lilywallys 发表于 2022-11-28 11:58
WIFI 6E/IPQ6010 CPU industrial wifi router support QCN9074 netwok card High power Wallys
WIFI 6E/IPQ6010 CPU industrial wifi router support QCN9074 netwok card High power Wallys What's WiFi 6E? Simply put, WiFi 6E means WiFi 6 extended to the 6 GHz band. WiFi 6E works with the same standard as WiFi 6 but with an extended spectrum. 6 GHz is the new frequency band ranging from 5.925 GHz to 7.125 GHz, allowing up to 1,200 MHz of additional spectrum. Unlike the existing bands on which channels are currently crammed into the limited spectrum, 6 GHz band exists without overlap or interference. Access to the 6 GHz frequency brings more bandwidth, faster speeds, and lower latency, opening up resources for future innovations like in AR/VR, 8K streaming and more. With an additional 1200 MHz of spectrum available for use in the 6 GHz band for Wi-Fi applications, Wi-Fi 6E devices will operate in 14 additional 80 MHz channels and 7 additional 160 MHz channels. This broader spectrum simplifies network design and delivers ultimate Wi-Fi performance with higher throughput and wider channels, while eliminating the need to support legacy devices, resulting in less network congestion. Making use of this extended spectrum capacity in 6 GHz brings the promising outlook of continued innovation across Wi-Fi user experience and connected devices. The Wi-Fi 6E standard further improves the 802.11ax network user experience with faster and more reliable Wi-Fi networks that are designed for soaring device densities and high-bandwidth applications such as video streaming, videoconferencing, and voice calls. Not all routerboard can support 6E card, it need develop the software, letting the routerboard support the 6E card. Our routerboard DR6018 can support our network card DR9074-6E, as our engineer has developed the software. DR6018Key words for DR6018 for your quick knownledgeDR6018 Qualcomm-Atheros IPQ6010Quad-core ARM 64bit A53 @1.8GHz Processor1GB DDRL3L System Memory32MB NOR Flash, 256MB NAND FlashSupports Dynamic Frequency Selection (DFS)2x2 On-board 2.4GHz radio, up to 573Mbps physical Data Rate2x2 On-board 5GHz radio, up to 1201Mbps physical Data RateSupport: QUECTEL RM500Q-GLSupport: QCN9074 WiFi 6E Card Click below the link for more hardware parameter information for DR6018https://www.wallystech.com/Routerboard/DR6018V4-wifi6-Qualcomm-IPQ6010-IPQ6018-FAMILY-2T2R-2.5G-ETH-port-supporting-5G-celluar-Modem-802-11AX-MU-MIMO-OFDMA.html 9074-6EKey words for 9074-6E for your quick knownledge■ Qualcomm Atheros QCN9074■ 6GHz, max 23dBm per chain, up to 4949Mbps■ Single Band 6GHz 4x4 WiFi 6E (802.11ax)■ 4 spatial streams (4SS)■ M.2 E Key Interface■ PCI Express 3.0 Interface Click below the link for more hardware parameter information for 9074-6Ehttps://www.wallystech.com/Network_Card/DR9074-6E-Wifi6E-Qualcomm-QCN9074-Single-Band-6GHz-4T4R-M-2-E-Key-Interface-802-11ax.html Wallys Communications(Suzhou) Co.,Ltd,known as a specialist in researching and developing and producing of wireless communication products,have star product as Routerboard,Network Card,Industrial Wireless AP,Antenna etc,is one of the suppliers of the Facebook. With the professional R&D teams which possess over 15 years experience,we could not only providing OEM/ODM/JDM services,but also have the ability to supporting customization service for you.From idea design to manufacture to put the product into market. Email us by sales1@wallystech.comVisit our website:https://www.wallystech.com/
页: [1]
查看完整版本: WIFI 6E/IPQ6010 CPU industrial wifi router support QCN9074 netwok card High power Wallys
