IPQ6010 QCN9074 high power industrial wifi router support openWRT/Wallys 802.11ax boards DR6018V4
IPQ6010 QCN9074 high power industrial wifi router support openWRT/Wallys 802.11ax boards DR6018V4 802.11ac and 802.11ax are different wireless (WiFi) technology standards that are present in WiFi routers or gateways.WiFi and Internet capabilities are constantly evolving. Up until 2019, the most common wireless standard called for 802.11ac, also referred to as WiFi 5. However, in late 2019, 802.11ax (also known as WiFi 6) was launched, providing enhanced capabilities over its predecessor. These two WiFi standards are important to understand because they determine what devices you will need for your home network, which features they support, and the overall performance of your WiFi. 802.11ac is the 5th generation in WiFi standards and was introduced around 2013.802.11ac is commonly referred to as WiFi 5 and was developed by the Wi-Fi Alliance to achieve gigabit speeds, meaning WiFi 5 could provide speeds up to 3.5 Gbps under optimal conditions.In addition to faster speeds, WiFi 5 offered wider WiFi frequency channels that allowed wireless devices to send and receive more data, resulting in faster overall performance.WiFi 5 (802.11ac) also introduced MU-MIMO technology that facilitated data to be sent to multiple devices simultaneously.Most notably, WiFi 5 was developed to only use the 5GHz wireless frequency, rather than both 2.4 GHz and 5 GHz frequencies. 802.11ax, or WiFi 6, is the latest WiFi standard and is the highest performing.WiFi 6 is capable of speeds up to 9.6 Gbps which means its faster than WiFi 5, making it better for video streaming, online gaming and more high-bandwidth applications.WiFi 6 offers more efficient data management for faster speeds and supports both the 2.4 GHz and 5 GHz frequencies for faster Internet across both frequency channels.A new feature called “Targeted Wake Time (TWT)” allows your router to put the WiFi connection to “sleep” when not in use, saving the battery life of your smartphones, laptops and other connected devices until they are needed.WiFi 6 has the power to higher number of connected devices and deliver more data to those devices, meaning you will have a much faster and more efficient Internet connection to all devices. Here I would like to introduce you wallys 802.11ax boards and cards.They are: DR6018 V4DR6018C V01DR6018-S V02DR8072 V01DR5018DR9074-6E(PN02.7)DR9074-5G(PN02.1)DR9074-2.4G(PN01.1) And today let’s talk about the DR6018V4 first. DR6018 V4 This is a router board integrated with Qualcomm-Atheros IPQ6010 CPU,Processor with Quad-core ARM 64bit A53 @1.8GHz,and the System Memory is 1GB DDRL3L.32MB NOR Flash, 256MB NAND Flash,Supports Dynamic Frequency Selection (DFS),2x2 On-board 2.4GHz radio, up to 573Mbps physical Data Rate,2x2 On-board 5GHz radio, up to 1201Mbps physical Data Rate,support: QUECTEL RM500Q-GL,support: QCN9074 WiFi 6E Card. Regard to the Absolute Maximum Rating of DR6018V4,we’ll introduce from 4 perspectives parameters:Supply Voltage,Operating Temperature Range,Storage Temperature Range and Operating Humidity Range. For the Supply Voltage,it is 24V~48V.For the Operating Temperature Range,it is -40ºC to +70ºC.For the Storage Temperature Range,it is -45ºC to +105ºC.For the Operating Humidity Range,It is 5 to +95 (non-condensing)%. Regard to the Hardware Specifications of DR6018V4,we’ll introduce from 17 perspectives:CPU,CPU Frequency,system memory,ethernet port,NGFF Slot,SD card Slot,USB,POE,DC Jack,LED header,Serial Port,Wireless,Bluetooth,Nor Flash,Nand Flash,DDR and Dimension. For the CPU,it is Qualcomm-Atheros IPQ6010.For the CPU Frequency,it is Quad-core ARM 64 bit A53 @1.8 GHz processor.For the System Memory,it is 1GB (2x 512MB) DDR3L 16-bit interface with 32-bit memory bus design.For the Ethernet Port,It is 1 x 1Gbps Ethernet Ports & POE3 x 1Gbps Ethernet Ports , 1x 2.5Gbps Ethernet Port.For the NGFF Slot,It is M.2 (NGFF) “E Key” Socket with MiniPCIe 3.0 For the SD Card Slot,It is 1x SD Card SlotFor the USB /header,It is 1x USB 2.0 PortFor the POE,It is 24V~48V passive POE/Active POE(Suport 802.3bt)For the DC Jack,It is 24V power supplyFor the LED header,It is FFC/FPC ConnectorFor the Serial Port,It is 1x Serial Port 4 Pin ConnectorFor the Wireless,It is On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/802.11g/802.11n/802.11ax,max 23dBm per chain;On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain;4 x MMCX ConnectorsFor the Bluetooth,It is optionalFor the Nor Flash,It is 8-32MB(normally is 8MB)For the Nand Flash,It is 256MBFor the DDR,It is 1GBFor the Dimension,It is 185mm x 116mm. Wallys Communications(Suzhou) Co.,Ltd,known as a specialist in researching and developing and producing of wireless communication products,have star product as Routerboard,Network Card,Industrial Wireless AP,Antenna etc,is one of the suppliers of the Facebook. With the professional R&D teams which possess over 15 years experience,we could not only providing OEM/ODM/JDM services,but also have the ability to supporting customization service for you.From idea design to manufacture to put the product into market. Email us by sales1@wallystech.comFor more information,visit our website:https://www.wallystech.com/
页:
[1]
