而服务器人 发表于 2022-12-27 16:34
基于STM32的RFID-RC522门禁系统
设计介绍这是一个基于STM32的RFID-RC522门禁系统,LCD1602显示当前状态,当检测到IC卡时,如果这个IC卡已经登记过,LCD1602上会显示IC卡的卡号,继电器打开,如果没有登记则报警。部分代码如下。#include "sys.h"
#include "delay.h"
#include "lcd.h"
#include "led.h"
#include "usart.h"
#include "dht11.h"
#include "key.h"
#include "beep.h"
#include <stdio.h>
#include "stmflash.h"
#include "timer.h"
#include "exit.h"
#include "rc522.h"
void show1(void);
void show2(void);
void show3(void);
void show4(void);
void show5(void);
void show21(void);
void show31(void);
void show8(void);
u8 read_up=1;
u8 set1=1;
/*这三个标志位是用于按键的扫描程序*/
u8 key0_flag=0;
u8 key1_flag=0;
u8 key2_flag=0;
u8 beep_switch=0;
u8 beep_num=0;
u8 beepup_num=0;
u8 open_flag=0;
u8 down_flag=0;
u8 err_beepnum=0;
u8 table1[]="Please Bash Card";
u8 table11[]="      (())      ";
u8 table2[]="Register Mode ";
u8 table22[]="      (())      ";
u8 table222[]="Register Success";
u8 table3[]="   Clear Mode   ";
u8 table33[]=" **ut Success ";
u8 table5[]="    Door open   ";
u8 table6[]="   Door close   ";
u8 table8[]=" Dead Lock    s ";
u8 err_num=0;
u8 eee_flag=0;
int kg_flag=0;//定时器4累加标志位,用于当RFID扫描到了并对门做出了相应的动作后,返回到扫描ID卡的计时标志位
u8 tim2_flag=0;//定时器2累加标志位,用于当按键按下之后,并完成了注册或注销卡之后,返回到扫描ID卡的计时标志位
u8 show_flag=0;//记录显示那个界面的标志位
unsigned char num;
unsigned char key_flag;//用于标识当前系统处于,扫描ID卡状态还是注册ID卡状态还是注销ID卡状态
unsigned char i;
unsigned int temp;
unsigned char status;
unsigned char g_ucTempbuf;
unsigned char g_ucTempbufid;//用于记录下来当前扫描到的ID
unsigned char lcd[]="0123456789ABCDEF";//用于显示ID时的16进制
unsigned char dataerr = {0x11,0x11,0x11,0x78,0xED,0xCB,0xA9,0x87,0x12,0x34,0x56,0x78,0x01,0xFE,0x01,0xFE};//ID卡中错误的密码数据
unsigned char data1 = {0x12,0x34,0x56,0x78,0xED,0xCB,0xA9,0x87,0x12,0x34,0x56,0x78,0x01,0xFE,0x01,0xFE};//ID卡中正确的密码数据
unsigned char data2= {0,0,0,0x01};
unsigned char DefaultKey = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};
u8 RC522_flag=1;
u8 RC522_flag1=1;
u8 RC522_flag2=1;
u8 RC522_flag3=0;
/*按键的扫描函数*/
/*用于判断系统应该显示哪一个界面*/
int main(void)
      unsigned char status,i;
      unsigned int temp;
      delay_init();
LCD1602_Init();
      KEY_Init();
      BEEP_Init();
      LED_Init();
      NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); //设置NVIC中断分组2:2位抢占优先级,2位响应优先级
         uart_init(115200);
      RC522_Init();
      PcdReset();
      PcdAntennaOff();
      delay_ms(10);
         PcdAntennaOn();
      delay_ms(10);
      TIM2_Int_Init(4999,7199);//10Khz的计数频率,计数到5000为500ms
      TIM3_Int_Init(499,7199);//10Khz的计数频率,计数到5000为500ms
      TIM4_Int_Init(4999,7199);//10Khz的计数频率,计数到5000为500ms
      printf("Start \r\n");
      key_flag=0;
      show_flag=1;
      beep_switch=0;
      GPIO_ResetBits(GPIOB,GPIO_Pin_0);
      while(1)
//                printf("%d",RC522_flag1);
                show_num();
                        down_flag=0;
                        if(kg_flag==6 && err_num<3)
                              kg_flag=0;
                              TIM_Cmd(TIM4, DISABLE);//使能TIMx
                              GPIO_ResetBits(GPIOB,GPIO_Pin_11);
                              key_flag=0;
                              show_flag=1;
                              open_flag=0;
                              down_flag=0;
                        else if(kg_flag==360 && err_num==3)
                              kg_flag=0;
                              err_beepnum=0;
                              key_flag=0;
                              show_flag=1;
                              err_num=0;
                if(tim2_flag==4)
                              tim2_flag=0;
                              TIM_Cmd(TIM2, DISABLE);//使能TIMx
                              key_flag=0;
                        show_flag=1;
                if(key_flag==0)
                        status = PcdRequest(PICC_REQALL, g_ucTempbuf);//寻卡
                        if (status != MI_OK)
                              PcdReset();
                              PcdAntennaOff();
                              PcdAntennaOn();
                                        printf("寻卡失败\r\n");
                              if(RC522_flag3<3) RC522_flag3++;
                        if(RC522_flag3==4)RC522_flag3=3;
                              continue;
                        else
                                        if(RC522_flag3==3)
                                                RC522_flag3=4;
                                                      RC522_flag=1;
                        if(RC522_flag==1)
                              RC522_flag=0;
                              printf("1231231231312312312312312312\r\n");
                              status = PcdAnticoll(g_ucTempbuf);//防冲撞
                              if(status != MI_OK)
                              {   printf("寻卡失败1");continue;         }
                              printf("卡序列号:");      //超级终端显示,
                              for(i=0;i<4;i++)
                              temp=g_ucTempbuf;
                              g_ucTempbufid=temp;
                              printf("%X",temp);
                                                      status = PcdSelect(g_ucTempbuf);//选定卡片
                              {   printf("寻卡失败2");continue;         }
                              status = PcdAuthState(PICC_AUTHENT1A, 1, DefaultKey, g_ucTempbuf);//验证卡片密码
                              {         printf("寻卡失败3");   continue;}
                              status = PcdRead(1, g_ucTempbuf);//读块
                              {          printf("寻卡失败4");    continue;}
