lilywallys 发表于 2022-12-15 09:59
IPQ5018 QCN9074 wifi 6e support BT5.1/Wallys 802.11ax boards DR5018
IPQ5018 QCN9074 wifi 6e support BT5.1/Wallys 802.11ax boards DR5018 802.11ac and 802.11ax are different wireless (WiFi) technology standards that are present in WiFi routers or gateways.WiFi and Internet capabilities are constantly evolving. Up until 2019, the most common wireless standard called for 802.11ac, also referred to as WiFi 5. However, in late 2019, 802.11ax (also known as WiFi 6) was launched, providing enhanced capabilities over its predecessor. These two WiFi standards are important to understand because they determine what devices you will need for your home network, which features they support, and the overall performance of your WiFi. Here are wallys 802.11ax boards and cards.DR6018 V4DR6018C V01DR6018-S V02DR8072 V01DR5018DR9074-6E(PN02.7)DR9074-5G(PN02.1)DR9074-2.4G(PN01.1) We have introduced DR6018V4,DR6018C V01,DR6018-S V02,DR8072 V01 in previous articles and today let’s talk about the DR5018. DR5018IPQ5018,802.11AX,WIFI6E,QCN9074,SUPPORT BT5.1This is a router board integrated with Qualcomm Atheros IPQ5018 CPU,processor with dual-core ARM 64bit A53@1.0GHz,and the System Memory is 512MB DDR3L.4 MB NOR Flash, 128MB NAND Flash,2x2 On-board 2.4GHz radio, up to 573Mbps physical data rate,Support BT5.1,M.2 Card Slot for 5G (QUECTEL RM 500Q-GL) ;M.2 Card Slot for QCN9074 WIFI 6E Card. Regard to the Absolute Maximum Rating,we’ll introduce from 4 perspectives parameters:Supply Voltage,Operating Temperature Range,Storage Temperature Range,Operating Humidity Range. For the Supply Voltage,It is 12V.For the Operating Temperature Range,it is -40 to +70ºC.For the Storage Temperature Range,it is -45 to +105ºC.For the Operating Humidity Range,it is 5 to +95 (non-condensing)%. Regard to the Hardware Specifications,we’ll introduce from 16 perspectives:For the CPU,it is Qualcomm-Atheros IPQ5018.For the CPU Frequency,it is Dual-core ARM 64 bit A53 @1.0 GHz processor.For the System Memory,it is 512MB DDR3L 16-bit interface with 32-bit memory bus design.For the Ethernet Port,it is 4 x 1Gbps Ethernet Portsor 1 x 1Gbps Ethernet Port & PoeFor the NGFF Slot,it is M.2 Card Slot for 5G (QUECTEL RM 500Q-GL) ;M.2 Card Slot for QCN9074 WIFI 6E CardFor the EMMC,it is 4G/8G(optional)For the USB /header,it is 1x USB 3.0 PortFor the DC Jack,it is 12V power supplyFor the LED header,LED for power,Wifi strengthFor the Serial Port,support.For the Wireless,It is On-board 2x22.4GHz MU-MIMO OFDMA 802.11b/802.11g/802.11n/802.11ax,max 23dBm per chain,2x IPEX ConnectorsFor the Bluetooth,It is BT5.1For the Nor Flash,It is 8MBFor the Nand Flash,It is 128 MBFor the DDR,It is 512MB.For the Dimension,It is 170mm x 120mm x 15m. Wallys Communications(Suzhou) Co.,Ltd,known as a specialist in researching and developing and producing of wireless communication products,have star product as Routerboard,Network Card,Industrial Wireless AP,Antenna etc,is one of the suppliers of the Facebook. With the professional R&D teams which possess over 15 years experience,we could not only providing OEM/ODM/JDM services,but also have the ability to supporting customization service for you.From idea design to manufacture to put the product into market. Email us by sales1@wallystech.comFor more information,visit our website:https://www.wallystech.com/
页: [1]
查看完整版本: IPQ5018 QCN9074 wifi 6e support BT5.1/Wallys 802.11ax boards DR5018
