梵蒂冈是神uy 发表于 2022-12-25 13:48
STM32L053基于LL库、HAL库两种库RTC闹钟唤醒
STM32L053闹钟唤醒:
设置实现原理,当闹钟时间==日历时间时,闹钟中断产生,但是闹钟中断与外部中断线17相连,所以如果不初始化外部中断线17,则无法进入RTC中断服务函数。
目的:实现毫米级闹钟中断唤醒睡眠模式
设置日历时间=闹钟时间,启用闹钟的亚秒寄存器,用亚秒寄存器产生毫秒级的计时
进入中断之后,再重新设置日历时间=闹钟时间。
注意:中断之中也要清除外部中断标志
版权声明:本文为CSDN博主「火红色祥云」的原创文章,遵循CC 4.0 BY-SA版权协议,转载请附上原文出处链接及本声明。
原文链接:https://blog.csdn.net/weixin_43739167/article/details/108038431
梵蒂冈是神uy 发表于 2022-12-25 13:49
HAL库
RTC_HandleTypeDef hrtc;
RTC_TimeTypeDef sTime = {0};
RTC_AlarmTypeDef sAlarm = {0};
* @briefRTC中断初始化,用于睡眠定时唤醒
* @param
* @retval
void rtc_INT_init(uint16_t ms)
hrtc.Instance = RTC;
hrtc.Init.HourFormat = RTC_HOURFORMAT_24;                                                //LL_RTC_SetHourFormat(RTC_TypeDef *RTCx, uint32_t HourFormat);
hrtc.Init.AsynchPrediv = 36;        //LL_RTC_SetAsynchPrescaler(RTC_TypeDef *RTCx, uint32_t AsynchPrescaler);
hrtc.Init.SynchPrediv = ms;        //LL_RTC_SetSynchPrescaler(RTC_TypeDef *RTCx, uint32_t SynchPrescaler);
hrtc.Init.OutPut = RTC_OUTPUT_DISABLE;                                                        //
hrtc.Init.OutPutRemap = RTC_OUTPUT_REMAP_NONE;                        //LL_RTC_DisableOutRemap(RTC_TypeDef *RTCx);
hrtc.Init.OutPutPolarity = RTC_OUTPUT_POLARITY_HIGH;//LL_RTC_SetOutputPolarity(RTC_TypeDef *RTCx, uint32_t Polarity);
hrtc.Init.OutPutType = RTC_OUTPUT_TYPE_OPENDRAIN;                //LL_RTC_SetAlarmOutputType(RTC_TypeDef *RTCx, uint32_t Output);
HAL_RTC_Init(&hrtc);
/** Initialize RTC and set the Time
sTime.Hours = 0x08;        //LL_RTC_TIME_SetHour(RTC_TypeDef *RTCx, uint32_t Hours)
sTime.Minutes = 0x30;        //LL_RTC_TIME_SetMinute(RTC_TypeDef *RTCx, uint32_t Minutes)
sTime.Seconds = 0x10;        //LL_RTC_TIME_SetSecond(RTC_TypeDef *RTCx, uint32_t Seconds)
sTime.TimeFormat = RTC_HOURFORMAT12_AM;                                                        //LL_RTC_TIME_SetFormat(RTC_TypeDef *RTCx, uint32_t TimeFormat);
sTime.DayLightSaving = RTC_DAYLIGHTSAVING_NONE ;                //LL_RTC_TIME_DisableDayLightStore(RTC_TypeDef *RTCx)
sTime.StoreOperation = RTC_STOREOPERATION_RESET;                //
HAL_RTC_SetTime(&hrtc,&sTime,RTC_FORMAT_BCD);
/** Enable the Alarm A
sAlarm.Alarm = RTC_ALARM_A;        //LL_RTC_ALMA_Enable(RTC_TypeDef *RTCx)
sAlarm.AlarmDateWeekDay = RTC_WEEKDAY_MONDAY;                                //LL_RTC_ALMA_SetWeekDay(RTC_TypeDef *RTCx, uint32_t WeekDay)
