TIM1重映像到PE引脚不出波形,使用默认引脚时有波形
GPIO_InitTypeDef GPIO_InitStructure;GPIO_PinRemapConfig(GPIO_FullRemap_TIM1,ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO|RCC_APB2Periph_GPIOE|RCC_APB2Periph_TIM1,ENABLE);
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP;
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11|GPIO_Pin_12|GPIO_Pin_13;
GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
GPIO_Init(GPIOE,&GPIO_InitStructure); 如果不做REMAP是否能正常输出呢?
注意stm32f1系列的TIM1 的 Full remap 仅限于100脚和144脚封装;
另外 请注意TIM1的时钟是APB2 以及需使能其MOE.
不做REMP能输出我用的是STMF103VET6 100引脚的
void TIM1_GPIO_Configuration(void)
// RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_TIM1,ENABLE);
// GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP;
// GPIO_InitStructure.GPIO_Pin=GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11|GPIO_Pin_12|GPIO_Pin_13;
// GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
// GPIO_Init(GPIOA,&GPIO_InitStructure);
void TIM1_MODE_Configuration(void)
TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStructure;
TIM_OCInitTypeDef TIM_OCInitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
TIM_BDTRInitTypeDef TIM_BDTRInitStructure;
TIM_TimeBaseInitStructure.TIM_Period=14399;
TIM_TimeBaseInitStructure.TIM_Prescaler=0;
TIM_TimeBaseInitStructure.TIM_ClockDivision=TIM_CKD_DIV1;
TIM_TimeBaseInitStructure.TIM_CounterMode=TIM_CounterMode_CenterAligned1;
TIM_TimeBaseInitStructure.TIM_RepetitionCounter=0;
TIM_TimeBaseInit(TIM1,&TIM_TimeBaseInitStructure);
TIM_OCInitStructure.TIM_OCMode=TIM_OCMode_PWM2;
TIM_OCInitStructure.TIM_OutputState=TIM_OutputState_Enable;
TIM_OCInitStructure.TIM_OutputNState=TIM_OutputNState_Enable;
TIM_OCInitStructure.TIM_Pulse=0;
TIM_OCInitStructure.TIM_OCPolarity=TIM_OCPolarity_Low;
TIM_OCInitStructure.TIM_OCNPolarity=TIM_OCNPolarity_Low;
TIM_OCInitStructure.TIM_OCIdleState=TIM_OCIdleState_Set;
TIM_OCInitStructure.TIM_OCNIdleState=TIM_OCNIdleState_Reset;
TIM_OC1Init(TIM1,&TIM_OCInitStructure);
TIM_OC1PreloadConfig(TIM1,TIM_OCPreload_Enable);
TIM_OC2Init(TIM1,&TIM_OCInitStructure);
TIM_OC2PreloadConfig(TIM1,TIM_OCPreload_Enable);
TIM_OC3Init(TIM1,&TIM_OCInitStructure);
TIM_OC3PreloadConfig(TIM1,TIM_OCPreload_Enable);
// TIM_OCInitStructure.TIM_OutputState=TIM_OutputState_Enable;
// TIM_OCInitStructure.TIM_Pulse=125;
// TIM_OC4Init(TIM1,&TIM_OCInitStructure);
// TIM_OC4PreloadConfig(TIM1,TIM_OCPreload_Enable);
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
NVIC_InitStructure.NVIC_IRQChannel=TIM1_UP_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority=0;
NVIC_InitStructure.NVIC_IRQChannelCmd=ENABLE;
NVIC_Init(&NVIC_InitStructure);
TIM_ITConfig(TIM1,TIM_IT_Update,ENABLE);
TIM_BDTRInitStructure.TIM_OSSRState=TIM_OSSRState_Disable;
TIM_BDTRInitStructure.TIM_OSSIState=TIM_OSSIState_Disable;
TIM_BDTRInitStructure.TIM_LOCKLevel=TIM_LOCKLevel_OFF;
TIM_BDTRInitStructure.TIM_DeadTime=0;
TIM_BDTRInitStructure.TIM_Break=TIM_Break_Disable;
TIM_BDTRInitStructure.TIM_BreakPolarity=TIM_BreakPolarity_High;
TIM_BDTRInitStructure.TIM_AutomaticOutput=TIM_AutomaticOutput_Enable;
TIM_BDTRConfig(TIM1,&TIM_BDTRInitStructure);
TIM_ARRPreloadConfig(TIM1,ENABLE);
TIM_Cmd(TIM1,ENABLE);
TIM_CtrlPWMOutputs(TIM1,ENABLE);
记得开启AFIO时钟, RCC_APB2ENR_AFIOEN
问题解决了,是REMAP函数位置放错了。
放到哪里了
是不是时钟没开 不做REMAP是否能正常输出 REMAP函数放哪了? 是不是时钟没配置好啊 TIM1的时钟是APB2 时钟没打开吗? 不做REMAP是否能正常输出 重映像之后还需要对相关的引脚进行配置才可以使用 这个引脚的时钟源好像不是楼主配置的这个时钟啊 REMAP函数应该放在哪个函数的后边比较合适呢 这个函数的作用是什么 在初始化过程中它的位置有什么影响呢
页:
[1]
