花间一壶酒sd 发表于 2022-12-27 16:39
STM32与RC522简单公交卡系统的设计
系统的结构框图
花间一壶酒sd 发表于 2022-12-27 16:40
目前所用到的硬件有RC522,STM32和矩阵键盘,实物图如下:
花间一壶酒sd 发表于 2022-12-27 16:41
引脚连接以及相关接口设计
花间一壶酒sd 发表于 2022-12-27 16:45
RC522相关的引脚在我上一篇博客已经说过,请大家点开本博客开头的链接查看,4x4的矩阵键盘相关行我们用到的引脚是PF8,9,10,11,相关列用到的引脚是PF12,13,14,15。
花间一壶酒sd 发表于 2022-12-27 16:46
按键相关代码如下:
按键初始化函数void Matrix_ssKey_Pin_Init(void)
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOF,ENABLE);
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_11;//行按键
        GPIO_Init(GPIOF,&GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU ;
        GPIO_InitStructure.GPIO_Pin =GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;//列按键
按键扫描函数
int Matrix_Key_Scan(void)
        u8 temp = 0;
        int key_val = -1;
        GPIO_ResetBits(GPIOF,GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11);
        delay_us(10);
        temp=(GPIO_ReadInputData(GPIOF) >> 8)&0xff;
        if (temp == 0xf0)
                        delay_ms(50);
                        delay_us(10);
                        if (temp != 0xf0)
                                GPIO_Write(GPIOF,0);
                                delay_ms(5);
                                GPIO_Write(GPIOF,(uint16_t)(0xFE << 8));
                                if(((GPIO_ReadInputData(GPIOF) >> 8) & 0XF0) != 0XF0)
                                                delay_ms(20);
        temp=((GPIO_ReadInputData(GPIOF) >> 8) & 0XFE);
        switch(temp)
        case 0xEE:key_val = 1;   break;
        case 0xDE:key_val = 2;   break;
        case 0xBE:key_val = 3;   break;
        case 0x7E:key_val = 4;   break;
        default:    key_val = -1;   break;
                                delay_ms(5);
                                GPIO_Write(GPIOF,(uint16_t)(0xFD << 8));
                                if(((GPIO_ReadInputData(GPIOF) >> 8) & 0XF0)!= 0XF0)
                                                delay_ms(20);
        temp=((GPIO_ReadInputData(GPIOF) >> 8) & 0XFD);
        switch(temp)
        case 0xED:key_val = 5;   break;
        case 0xDD:key_val = 6;   break;
        case 0xBD:key_val = 7;   break;
        case 0x7D:key_val = 8;   break;
                                delay_ms(5);
                                GPIO_Write(GPIOF,(uint16_t)(0xFB << 8));
                                                delay_ms(20);
        temp=((GPIO_ReadInputData(GPIOF) >> 8) & 0XFB);
        switch(temp)
        case 0xEB:key_val = 9;   break;
        case 0xDB:key_val = 10;   break;
        case 0xBB:key_val = 11;   break;
        case 0x7B:key_val = 12;   break;
                                delay_ms(5);
                                GPIO_Write(GPIOF,(uint16_t)(0xF7 << 8));
                                if(((GPIO_ReadInputData(GPIOF) >> 8) & 0XF0) !=0XF0)
                                                delay_ms(20);
        temp=((GPIO_ReadInputData(GPIOF) >> 8) & 0XF7);
        switch(temp)
        case 0xE7:key_val = 13;   break;
        case 0xD7:key_val = 14;   break;
        case 0xB7:key_val = 15;   break;
        case 0x77:key_val = 16;   break;
        return key_val;
花间一壶酒sd 发表于 2022-12-28 23:33
软件流程图
花间一壶酒sd 发表于 2022-12-28 23:35
花间一壶酒sd 发表于 2022-12-28 23:36
调试过程
我最开始设计的功能是将卡号先写好定义在数组里面,可是这样的话就没有了发卡的功能,于是我就想到设置一个空数组,读卡的时候把卡号存进这个数组里面去。随后,我在设置个人信息的功能时遇到了麻烦,我按下一个按键之后,不需要按后面三个按键他就自动跟第一个按键一样了,于是我在代码里找原因,发现原来每一次输入按键的时候都需要重新扫描,否则按键会停留在上一次的值。
花间一壶酒sd 发表于 2022-12-28 23:37
在发卡和个人信息绑定设置完成后,我又要设置挂失和解除挂失功能。这个时候我又用到了一个临时数组,用来临时存放卡号。
花间一壶酒sd 发表于 2022-12-28 23:38
当输入的个人信息和相应的卡匹配时,就将卡号存放在临时数组里面。
花间一壶酒sd 发表于 2022-12-28 23:39
花间一壶酒sd 发表于 2022-12-28 23:40
起初我只考虑了输入正确的情况,没有考虑到输入的信息错误的情况,于是我又小改了一下函数,把if改成了else if 最后如果输入的个人信息都不匹配,则打印出密码错误。
在设计卡的扣款的功能的时候,由于要扣款小数位,最开始我没有想到很好的方法怎么去设置小数位。然后我突然想到一个办法,就是用数据的第十位作为小数位,比如数据100,则实际金额为10.0。根据这个想法,我修改了代码。
花间一壶酒sd 发表于 2022-12-28 23:42
将数值块的数据除以10再强制转换为double类型,这样就实现了小数的功能了。不过这样做的坏处就是整体可用金额少了十倍。
花间一壶酒sd 发表于 2022-12-28 23:44
在我本来以为功能都设计的差不多的时候,我又发现了另一个问题,那就是挂失和解除挂失功能的模块,我原先把这块函数写在了读卡成功之后。实际功能为不刷卡时无法进入挂失和解除挂失模式的函数,这与实际情况不符合,我就是因为卡掉了才要进入挂失,你现在要我刷卡,我拿什么刷?于是我就把这块函数写在了读卡之前,这样,即使不刷卡,也能进入卡的挂失和解除挂失功能,更加符合实际情况。
花间一壶酒sd 发表于 2022-12-28 23:45
相关代码
挂失代码
if(WK_UP==1)//进入挂失和解除挂失模式
                printf("\r\n进入挂失和解除挂失模式\r\n");
                printf("\r\n按下S1进入挂失模式,按下S2进入解除挂失模式\r\n");
                while(1)
                        key_val = Matrix_Key_Scan();
                        if(key_val > 0 && key_val < 17)
                                if(key_val==1)//进入挂失模式
                                        printf("\r\n 进入挂失模式\r\n");
                                        printf("\r\n 请输入4位个人信息\r\n");
                                        while(1)
                                                if(key_val > 0 && key_val < 17)//¸个人信息第一位
                                                        if(key_val==1)card_3=1;
                                                        if(key_val==2)card_3=2;
                                                        if(key_val==3)card_3=3;
                                                        if(key_val==4)card_3=4;
                                                        if(key_val==5)card_3=5;
                                                        if(key_val==6)card_3=6;
                                                        if(key_val==7)card_3=7;
                                                        if(key_val==8)card_3=8;
                                                        if(key_val==9)card_3=9;
                                                        if(key_val==10)card_3=0;
                                                        printf("\r\n %d \r\n",card_3);