sAlarm.AlarmDateWeekDaySel = RTC_ALARMDATEWEEKDAYSEL_WEEKDAY;
sAlarm.AlarmMask = RTC_ALARMMASK_DATEWEEKDAY;                                //LL_RTC_ALMA_SetMask(RTC_TypeDef *RTCx, uint32_t Mask)
sAlarm.AlarmSubSecondMask = RTC_ALARMSUBSECONDMASK_NONE;//LL_RTC_ALMA_SetSubSecondMask(RTC_TypeDef *RTCx, uint32_t Mask)
sAlarm.AlarmTime.TimeFormat = RTC_HOURFORMAT12_AM;        //LL_RTC_ALMA_SetTimeFormat(RTC_TypeDef *RTCx, uint32_t TimeFormat);
sAlarm.AlarmTime.Hours = 0x08;        //LL_RTC_ALMA_SetHour(RTC_TypeDef *RTCx, uint32_t Hours)
sAlarm.AlarmTime.Minutes = 0x30;        //LL_RTC_ALMA_SetMinute(RTC_TypeDef *RTCx, uint32_t Minutes)
sAlarm.AlarmTime.Seconds = 0x10;        //LL_RTC_ALMA_SetSecond(RTC_TypeDef *RTCx, uint32_t Seconds)
sAlarm.AlarmTime.SubSeconds = 1;        //LL_RTC_ALMA_SetSubSecond(RTC_TypeDef *RTCx, uint32_t Subsecond)
HAL_RTC_SetAlarm_IT(&hrtc,&sAlarm,RTC_FORMAT_BCD);
        HAL_NVIC_SetPriority(RTC_IRQn, 0, 0);
HAL_NVIC_EnableIRQ(RTC_IRQn);
        __HAL_RCC_RTC_ENABLE();        //LL_RTC_EnableIT_ALRA(RTC_TypeDef *RTCx)
void RTC_IRQHandler(void)
/* USER CODE BEGIN RTC_IRQn 0 */
/* USER CODE END RTC_IRQn 0 */
HAL_RTC_AlarmIRQHandler(&hrtc);
/* USER CODE BEGIN RTC_IRQn 1 */
/* USER CODE END RTC_IRQn 1 */
uint32_t count=0;
/* USER CODE BEGIN 1 */
void HAL_RTC_AlarmAEventCallback(RTC_HandleTypeDef *hrtc)
        count++;
        debug_print(0, "Enter Count%d\r\n",count);
        HAL_RTC_SetTime(hrtc, &sTime, RTC_FORMAT_BCD);
LL库
        LL_RTC_InitTypeDef RTC_InitStruct = {0};
LL_RTC_TimeTypeDef RTC_TimeStruct = {0};
LL_RTC_AlarmTypeDef RTC_AlarmStruct = {0};
        LL_EXTI_InitTypeDef EXTI_InitStruct = {0};
        LL_RTC_TimeTypeDef RTC_ALMA_InitStruct = {0};
        LL_RCC_EnableRTC();
        NVIC_SetPriority(RTC_IRQn, 2);
        EXTI_InitStruct.Line_0_31 = LL_EXTI_LINE_17;
EXTI_InitStruct.LineCommand = ENABLE;
EXTI_InitStruct.Mode = LL_EXTI_MODE_IT;
EXTI_InitStruct.Trigger = LL_EXTI_TRIGGER_RISING;
LL_EXTI_Init(&EXTI_InitStruct);
        RTC_InitStruct.HourFormat=LL_RTC_HOURFORMAT_24HOUR;
        RTC_InitStruct.AsynchPrescaler=36;
        RTC_InitStruct.SynchPrescaler=ms;
        LL_RTC_Init(RTC, &RTC_InitStruct);
        RTC_TimeStruct.TimeFormat=LL_RTC_TIME_FORMAT_AM_OR_24;
        RTC_TimeStruct.Hours=0x8;
        RTC_TimeStruct.Minutes=0x30;
