MUG51 UART1中断收发
/* SPDX-License-Identifier: Apache-2.0 */
/* Copyright(c) 2022 Nuvoton Technology Corp. All rights reserved. */
/*File Function: MUG51 UART1 with interrupt demo */
#include "MUG51.h"
//#defineUART1_TX_only
#defineUART1_RXTX_loop
* FUNCTION_PURPOSE: Main function
!!! if UART1 pin also occupied by debug pin,
please remove Nu-link or not in debug mode to test UART1 function.
External UART1 connect also disturb debug download
void main (void)
MFP_P23_UART1_TXD;
P23_QUASI_MODE;
MFP_P22_UART1_RXD;
P22_INPUT_MODE;
UART_Open(FSYSCLK,UART1_Timer3,115200);
ENABLE_UART1_INTERRUPT; //For interrupt enable , interrupt subroutine is in uart.c file
ENABLE_GLOBAL_INTERRUPT; //Enable global interrupt
#if defined UART1_TX_only
while(1)
UART_Send_Data(UART1,0x55);
_delay_();
#elif defined UART1_RXTX_loop
while(1)
if (uart1_receive_flag)
uart1_receive_flag = 0;
UART_Send_Data(UART1,uart1_receive_data);
#endif
while(1);
#include "MUG51.h"
bit UART0PRINTFG=0,UART1PRINTFG=0, uart0_receive_flag = 0, uart1_receive_flag;
unsigned char uart0_receive_data, uart1_receive_data;
void Enable_P31_UART0_VCOM_115200_printf(void)
/* UART0 initial setting
** include uart.c in Library for UART initial setting
**UART0 define P3.1 TXD multi function setting
MFP_P31_UART0_TXD;
P31_QUASI_MODE;
UART_Open(FSYSCLK,UART0_Timer3,115200);
ENABLE_UART0_PRINTF;
void Enable_P31_UART0_VCOM_38400_printf(void)
MFP_P31_UART0_TXD;
P31_QUASI_MODE;
UART_Open(FSYSCLK,UART0_Timer3,38400);
#if 0
/* UART0 interrupt subroutine */
* @brief UART0 interrupt subroutine
* @param UART0~3, baudrate value
* @return none
* @Details none
* @NOTE Since printf function TI must be 1. Check with printf flag, for printf enable, not clear TI .
void UART0_ISR(void) interrupt 4
_push_(SFRS);
if (RI)
uart0_receive_flag = 1;
uart0_receive_data = SBUF;
clr_SCON_RI; // Clear RI (Receive Interrupt).
if (TI)
// if (!UART0PRINTFG)
// TI = 0;
_pop_(SFRS);
#endif
/* UART1 interrupt subroutine */
void UART1_ISR(void) interrupt 15
_push_(SFRS);
if (RI_1)
uart1_receive_flag = 1;
uart1_receive_data = SBUF1;
RI_1=0; /* clear reception flag for next reception */
if (TI_1)
if (!UART1PRINTFG)
TI_1 = 0; /* if emission occur */
_pop_(SFRS);
* @brief UART no interrupt enable setting
* @return none
* @details none
* @note max baud rate = 230400 when Fsys = 7.3728MHz
//**** UART Enable Setting
//**** 1. Define Fsys value(value)
//**** 2. Select UART port(UART0_Timer1 / UART0_Timer3 / UART1_Timer3 / UART2/UART3)
//**** 3. Define baudrate (value)
//**** For example: UART_Open(FSYSCLK,UART0_Timer3,115200)
void UART_Open(unsigned long u32SysClock, unsigned char u8UARTPort,unsigned long u32Baudrate)
switch(u8UARTPort)
case UART0_Timer1:
case UART0:
SFRS = 0x00;
SCON = 0x50; /*UART0 Mode1,REN=1,TI=1 */
TMOD |= 0x20; /*Timer1 Mode1*/
set_PCON_SMOD; /*UART0 Double Rate Enable*/
set_CKCON_T1M;
clr_T3CON_BRCK; /*Serial port 0 baud rate clock source = Timer1*/
TH1 = 256 - (u32SysClock/16/u32Baudrate);
set_TCON_TR1;
break;
case UART0_Timer3:
SFRS = 0x00;
SCON = 0x50; /*UART0 Mode1,REN=1,TI=1*/
T3CON &= 0xF8; /*T3PS2=0,T3PS1=0,T3PS0=0(Prescale=1)*/
set_T3CON_BRCK; /*UART0 baud rate clock source = Timer3*/
RH3 = HIBYTE(65536 - (u32SysClock/16/u32Baudrate));
RL3 = LOBYTE(65536 - (u32SysClock/16/u32Baudrate));
set_T3CON_TR3; /*Trigger Timer3*/
break;
case UART1_Timer3:
case UART1:
SFRS = 0x00;
S1CON = 0x50; /*UART1 Mode1,REN_1=1 */
T3CON = 0x88; /*T3PS2=0,T3PS1=0,T3PS0=0(Prescale=1), UART1 in MODE 1*/
set_T3CON_TR3; /* Trigger Timer3 */
break;
//**** UART Receive data without interrupt
//**** For example: UART_Open(UART0_Timer1,1200)
unsigned char UART_Receive_Data(unsigned char UARTPort)
unsigned char c;
SFRS = 0x00;
switch (UARTPort)
case UART0:
while (!RI);
c = SBUF;
RI = 0;
break;
case UART1:
while (!RI_1);
c = SBUF1;
RI_1 = 0;
break;
return (c);
//**** UART transfer data without interrupt
//**** For example: UART_Send_Data(UART0,0x55)
void UART_Send_Data(unsigned char UARTPort, unsigned char c)
SFRS = 0x00;
switch (UARTPort)
case UART0:
TI = 0;
SBUF = c;
while(TI==0);
TI = 0;
break;
case UART1:
TI_1 = 0;
SBUF1 = c;
while(TI_1==0);
TI_1 = 0;
break;
* @brief UART interrupt enable setting
* @param u8UARTPort: UART0/UART1/UART2/UART3 baudrate value
* @param u8UARTINTStatus: Disable/Enable
* @return none
* @details none
* @note max baud rate =230400 when Fsys = 7.3728MHz
void UART_Interrupt_Enable(unsigned char u8UARTPort, unsigned char u8UARTINTStatus)
switch (u8UARTPort)
case UART0:
switch(u8UARTINTStatus)
case Disable: clr_IE_ES; break;
case Enable:set_IE_ES; break;
break;
case UART1:
case Disable: clr_EIE1_ES1; break;
case Enable:set_EIE1_ES1; break;
break;
页:
[1]