                                                        if(card_3==0|card_3==1|card_3==2|card_3==3|card_3==4|card_3==5|card_3==6|card_3==7|card_3==8|card_3==9)break;
                                        delay_ms(10000);
                                        while(1)
                                                if(key_val > 0 && key_val < 17)//个人信息第二位
                                        delay_ms(10000);
                                        while(1)
                                                if(key_val > 0 && key_val < 17)//个人信息第三位
                                        delay_ms(10000);
                                        while(1)
                                                if(key_val > 0 && key_val < 17)//个人信息第四位
                                        delay_ms(10000);
                                        if(((card_3==card)&&(card_3==card)&&(card_3==card)&&(card_3==card)))//如果为普通卡的信息
                                                {//创建一个临时数组来临时保存普通卡的卡号,然后将该卡卡号初始化为0
                                                        card_4=card;card=0;
                                                        card_4=card;card=0;
                                                        card_4=card;card=0;
                                                        card_4=card;card=0;
                                                        printf("\r\n 普通卡挂失成功\r\n");
                                                        printf("\r\n 按下S16退出\r\n");
                                                else if(((card_3==card)&&(card_3==card)&&(card_3==card)&&(card_3==card)))//如果为学生卡的信息
                                                {//创建一个临时数组来临时保存学生卡的卡号,然后将该卡卡号初始化为0
                                                        card_5=card;card=0;
                                                        card_5=card;card=0;
                                                        card_5=card;card=0;
                                                        card_5=card;card=0;
                                                        printf("\r\n 学生卡挂失成功\r\n");
                                                else if(((card_3==card)&&(card_3==card)&&(card_3==card)&&(card_3==card)))//如果为老年卡的信息
                                                {//创建一个临时数组来临时保存老年卡的卡号,然后将该卡卡号初始化为0
                                                        card_6=card;card=0;
                                                        card_6=card;card=0;
                                                        card_6=card;card=0;
                                                        card_6=card;card=0;
                                                        printf("\r\n 老年卡挂失成功\r\n");
                                                else
                                                        printf("\r\n 该信息未绑定公交卡\r\n ");
                                if(key_val==2)//进入解除挂失模式
                                                        printf("\r\n 进入解除挂失模式\r\n");
                                                        printf("\r\n 请输入4为个人信息\r\n");
                                                        while(1)
        if(key_val > 0 && key_val < 17)//个人信息第一位
                                                        delay_ms(10000);
                                                        while(1)
                                        delay_ms(10000);
                                        while(1)
                                        delay_ms(10000);
                                        while(1)
                                        delay_ms(10000);
                                        if(((card_3==card)&&(card_3==card)&&(card_3==card)&&(card_3==card)))//如果为普通卡的个人信息
                                                {//将挂失时临时保存的普通卡重新定义
                                                        card=card_4;
                                                        card=card_4;
                                                        card=card_4;
                                                        card=card_4;
                                                        printf("\r\n 普通卡解除挂失成功\r\n");
                                                else if(((card_3==card)&&(card_3==card)&&(card_3==card)&&(card_3==card)))//如果为学生卡的个人信息
                                                {//将挂失时临时保存的学生卡重新定义
                                                        card=card_5;
                                                        card=card_5;
                                                        card=card_5;
                                                        card=card_5;
                                                        printf("\r\n 学生卡解除挂失成功\r\n");
                                                else if(((card_3==card)&&(card_3==card)&&(card_3==card)&&(card_3==card)))//如果为老年卡的个人信息
                                                {//将挂失时临时保存的老年卡重新定义
                                                        card=card_6;
                                                        card=card_6;
                                                        card=card_6;
                                                        card=card_6;
                                                        printf("\r\n 老年卡解除挂失成功\r\n");
                                                else
                                                        printf("\r\n 该个人信息未绑定公交卡\r\n ");
                                if(key_val==16)//按下S16退出挂失和解除挂失功能
                                        printf("\r\n 退出挂失和解除挂失功能\r\n");
                                        break;
页: [1] 2
查看完整版本: STM32与RC522简单公交卡系统的设计
