unsigned int sd;
    Single_Write_BH1750(0x01);
    Single_Write_BH1750(0x10);
    Delay(180);
    Multiple_Read_BH1750();
    for(i=0;i<3;i++)    dis_data=BUF;
    dis_data=(dis_data<<8)+BUF;
    temp=(float)dis_data/1.2;
    sd=temp;
    LCD_ShowNum(120,50,sd,5,YELLOW);
显示光强检测与显示的主程序为:void main(void)
        P0CON = 0xFF;
        P0PH= 0x00;
        P1CON = 0x00;
        P1PH= 0x00;
        P2CON = 0xFF;
        P2PH= 0x00;
        P3CON = 0xFF;
        P3PH= 0x00;
        P4CON = 0xFF;
        P4PH= 0x01;
        P5CON = 0xFF;
        P5PH= 0x00;
        GPIO_Init(GPIO0, GPIO_PIN_4 | GPIO_PIN_5 |GPIO_PIN_6, GPIO_MODE_OUT_PP);
        GPIO_Init(GPIO2, GPIO_PIN_2, GPIO_MODE_OUT_PP);
        GPIO_Init(GPIO5, GPIO_PIN_3, GPIO_MODE_OUT_PP);
    GPIO_Init(GPIO4, GPIO_PIN_2 | GPIO_PIN_3 | GPIO_PIN_4 | GPIO_PIN_5, GPIO_MODE_OUT_PP);
        Delay(100);
        Lcd_Init();
    LCD_Clear(RED);
        BACK_COLOR=RED;
        LCD_Picturea();
        LCD_ShowChinese(80,10,0,16,YELLOW);
        LCD_ShowChinese(96,10,1,16,YELLOW);
        LCD_ShowChar(112,10,':',0,YELLOW);
        LCD_ShowChinese(80,30,2,16,YELLOW);
        LCD_ShowChinese(96,30,3,16,YELLOW);
        LCD_ShowChar(112,30,':',0,YELLOW);
        LCD_ShowChinese(80,50,4,16,YELLOW);
        LCD_ShowChinese(96,50,5,16,YELLOW);
        LCD_ShowChar(112,50,':',0,YELLOW);
        while(1)
                  Get_Sunlight_Value();
                  Delay(1000);
经程序的编译与下载,其运行效果如下图所示。
光强检测效果
pl202 发表于 2023-3-10 16:33
BH1750的效果不错。
dspmana 发表于 2023-3-10 17:12
光敏是怎么转换为数值的
光敏是怎么转换为数值的
数字式传感器无需模拟量那样的转换
wwppd 发表于 2023-3-11 20:44
BH1750测量的范围阈值是多少
dspmana 发表于 2023-3-11 21:27
利用BH1750光照传感器来调节LED灯的亮度
saservice 发表于 2023-3-11 21:48
这个是模拟量变化数值吗?
uytyu 发表于 2023-3-11 22:19
BH1750的才几块钱,数字传感器。
pl202 发表于 2023-3-11 22:26
使用的是硬件iic配置的吗?
这个是模拟量变化数值吗?
数字式传感器
使用的是硬件iic配置的吗?
GPIO模拟
tifmill 发表于 2023-4-4 14:32
如何用bh1750实现20万lux光照度测量
rosemoore 发表于 2023-4-4 16:02
BH1750连单片机接上拉电阻吗
i1mcu 发表于 2023-4-4 20:46
如何找bh1750的在iic总线中的地址
claretttt 发表于 2023-4-4 21:09
BH1750连单片机接上拉电阻吗
查资料看看它的最大测量范围到多大
wwppd 发表于 2023-4-6 18:10
bh1750的输入输出关系是什么
lihuami 发表于 2023-4-6 18:17
怎么利用BH1750光照传感器来调节LED灯的亮度
页: [1] 2 3 4 5
查看完整版本: 【新定义MCU开发板测评】 + 光照强度检测与显示
