9dome猫 发表于 2022-12-24 14:21
STM32F407 HAL库外扩SRAM作为默认RAM使用
       项目使用STM32F407ZET6开发,但自带的RAM空间不够,所以需要外扩SRAM作为默认的RAM来使用,使用的SRAM是IS62WV51216BLL,19条地址线,16条数据线,使用的库为HAL库。
      外扩的SRAM使用FSMC的NE3作为硬件接口,所以外扩的重要步骤其实是NE3作为SRAM的初始化。
第一步:勾选魔术棒下面的选项,这样才能使其作为默认的RAM来分配变量
9dome猫 发表于 2022-12-24 14:26
那么我们需要先将DATA_IN_ExtSRAM添加到魔术棒C/C++选项的Define中,这样SystemInit才会调用SystemInit_ExtMemCtl函数
9dome猫 发表于 2022-12-24 14:37
    下一步就是修改寄存器的配置,SystemInit_ExtMemCtl函数407部分FSMC的配置默认是NE2的。找到407部分(有2部分,一部分为引脚配置,一部分为FSMC配置,找到有defined(STM32F407xx)字样的代码部分就是)将寄存器配置修改为以下内容
#if defined(STM32F405xx) || defined(STM32F415xx) || defined(STM32F407xx) || defined(STM32F417xx)\
|| defined(STM32F427xx) || defined(STM32F437xx) || defined(STM32F429xx) || defined(STM32F439xx)\
|| defined(STM32F469xx) || defined(STM32F479xx) || defined(STM32F412Zx) || defined(STM32F412Vx)
#if defined(DATA_IN_ExtSRAM)
/*-- GPIOs Configuration -----------------------------------------------------*/
   /* Enable GPIOD, GPIOE, GPIOF and GPIOG interface clock */
RCC->AHB1ENR   |= 0x00000078;
/* Delay after an RCC peripheral clock enabling */
tmp = READ_BIT(RCC->AHB1ENR, RCC_AHB1ENR_GPIODEN);
/* Connect PDx pins to FMC Alternate function */
GPIOD->AFR= 0x00CC00CC;
GPIOD->AFR= 0xCCCCCCCC;
/* Configure PDx pins in Alternate function mode */
GPIOD->MODER   = 0xAAAA0A0A;
/* Configure PDx pins speed to 100 MHz */
GPIOD->OSPEEDR = 0xFFFF0F0F;
/* Configure PDx pins Output type to push-pull */
GPIOD->OTYPER= 0x00000000;
/* No pull-up, pull-down for PDx pins */
GPIOD->PUPDR   = 0x00000000;
/* Connect PEx pins to FMC Alternate function */
GPIOE->AFR= 0xC00000CC;
GPIOE->AFR= 0xCCCCCCCC;
/* Configure PEx pins in Alternate function mode */
GPIOE->MODER   = 0xAAAA800A;
/* Configure PEx pins speed to 100 MHz */
GPIOE->OSPEEDR = 0xFFFFC00F;
/* Configure PEx pins Output type to push-pull */
GPIOE->OTYPER= 0x00000000;
/* No pull-up, pull-down for PEx pins */
GPIOE->PUPDR   = 0x00000000;
/* Connect PFx pins to FMC Alternate function */
GPIOF->AFR= 0x00CCCCCC;
GPIOF->AFR= 0xCCCC0000;
/* Configure PFx pins in Alternate function mode */
GPIOF->MODER   = 0xAA000AAA;
/* Configure PFx pins speed to 100 MHz */
GPIOF->OSPEEDR = 0xFF000FFF;
/* Configure PFx pins Output type to push-pull */
GPIOF->OTYPER= 0x00000000;
/* No pull-up, pull-down for PFx pins */
GPIOF->PUPDR   = 0x00000000;
/* Connect PGx pins to FMC Alternate function */
GPIOG->AFR= 0x00CCCCCC;
GPIOG->AFR= 0x00000C00;
/* Configure PGx pins in Alternate function mode */
GPIOG->MODER   = 0x00200AAA;
/* Configure PGx pins speed to 100 MHz */
GPIOG->OSPEEDR = 0x000C03FF;
/* Configure PGx pins Output type to push-pull */
GPIOG->OTYPER= 0x00000000;
/* No pull-up, pull-down for PGx pins */
GPIOG->PUPDR   = 0x00000000;
/*-- FMC/FSMC Configuration --------------------------------------------------*/
/* Enable the FMC/FSMC interface clock */
RCC->AHB3ENR         |= 0x00000001;
9dome猫 发表于 2022-12-24 14:41
第二部分FSMC配置:
#if defined(STM32F405xx) || defined(STM32F415xx) || defined(STM32F407xx)|| defined(STM32F417xx)\
tmp = READ_BIT(RCC->AHB3ENR, RCC_AHB3ENR_FSMCEN);
/* Configure and enable Bank1_SRAM2 */
FSMC_Bank1->BTCR= 0x00001011;
FSMC_Bank1->BTCR= 0x00000201;
FSMC_Bank1E->BWTR = 0x0FFFFFFF;
9dome猫 发表于 2022-12-24 14:43
    需要注意的是,我是19条地址线,16条数据线,即地址为19位,数据位为16位,如果不同自己需要修改对应寄存器,包括引脚部分配置,最好能百度下这些寄存器意义,然后对照电路图设置即可。
到这步就成功了,可以写个程序验证往对应RAM地址写数据是否成功或者对应外设运行在该段RAM中是否能初始化成功,能正常使用(我自己的使用体验的话,初始化不成功,连main函数都进入不了就会跑飞)。
9dome猫 发表于 2022-12-24 14:44
隔断一下,聊一下1.使用库函数写初始化函数再在启动函数中调用的方式,还有2.在main函数中初始化FSMC 这2种方式。
第一种方式,如果使用官方库而不是HAL库,是可以运行的,我使用正点原子官方库例程修改后可以运行,但是使用HAL库,直接无法进入main程序跑飞,取消勾选第一张图配置,可以正常运行,但各项外设初始化无法成功,实际上无法使用。
第二种方式,只能是不作为默认RAM使用时这样配置。
至于这2种情况是为什么,个人时间和能力有限,没有去深究
huangcunxiake 发表于 2022-12-25 17:35
HAL库是目前最好用的了。
Bowclad 发表于 2023-1-1 17:36
现在还有更接近底层的LL库
MessageRing 发表于 2023-1-3 13:43
还是标准库好用
AdaMaYun 发表于 2023-1-4 14:41
HAL库就是封装的比较猛,移植性比较强,标准库就是将寄存器封装好,移植性没有HAL好。HAL库最方便的就是可以用CUBEMX自动生成代码,动态的调用资源,不会出现地城配置上的冲突
ulystronglll 发表于 2023-1-6 14:36
这个ram的速度怎么样?
sesefadou 发表于 2023-1-6 16:07
可以换成f411的
fengm 发表于 2023-1-12 11:36
FSMC的接口的访问速度很一般。
alvpeg 发表于 2023-1-16 15:14
sram怎么移植代码过去?
lzbf 发表于 2023-1-19 12:24
STM32F407怎么直接访问呢?
页: [1]
查看完整版本: STM32F407 HAL库外扩SRAM作为默认RAM使用
