zeshoufx 发表于 2022-11-25 20:53
GD32F103卡尔曼滤波实现及效果
卡尔曼滤波在数据去噪,获得真实值的运用中广泛使用,在采集一些信号时,很实用。测试方法:通过将DAC输出与ADC连接,,DAC输出一固定值
通过ADC采集数据,由于ADC精度受限以及一些干扰,ADC采集到
的数据在固定值附近波动,通过卡尔曼滤波估计一下ADC采集的真实值。
这个与之前的PID测试有点区别,PID是设定目标,自动调节DAC,使
ADC采集数据接近目标。PID演示连接:专栏:ARM DSP库 PID控制测试 - 哔哩哔哩 (bilibili.com)视频:【ARM单片机PID控制测试——基于DSP库】 https://www.bilibili.com/video/BV1sd4y1w755/?share_source=copy_web&vd_source=7f0cb9c0f09b768583faf157910eb515视频1、卡尔曼滤波结构体:type_KalmanFilter//卡尔曼滤波结构体
typedef struct KalmanFilter
        float x_mea;       // 测量值
        float x_est;       // 估计值
        float e_mea;       // 测量偏差
        float e_est;       // 估计偏差
        float Kk;                // Karlman 增益
}type_KalmanFilter;2、初始化,为结构体成员赋值//Kalman初始化
void Kalman_Init(type_KalmanFilter* kalmanFilter, float FirstMeaValue, float E_mea, float FirstEstValue, float E_est)
        kalmanFilter->x_est = FirstEstValue;
        kalmanFilter->x_mea = FirstMeaValue;
        kalmanFilter->e_est = E_est;
        kalmanFilter->e_mea = E_mea;
        kalmanFilter->Kk = Kk_calc(kalmanFilter->e_est, kalmanFilter->e_mea);
}3、更新,将采集到的数据作为测量输入//Kalman更新
void Kalman_Update(type_KalmanFilter* kalmanFilter, float newMeaValue)
        float temp = kalmanFilter->e_est;
        kalmanFilter->x_est = kalmanFilter->x_est + kalmanFilter->Kk * (newMeaValue - kalmanFilter->x_est);
        kalmanFilter->x_mea = newMeaValue;
        kalmanFilter->e_est = (1 - kalmanFilter->Kk) * temp;
}4、端口设置void ad_da_init(void)
        //时钟配置
        rcu_periph_clock_enable(RCU_GPIOA);
        rcu_periph_clock_enable(RCU_AF);
        rcu_periph_clock_enable(RCU_ADC0);
        rcu_periph_clock_enable(RCU_DAC);
        rcu_adc_clock_config(RCU_CKADC_CKAPB2_DIV12);
        //接口配置
        gpio_init(GPIOA,GPIO_MODE_AIN,GPIO_OSPEED_50MHZ,GPIO_PIN_4);
        gpio_init(GPIOA,GPIO_MODE_AIN,GPIO_OSPEED_50MHZ,GPIO_PIN_6);
        //ADC输入配置
        adc_special_function_config(ADC0,ADC_CONTINUOUS_MODE,ENABLE);
        adc_data_alignment_config(ADC0,ADC_DATAALIGN_RIGHT);
        adc_channel_length_config(ADC0,ADC_REGULAR_CHANNEL,1);
        adc_regular_channel_config(ADC0,0,ADC_CHANNEL_6,ADC_SAMPLETIME_55POINT5);
        adc_external_trigger_config(ADC0,ADC_REGULAR_CHANNEL,DISABLE);
        adc_enable(ADC0);
        delay_ms(1);
        adc_calibration_enable(ADC0);
        //DAC输出配置
        dac_trigger_source_config(DAC0,DAC_TRIGGER_SOFTWARE);
        dac_trigger_enable(DAC0);
        dac_wave_mode_config(DAC0,DAC_WAVE_DISABLE);
        dac_output_buffer_enable(DAC0);
        dac_enable(DAC0);
        dac_data_set(DAC0, DAC_ALIGN_12B_R, (u16)1024);
    dac_software_trigger_enable(DAC0);
        //Kalman初始化
        Kalman_Init(&k, 1024, 2, 1024, 2);
}5、滤波处理void dsp_test(void)
        u16 adc_get=0;
        adc_software_trigger_enable(ADC0,ADC_REGULAR_CHANNEL);
        if(adc_flag_get(ADC0,ADC_FLAG_EOC))
                adc_flag_clear(ADC0,ADC_FLAG_EOC);
                adc_get = adc_regular_data_read(ADC0);
                Kalman_Update(&k,adc_get);
        printf("%d        %f        %f\r\n",adc_get,k.x_mea,k.x_est);
}6、主函数#include "bitband.h"
#include "led.h"
#include "systick.h"
#include "print.h"
#include "dsp_test.h"
u16 mem_infor={0};
u32 uid={0};
int main(void)
    systick_set(96);
        led_init();
        print_config(9600);
        get_mem_infor(&mem_infor,&mem_infor);
        printf("GD32F103VKT6 Flash Size=%dKB,Sram Size=%dKB...\r\n",mem_infor,mem_infor);
        get_uid(uid);
        printf("GD32F103VKT6 UID=%d%d%d...\r\n",uid,uid,uid);
        ad_da_init();
    while(1)
                dsp_test();
                delay_ms(100);
}演示视频:GD32F103卡尔曼滤波实现【GD32F103卡尔曼滤波测试】 https://www.bilibili.com/video/BV1bR4y1o7TQ/?share_source=copy_web&vd_source=7f0cb9c0f09b768583faf157910eb515GD32F103卡尔曼滤波测试效果【GD32F103卡尔曼滤波测试效果】 https://www.bilibili.com/video/BV1u14y1n7KD/?share_source=copy_web&vd_source=7f0cb9c0f09b768583faf157910eb5157、将数据打印输出,导入MATLAB,结果如图所示:可以看到整体上实际的采集值在波动,而卡尔曼滤波估计的真实值却基本很平稳
呐咯密密 发表于 2022-11-26 16:58
这个卡尔曼滤波执行一次时间多久,会不会影响系统的时效性
还没具体测试过,,,{:smile:}我觉得跟多采集几次然后取平均这种暴力滤波方式差不多,,明天测试后补充,,,
还没具体测试过,,,我觉得跟多采集几次然后取平均这种暴力滤波方式差不多,,明天测试后补充 ...
估计跟直接取平均还是有区别的,大概误差应该在0.2左右
0.2秒吗
Jacquetry 发表于 2022-12-21 17:35
这个应该会有一点误差的
星辰大海不退缩 发表于 2022-12-22 16:25
卡尔曼滤波确实通过MATLAB分析后的结果很稳定,果然滤波能消除干扰
楼主,平均算法滤波测试了嘛?结果跟卡尔曼滤波差距怎么样?
dspmana 发表于 2023-1-9 17:42
这个卡尔曼可以做数据融合的吗?
pentruman 发表于 2023-1-9 17:51
这个的计算量应该不会很小了。
页: [1]
查看完整版本: GD32F103卡尔曼滤波实现及效果
