是你的乱码 发表于 2022-12-31 23:42
STM32f103,TIM1,TIM2,TIM3,TIM4,TIM5,TIM8,4路PWM输出配置
定时器的.c文件:
TIM1,TIM2,TIM3,TIM4,TIM5,TIM8输出4路PWM配置
要用TIM2-TIM5记得注销TIM1,TIM8
要用TIM1,TIM8记得注销TIM2-TIM5
默认:TIM2-TIM5
注意:要使用TIM8的话别忘记把
      TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Reset ;
      的注释取消掉,TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Reset ;
      的具体位置在下方。
arr和psc要自己配置(根据自己的需要配置)
公式:
   72MHz / ((arr+1)*(psc+1)) =F(HZ)
   T=1/F(s)
配置方式:
       在主函数加入PWM_Init (999,0);
       我的arr和psc的默认值分别是
       arr=999,psc=0
void PWM_Init (u16 arr,u16 psc)
    TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
    TIM_OCInitTypeDef TIM_OCInitStructure;
    PWM_motor_Init();
    //RCC_APB2PeriphClockCmd(TIMX_CLKCmd2, ENABLE);//TIM1,TIM8
    RCC_APB1PeriphClockCmd(TIMX_CLKCmd, ENABLE);//TIM2--TIM5(TIM2,TIM3,TIM4,TIM5)
    //PWM端口1
    RCC_APB2PeriphClockCmd(TIMX_GPIO_CLK1, ENABLE);
    GPIO_InitStructure.GPIO_Pin = TIMX_GPIO_PIN1;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_Init(TIMX_GPIO1, &GPIO_InitStructure);
    //PWM端口2
    RCC_APB2PeriphClockCmd(TIMX_GPIO_CLK2, ENABLE);
    GPIO_InitStructure.GPIO_Pin = TIMX_GPIO_PIN2;
    GPIO_Init(TIMX_GPIO2, &GPIO_InitStructure);
    //PWM端口3
    RCC_APB2PeriphClockCmd(TIMX_GPIO_CLK3, ENABLE);
    GPIO_InitStructure.GPIO_Pin = TIMX_GPIO_PIN3;
    GPIO_Init(TIMX_GPIO3, &GPIO_InitStructure);
    //PWM端口4
    RCC_APB2PeriphClockCmd(TIMX_GPIO_CLK4, ENABLE);
    GPIO_InitStructure.GPIO_Pin = TIMX_GPIO_PIN4;
    GPIO_Init(TIMX_GPIO4, &GPIO_InitStructure);
    //TIME配置模式
    TIM_TimeBaseStructure.TIM_Period = arr;
    TIM_TimeBaseStructure.TIM_Prescaler = psc;
    TIM_TimeBaseStructure.TIM_ClockDivision = 0;
    TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
    TIM_TimeBaseInit(TIMX, &TIM_TimeBaseStructure);
    TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
    TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
    TIM_OCInitStructure.TIM_Pulse = 0;
    TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
    //TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Reset ;//TIM8关闭空闲状态(使用TIM8时候开启)
是你的乱码 发表于 2022-12-31 23:44
空闲状态是MOE DISABLE的时候输出值哈。因为你要先配置好所有的寄存器才会去开启MOE的,
    这样对互补驱动来说很有用的。因为P MOSFET和N MOSFET的驱动是相反的,有些情况下IDLE
    下是要高电平或者是要低电平的。但是我一直都是用低电平,我配置为高电平的时候,之前
    出过问题,就是MOE开启的时候,互补驱动中间是不会插入死去的,2个驱动会有重叠部分,
    相当于桥臂会直通。但是TIMER1有一个比较厉害的地方那个就是当MCU的主时钟挂掉了,驱动
    还是可以保证互补的。
是你的乱码 发表于 2022-12-31 23:47
    //TIME使能
    TIM_OC1Init(TIMX, &TIM_OCInitStructure);
    TIM_OC2Init(TIMX, &TIM_OCInitStructure);
TIM_OC3Init(TIMX, &TIM_OCInitStructure);
    TIM_OC4Init(TIMX, &TIM_OCInitStructure);
    TIM_CtrlPWMOutputs(TIMX, ENABLE);
    TIM_OC1PreloadConfig(TIMX, TIM_OCPreload_Enable);
    TIM_OC2PreloadConfig(TIMX, TIM_OCPreload_Enable);
    TIM_OC3PreloadConfig(TIMX, TIM_OCPreload_Enable);
TIM_OC4PreloadConfig(TIMX, TIM_OCPreload_Enable);
    TIM_ARRPreloadConfig(TIMX, ENABLE);
    TIM_Cmd(TIMX, ENABLE);
定时器的.h
PWM设置
TIM1,TIM8:
   设置TIM1或TIM8时要改一下#define TIMX_CLKCmd2的配置
         默认:TIM1
TIM2-TIM5:
      设置TIM2,TIM3,TIM4,TIM5时改一下TIMX_CLKCmd的配置
            默认:TIM3
要用TIM2-TIM5记得注释TIM1,TIM8
要用TIM1,TIM8记得注释TIM2-TIM5
#define TIMX               TIM3
//#define TIMX_CLKCmd2      RCC_APB2Periph_TIM1//TIM1,TIM8
#define TIMX_CLKCmd      RCC_APB1Periph_TIM3//TIM2-TIM5(TIM2,TIM3,TIM4,TIM5)
#define TIMX_GPIO_CLK1   RCC_APB2Periph_GPIOA
#define TIMX_GPIO_PIN1   GPIO_Pin_6
#define TIMX_GPIO1         GPIOA
#define TIMX_GPIO_CLK2   RCC_APB2Periph_GPIOA
#define TIMX_GPIO_PIN2   GPIO_Pin_7
#define TIMX_GPIO2         GPIOA
#define TIMX_GPIO_CLK3   RCC_APB2Periph_GPIOB
#define TIMX_GPIO_PIN3   GPIO_Pin_0
#define TIMX_GPIO3         GPIOB
#define TIMX_GPIO_CLK4   RCC_APB2Periph_GPIOB
#define TIMX_GPIO_PIN4   GPIO_Pin_1
#define TIMX_GPIO4         GPIOB
void PWM_motor_Init (void);
void PWM_Init (u16 arr,u16 psc);
是你的乱码 发表于 2022-12-31 23:48
             TIM1    TIM2    TIM3    TIM4   TIM5    TIM8
CH1      PA8    PA0   PA6   PB6      PA0   PC6
CH2      PA9    PA1   PA7   PB7      PA1   PC7
CH3      PA10   PA2   PB0   PB8      PA2   PC8
CH4      PA11   PA3   PB1   PB9      PA3   PC9
注:这里TIM2和TIM5引脚配置一样
    如果要同时使用TIM2和TIM5的话可以把TIM2进行端口复用,
      在RCC_APB1PeriphClockCmd(TIMX_CLKCmd, ENABLE);//TIM2--TIM5(TIM2,TIM3,TIM4,TIM5)
      下方加入RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);即可
      然后把TIM2或者TIM5的引脚改成复用引脚
下面是TIM2的复用引脚
TIM2:
    CH1PA5   PA15
      CH2PB3
      CH3PB10
      CH4PB11
页: [1]
查看完整版本: STM32f103,TIM1,TIM2,TIM3,TIM4,TIM5,TIM8,4路PWM输出配置
