ATSAMD51 EVK评估板评测3串口发送
今天装了MPLABX和XC32编译器,搞了个串口发送的程序。代码:
* Copyright (C) 2019 Microchip Technology Inc. and its subsidiaries.
* Subject to your compliance with these terms, you may use Microchip software
* and any derivatives exclusively with Microchip products. It is your
* responsibility to comply with third party license terms applicable to your
* use of third party software (including open source software) that may
* accompany Microchip software.
* THIS SOFTWARE IS SUPPLIED BY MICROCHIP "AS IS". NO WARRANTIES, WHETHER
* EXPRESS, IMPLIED OR STATUTORY, APPLY TO THIS SOFTWARE, INCLUDING ANY IMPLIED
* WARRANTIES OF NON-INFRINGEMENT, MERCHANTABILITY, AND FITNESS FOR A
* PARTICULAR PURPOSE.
* IN NO EVENT WILL MICROCHIP BE LIABLE FOR ANY INDIRECT, SPECIAL, PUNITIVE,
* INCIDENTAL OR CONSEQUENTIAL LOSS, DAMAGE, COST OR EXPENSE OF ANY KIND
* WHATSOEVER RELATED TO THE SOFTWARE, HOWEVER CAUSED, EVEN IF MICROCHIP HAS
* BEEN ADVISED OF THE POSSIBILITY OR THE DAMAGES ARE FORESEEABLE. TO THE
* FULLEST EXTENT ALLOWED BY LAW, MICROCHIP'S TOTAL LIABILITY ON ALL CLAIMS IN
* ANY WAY RELATED TO THIS SOFTWARE WILL NOT EXCEED THE AMOUNT OF FEES, IF ANY,
* THAT YOU HAVE PAID DIRECTLY TO MICROCHIP FOR THIS SOFTWARE.
Main Source File
Company:
File Name:
main.c
Summary:
This file contains the "main" function for a project.
Description:
This file contains the "main" function for a project.The
"main" function calls the "SYS_Initialize" function to initialize the state
machines of all modules in the system
// Section: Included Files
#include <stddef.h> // Defines NULL
#include <stdbool.h> // Defines true
#include <stdlib.h> // Defines EXIT_FAILURE
#include "definitions.h" // SYS function prototypes
#include <string.h>
#define LED_ON LED_Clear
#define LED_OFF LED_Set
#define LED_TOGGLE LED_Toggle
/* Define the NVMCTRL_SEESBLK_MASK_BITS to extract the NVMCTRL_SEESBLK bits(35:32) from NVM User Page Mapping(0x00804000) */
#define NVMCTRL_SEESBLK_MASK_BITS 0x0F
/* Define the NVMCTRL_SEEPSZ_MASK_BITS to extract the NVMCTRL_SEEPSZ bits(38:36) from NVM User Page Mapping(0x00804000) */
#define NVMCTRL_SEEPSZ_MASK_BITS 0x07
/* A specific byte pattern stored at the begining of SmartEEPROM data area.
* When the application comes from a reset, if it finds this signature,
* the assumption is that the SmartEEPROM has some valid data.
#define SMEE_CUSTOM_SIG 0x5a5a5a5a
/* Define the number of bytes to be read when a read request comes */
#define MAX_BUFF_SIZE 256
/* The application toggles SmartEEPROM data at the following address
* each time the device is reset. This address must be within the total
* number of EEPROM data bytes ( Defined by SBLK and PSZ fuse values).
#define SEEP_TEST_ADDR 32
/* This example demo assumes fuses SBLK = 1 and PSZ = 3, thus total size is 4096 bytes */
#define SEEP_FINAL_BYTE_INDEX 4095
/* Define a pointer to access SmartEEPROM as bytes */
uint8_t *SmartEEPROM8 = (uint8_t *)SEEPROM_ADDR;
/* Define a pointer to access SmartEEPROM as words (32-bits) */
uint32_t *SmartEEPROM32 = (uint32_t *)SEEPROM_ADDR;
uint8_t menu[] = "\r\n******** uart send test ******** \r\n";
typedef enum {ReadSmartEEPROM = '1', WriteSmartEEPROM = '2', ResetDevice = '3', NoSelection = 0} MenuOptions;
uint8_t data_8;
uint8_t eeprom_data_buffer = {0};
* \brief Invert a byte in SmartEEPROM
* To invert the data at the given index in SmartEEPROM
void invert_seep_byte(uint8_t index)
/* Wait till the SmartEEPROM is free */
while (NVMCTRL_SmartEEPROM_IsBusy());
/* Read the data, invert it, and write it back */
data_8 = SmartEEPROM8;
printf("\r\nData at test address %d is = %d\r\n", index, (int)data_8);
SmartEEPROM8 = !data_8;
printf("\r\nInverted the data at test address and written\r\n");
* \brief Verify the custom data in SmartEEPROM
* Verify the custom data at initial 4 bytes of SmartEEPROM
int8_t verify_seep_signature(void)
uint32_t NVMCTRL_SEESBLK_FuseConfig = ((*(uint32_t *)(USER_PAGE_ADDR + 4)) >> 0) & NVMCTRL_SEESBLK_MASK_BITS;
int8_t ret_val = 0;
/* If SBLK fuse is not configured, inform the user and wait here */
if (!NVMCTRL_SEESBLK_FuseConfig)
printf("\r\nPlease configure SBLK fuse to allocate SmartEEPROM area\r\n");
while (1);
if (SMEE_CUSTOM_SIG != SmartEEPROM32)
ret_val = 0x4;
return ret_val;
* \brief Print a buffer as hex values
* Print a given array as a hex values
void print_hex_array(void *mem, uint16_t len)
unsigned char *p = (unsigned char *)mem;
for(uint32_t i = 0; i < len; i++)
if ((i != 0) && (!(i & 0x7)))
printf("\r\n");
printf("%03d ", p);
printf("\r\n");
// Section: Main Entry Point
int main ( void )
//uint32_t NVMCTRL_SEESBLK_FuseConfig= ((*(uint32_t *)(USER_PAGE_ADDR + 4)) >> 0) & NVMCTRL_SEESBLK_MASK_BITS;
//uint32_t NVMCTRL_SEEPSZ_FuseConfig = ((*(uint32_t *)(USER_PAGE_ADDR + 4)) >> 4) & NVMCTRL_SEEPSZ_MASK_BITS;
//MenuOptions user_selection = NoSelection;
uint32_t i=0;
// uint32_t num_of_bytes_to_read = 0;
// uint32_t eeprom_data = 0;
// uint32_t eeprom_addr = 0;
// uint32_t eeprom_data_buf_start_index = 0;
long int temp=0;
/* Initialize all modules */
// <editor-fold defaultstate="collapsed" desc="comment">
SYS_Initialize( NULL );
printf("%s", menu);
while ( true )
printf("temp=%ld\r\n",temp);
temp++;
for(i=0;i<50000000;i++);
/* Execution should not come here during normal operation */
return ( EXIT_FAILURE );
End of File
效果图:
另外说明一下,我装的是MPLABX IDE V5.30,需要设置一下才能下载程序。
听说V5.3版本不好用? chenjun89 发表于 2022-12-3 18:11
听说V5.3版本不好用?
感觉还行,V5.4版没用过 chenjun89 发表于 2022-12-3 18:11
听说V5.3版本不好用?
感觉还行,V5.4版没用过 感觉还行,V5.4版没用过 怎么回复了两遍,网络有问题
页:
[1]