                              printf("卡读块:");      //超级终端显示,
                              for(i=0;i<16;i++)
                                        temp=g_ucTempbuf;
                                        printf("%X",temp);
                              num=0;
                              for(i=0;i<16;i++)
                                        if(data1==g_ucTempbuf)
                                        {num++;}
                                        printf("\nnum %d\n",num);
                              if(num!=16)
                                        err_num++;
                                        if(err_num<3)
                                                //不开门
                                                show_flag=4;
                                                kg_flag=0;
                                                open_flag=2;
                                                printf("downflag%d\n",down_flag);
                                                TIM_Cmd(TIM4, ENABLE);//使能TIMx
                              else
                              //开门
                                        err_num=0;
                                        show_flag=5;
                                        kg_flag=0;
                                        open_flag=1;
                                        GPIO_SetBits(GPIOB,GPIO_Pin_11);
                              //printf("\n");
                        PcdHalt();
                else if(key_flag==1)
                        show_flag=2;
                              PcdReset();
                              PcdAntennaOff();
                              PcdAntennaOn();
                              key_flag=1;                printf("寻卡失败111\r\n");RC522_flag1=1;
                              continue;
                        if(RC522_flag1==1)
                              RC522_flag3=0;
                              RC522_flag1=0;
                              printf("卡的类型:");
                              for(i=0;i<2;i++)
                              temp=g_ucTempbuf;
                              printf("%X",temp);
                              if(status != MI_OK)
                                        printf("防冲撞失败");
                              else
                                        for(i=0;i<4;i++)
                                                temp=g_ucTempbuf;
                                                printf("%X",temp);
                                                printf("选定卡失败");
                                        else
                                                      printf("密码错误");
                                                else
                                                      status = PcdWrite(1, data1);//写块
        printf("写错");
                                                      else
        key_flag=3;
        show_flag=6;
                  tim2_flag=0;
        TIM_Cmd(TIM2, ENABLE);//使能TIMx
            PcdHalt();
//RC522_flag1=1;
                else if(key_flag==2)
                        show_flag=3;
                              PcdReset();
                              PcdAntennaOff();
                              PcdAntennaOn();
                              printf("寻卡失败\r\n");
                              key_flag=2;
                              RC522_flag2=1;
                              continue;
                        if(RC522_flag2==1)
                              RC522_flag3=0;
                              RC522_flag2=0;printf("1231231231312312312312312312\r\n");
                              printf("卡的类型:");
                              for(i=0;i<2;i++)
                                        temp=g_ucTempbuf;
                                        printf("%X",temp);
                              if(status != MI_OK)
                                        printf("防冲撞失败");
                              else
                                        for(i=0;i<4;i++)
                                                temp=g_ucTempbuf;
                                                printf("%X",temp);
                                                printf("选定卡失败");
                                        else
                                                      printf("密码错误");
                                                else
                                                      status = PcdWrite(1, dataerr);//写块
        printf("写错");
                                                      else
        key_flag=3;
        show_flag=7;
        tim2_flag=0;
                        PcdHalt();
                else if(key_flag==3)
pmp 发表于 2023-1-5 11:26
这个工程文件有了吗?
OKAKAKO 发表于 2023-1-5 11:35
原理简单,代码编写很有用
maudlu 发表于 2023-1-5 11:36
射频卡是否支持加密呢?
hudi008 发表于 2023-1-5 16:20
这个最大的读取速度是多少?
Jacquetry 发表于 2023-1-5 16:49
最大的读取速度是多少?
adolphcocker 发表于 2023-1-5 17:00
射频卡的功能非常强大。
LOVEEVER 发表于 2023-1-6 09:30
固定频率的电磁波,非接触的功能很好
louliana 发表于 2023-1-6 17:34
这个如何写入数据?
mikewalpole 发表于 2023-1-7 16:30
怎么写入数据到RC522系统呢?
bestwell 发表于 2023-1-9 15:33
循环扫描的话,会不会连续读写卡片?
星辰大海不退缩 发表于 2023-1-9 16:10
射频卡应用还是很多的,不过这种应该加密吧
sheflynn 发表于 2023-1-12 14:51
检测IC卡的时候,会报错,但是读取不到数据。
zerorobert 发表于 2023-1-13 22:26
RC522可以被哪个模块替代呢?
updownq 发表于 2023-1-14 14:39
这个有时候会接触不良怎么回事?
uiint 发表于 2023-1-14 15:58
怎么判断ic卡已经读取到了?
everyrobin 发表于 2023-1-16 19:00
STM32的性能还是不错的。
abotomson 发表于 2023-1-19 13:23
怎么判断数据是否读取成功?
earlmax 发表于 2023-1-19 18:28
怎么使用这个中断?
页: [1]
查看完整版本: 基于STM32的RFID-RC522门禁系统
