【AT-START-F437测评】OLED显示
手上有个SPI接口OLED屏,尺寸128x64,正好给AT32F437评估板加个显示器。OLED没太多好讲的,主要就是代码实现:连接如下:
OLED MCU
D/C PB10
CS PA8
RST PA10
CLK PB3
DAT PB5
底层主要是SPI接口调试,相对比较简单,实现初始化和写函数即可:
初始化:
void ext_spi_init(void)
spi_init_type cfg;
intx_alloc();
// 开启时钟
intx_disable();
crm_periph_clock_enable(CRM_SPI1_PERIPH_CLOCK, TRUE);
crm_periph_reset(CRM_SPI1_PERIPH_RESET, TRUE);
crm_periph_reset(CRM_SPI1_PERIPH_RESET, FALSE);
intx_enable();
// SPI 配置
cfg.transmission_mode = SPI_TRANSMIT_FULL_DUPLEX;
cfg.mclk_freq_division = SPI_MCLK_DIV_32;
cfg.master_slave_mode = SPI_MODE_MASTER;
cfg.frame_bit_num = SPI_FRAME_8BIT;
cfg.first_bit_transmission = SPI_FIRST_BIT_MSB;
cfg.cs_mode_selection = SPI_CS_SOFTWARE_MODE;
cfg.clock_polarity = SPI_CLOCK_POLARITY_HIGH;
cfg.clock_phase = SPI_CLOCK_PHASE_2EDGE;
spi_init(SPIn, &cfg);
SPIn->ctrl1_bit.spien = 1;
}写函数
void ext_spi_wb(uint8_t dataW)
volatile uint8_t rb;
spi_rx_reset();
//send data
spi_send(dataW);
spi_read_delay();
//wait for trans complete
while (is_spi_busy())
//read data
rb = spi_read();
}oled 数据/命令操作:
void oled1_write_cmd(uu8 Data)
oled_cs.dis();
oled_dc.dis();
oled_spi_wb(Data);
oled_cs.en();
void oled1_write_data(uu8 Data)
oled_cs.dis();
oled_dc.en();
oled_spi_wb(Data);
oled_cs.en();
}oled模块初始化:
void ssd1306_m1_init(void)
//internal setting
oled1_write_cmd(0xae); //--turn off oled panel
oled1_write_cmd(0x00); //--set low column address
oled1_write_cmd(0x10); //--set high column address
oled1_write_cmd(0x40); //--set start line address
oled1_write_cmd(0x81); //--set contrast control register
oled1_write_cmd(0xf0);
oled1_write_cmd(0xa1); //--ÁÐɨÃè˳Ðò£º´Ó×óµ½ÓÒa1 //×óÓҷתa0
oled1_write_cmd(0xc8); //--ÐÐɨÃè˳Ðò£º´ÓÉϵ½ÏÂc8 //ÉÏϵߵ¹c0
oled1_write_cmd(0xa6); //--set normal display
oled1_write_cmd(0xa8); //--set multiples ratio(1to64)
oled1_write_cmd(0x3f); //--1/64 duty
oled1_write_cmd(0xd3); //--set display offset
oled1_write_cmd(0x00); //--not offset
oled1_write_cmd(0xd5); //--set display clock divide ratio/oscillator frequency
oled1_write_cmd(0x80); //--set divide ratio
oled1_write_cmd(0xd9); //--set pre-charge period
oled1_write_cmd(0xf1);
oled1_write_cmd(0xda); //--set com pins hardware configuration
oled1_write_cmd(0x12);
oled1_write_cmd(0xdb); //--set vcomh
oled1_write_cmd(0x30);
oled1_write_cmd(0x8d); //--set chare pump enable/disable
oled1_write_cmd(0x14); //--set(0x10) disable
clr_display();
oled1_write_cmd(0xaf);
//oled1_write_cmd(0xa7); //--set normal display
}显示效果如下图所示:
代码托管在GITEE,后面评测会一直用这个仓库更新。
https://gitee.com/aple_sun/atf437-start
我也是准备做一个OLED液晶显示的测评
页:
[1]