        RTC_TimeStruct.Seconds=0x10;
        LL_RTC_TIME_Init(RTC, LL_RTC_FORMAT_BCD, &RTC_TimeStruct);
        RTC_ALMA_InitStruct.TimeFormat=LL_RTC_TIME_FORMAT_AM_OR_24;
        RTC_ALMA_InitStruct.Hours=0x8;
        RTC_ALMA_InitStruct.Minutes=0x30;
        RTC_ALMA_InitStruct.Seconds=0x10;
        LL_RTC_TIME_Init(RTC, LL_RTC_FORMAT_BCD, &RTC_ALMA_InitStruct);
        RTC_AlarmStruct.AlarmDateWeekDay=RTC_WEEKDAY_MONDAY;
        RTC_AlarmStruct.AlarmDateWeekDaySel=LL_RTC_ALMA_DATEWEEKDAYSEL_WEEKDAY;
        RTC_AlarmStruct.AlarmMask=LL_RTC_ALMA_MASK_DATEWEEKDAY;
        RTC_AlarmStruct.AlarmTime=RTC_ALMA_InitStruct;
        LL_RTC_ALMA_Init(RTC, LL_RTC_FORMAT_BCD, &RTC_AlarmStruct);
        LL_RTC_DisableWriteProtection(RTC);
        LL_RTC_ALMA_SetSubSecond(RTC, 1);
        LL_RTC_ALMA_SetMask(RTC, LL_RTC_ALMA_MASK_DATEWEEKDAY);
        LL_RTC_ALMA_SetSubSecondMask(RTC, 0xF);
        LL_RTC_ALMA_Enable(RTC);
        LL_RTC_EnableIT_ALRA(RTC);
        LL_RTC_EnableWriteProtection(RTC);
        LL_RTC_TimeTypeDef RTC_RstTimeStruct = {0};
        if(LL_RTC_IsActiveFlag_ALRA(RTC))
                printf("IRQn WKUP Timer Enter...\r\n");
                LL_RTC_ClearFlag_ALRA(RTC);
                LL_EXTI_ClearFlag_0_31(LL_EXTI_LINE_17);
        RTC_RstTimeStruct.TimeFormat=LL_RTC_TIME_FORMAT_AM_OR_24;
        RTC_RstTimeStruct.Hours=0x8;
        RTC_RstTimeStruct.Minutes=0x30;
        RTC_RstTimeStruct.Seconds=0x10;
        LL_RTC_TIME_Init(RTC, LL_RTC_FORMAT_BCD, &RTC_RstTimeStruct);
minzisc 发表于 2023-1-5 10:48
LL库还在使用的吗?
OKAKAKO 发表于 2023-1-5 11:42
标准库是不是已经停更了,现在都说HAL 库是主流了
LOVEEVER 发表于 2023-1-6 14:08
只要能实现功能,那个方法都可以
tabmone 发表于 2023-1-7 16:40
这个不错。
robincotton 发表于 2023-1-9 11:41
网上有教程可以学习的吗?
小小蚂蚁举千斤 发表于 2023-1-9 15:52
俩个对比,楼主这个不错,不过现在是不是hal库用的多啊
kmzuaz 发表于 2023-1-10 19:51
RTC掉电数据丢失怎么解决呢?
sdlls 发表于 2023-1-12 15:51
HAL库的RTC有bug
mattlincoln 发表于 2023-1-12 18:37
hal设置不了RTC的时间呢
maqianqu 发表于 2023-1-12 20:05
这个RTC精度怎么样
primojones 发表于 2023-1-12 21:12
STM32L053可以设置多少个RTC时钟呢
macpherson 发表于 2023-1-16 13:46
还可以ms的时间唤醒闹钟的吗?
sanfuzi 发表于 2023-1-16 22:46
LL库好用吗?
biechedan 发表于 2023-2-2 15:25
stm32 rtc时钟可以用内部时钟吗
youtome 发表于 2023-2-4 10:05
STM32 中 RTC_Init()是库函数吗?
macpherson 发表于 2023-2-5 12:57
stm32的rtc外接纽扣电池电压多少
albertaabbot 发表于 2023-2-6 16:55
stm32rtc后备电池掉电很快
页: [1] 2
查看完整版本: STM32L053基于LL库、HAL库两种库RTC闹钟唤醒
