51xlf 发表于 2022-11-23 22:07
硬件iic的使用
利用I2C接口,采用轮询方式读写EEPROM芯片
#define TESTI2C2    //I2C1 = 1   I2C2 = 2
#defineI2C1_SCL_GPIO_PORT       CW_GPIOB
#defineI2C1_SCL_GPIO_PIN      GPIO_PIN_10    //如果改动口线则GPIO初始化代码需要做同步修改
#defineI2C1_SDA_GPIO_PORT       CW_GPIOB
#defineI2C1_SDA_GPIO_PIN      GPIO_PIN_11    //如果改动口线则GPIO初始化代码需要做同步修改
#defineI2C2_SCL_GPIO_PORT       CW_GPIOB
#defineI2C2_SCL_GPIO_PIN      GPIO_PIN_0   //如果改动口线则GPIO初始化代码需要做同步修改
#defineI2C2_SDA_GPIO_PORT       CW_GPIOB
#defineI2C2_SDA_GPIO_PIN      GPIO_PIN_1   //如果改动口线则GPIO初始化代码需要做同步修改
//EEPROM内部地址
#define WRITEADDRESS   0      //写入或者读取的EEPROM的地址
#define WriteReadCycle22    //写读次数,每次写入数据为n+i(n为次数,i=0~7)
uint8_t u8Senddata = {0x66,0x02,0x03,0x04,0x05,0x60,0x70,0x20};
uint8_t u8Senddata2 = {0x55,0xAA,0xAA,0x55,0x55,0xAA,0x55,0xAA};
uint8_t u8Recdata={0x00};
uint8_t u8SendLen=0;
uint8_t u8RecvLen=0;
uint8_t Send** = 0,Comm_** = 0;
uint8_t u8recv**=0;
uint8_t u8State = 0;
void RCC_Configuration(void);
void GPIO_Configuration(void);
void NVIC_Configuration(void);
int32_t main(void)
                uint16_t tempcnt = 0 ;
          I2C_InitTypeDef I2C_InitStruct;
    //时钟初始化
    RCC_Configuration();
    //IO口初始化
    GPIO_Configuration();
    //I2C初始化
    I2C_InitStruct.I2C_BaudEn = ENABLE;
                I2C_InitStruct.I2C_Baud = 0x01;//500K=(8000000/(8*(1+1))
    I2C_InitStruct.I2C_FLT = DISABLE;
    I2C_InitStruct.I2C_AA = DISABLE;
    #if(0X01 == TESTI2C)
      I2C1_DeInit();
      I2C_Master_Init(CW_I2C1,&I2C_InitStruct);//初始化模块
                                I2C_Cmd(CW_I2C1,ENABLE);//模块使能
    #elif(0X02 == TESTI2C)
      I2C2_DeInit();
      I2C_Master_Init(CW_I2C2,&I2C_InitStruct);//初始化模块
                          I2C_Cmd(CW_I2C2,ENABLE);//模块使能
    #endif
                while(1)
                                I2C_MasterWriteEepromData(CW_I2C1,WRITEADDRESS,u8Senddata,8);
                                FirmwareDelay(3000);
                                I2C_MasterWriteEepromData(CW_I2C1,WRITEADDRESS+8,u8Senddata2,8);
                                I2C_MasterReadEepomData(CW_I2C1,WRITEADDRESS,u8Recdata,16);
                                I2C_MasterWriteEepromData(CW_I2C2,WRITEADDRESS,u8Senddata,8);
                                I2C_MasterWriteEepromData(CW_I2C2,WRITEADDRESS+8,u8Senddata2,8);
                                I2C_MasterReadEepomData(CW_I2C2,WRITEADDRESS,u8Recdata,16);
                        #endif
                        tempcnt++;
                        for(uint8_t i=0;i<8;i++)
                                u8Senddata =tempcnt+i;
                        if(tempcnt >=WriteReadCycle)
                                break;
    while(1)
iic的IO配置
      PB10_AFx_I2C1SCL();
      PB11_AFx_I2C1SDA();
                GPIO_InitStructure.Pins = I2C1_SCL_GPIO_PIN | I2C1_SDA_GPIO_PIN;
                GPIO_InitStructure.Mode = GPIO_MODE_OUTPUT_OD;
                GPIO_InitStructure.Speed = GPIO_SPEED_HIGH;
                GPIO_Init(I2C1_SCL_GPIO_PORT, &GPIO_InitStructure);
      PB00_AFx_I2C2SCL();
      PB01_AFx_I2C2SDA();
                GPIO_InitStructure.Pins = I2C2_SCL_GPIO_PIN | I2C2_SDA_GPIO_PIN;
                GPIO_Init(I2C2_SCL_GPIO_PORT, &GPIO_InitStructure);
    #endif
chenjun89 发表于 2022-12-3 18:43
很多时候都是用的软件模拟IIC
页: [1]
查看完整版本: 硬件iic的使用
