yjsmcu 发表于 2023-1-4 10:25
HC32L110的ADC通道AdcAVccDiV3Input不能中断问题
//使用\HC32L110_DDL_Rev1.1.5\example\adc\adc_cont_irq_sw范例改
* Include files
#include "adc.h"
#include "gpio.h"
* Local pre-processor symbols/macros ('#define')
* Global variable definitions (declared in header file with 'extern')
* Local type definitions ('typedef')
* Local function prototypes ('static')
* Local variable definitions ('static')                                    *
static uint32_t u32AdcResultAcc;
* Function implementation - global ('extern') and local ('static')
void AdcContIrqCallback(void)
    //中断标志位判断和清零,已在库函数中处理Adc_IRQHandler();
    Adc_GetAccResult(&u32AdcResultAcc);
    Adc_ClrAccResult();
    // Adc_ClrContIrqState();
void AdcRegIrqCallback(void)
    // 中断标志位判断和清零,已在库函数中处理Adc_IRQHandler();
    // Adc_ClrRegIrqState();
void AdcHhtIrqCallback(void)
    // Adc_ClrHhtIrqState();
void AdcLltIrqCallback(void)
    // Adc_ClrLltIrqState();
** \briefMain function of project
** \return uint32_t return value, if needed
** This sample
int32_t main(void)
    stc_adc_cfg_t             stcAdcCfg;
    stc_adc_cont_cfg_t      stcAdcContCfg;
    stc_adc_irq_t             stcAdcIrq;
    stc_adc_irq_calbakfn_pt_t stcAdcIrqCalbaks;
    DDL_ZERO_STRUCT(stcAdcCfg);
    DDL_ZERO_STRUCT(stcAdcContCfg);
    DDL_ZERO_STRUCT(stcAdcIrq);
    DDL_ZERO_STRUCT(stcAdcIrqCalbaks);
    Clk_SwitchTo(ClkRCL);
    Clk_SetRCHFreq(ClkFreq24Mhz);
    Clk_SwitchTo(ClkRCH);
    Clk_SetPeripheralGate(ClkPeripheralGpio, TRUE);            //GPIO 外设时钟使能
    if (Ok != Clk_SetPeripheralGate(ClkPeripheralAdcBgr, TRUE))//ADCBGR 外设时钟使能
      return Error;
    //Gpio_SetAnalog(2, 4, TRUE);
    //ADC配置
    Adc_Enable();
    M0P_BGR->CR_f.BGR_EN = 0x1u;//BGR必须使能
    M0P_BGR->CR_f.TS_EN = 0x0u;   //内置温度传感器,视使用需求
    delay100us(1);
    stcAdcCfg.enAdcOpMode = AdcContMode;                //连续采样模式
    stcAdcCfg.enAdcClkSel = AdcClkSysTDiv1;             //PCLK
    stcAdcCfg.enAdcSampTimeSel = AdcSampTime8Clk;       //8个采样时钟
    // stcAdcCfg.enAdcRefVolSel = RefVolSelInBgr2p5;    //参考电压:内部2.5V(avdd>3V,SPS<=200kHz)
    stcAdcCfg.enAdcRefVolSel = RefVolSelAVDD;         //参考电压:AVDD
    stcAdcCfg.bAdcInBufEn = TRUE;
    //stcAdcCfg.bAdcInBufEn = FALSE;                      //电压跟随器如果使能,SPS采样速率 <=200K
    stcAdcCfg.enAdcTrig0Sel = AdcTrigDisable;         //ADC转换自动触发设置
    stcAdcCfg.enAdcTrig1Sel = AdcTrigDisable;
    Adc_Init(&stcAdcCfg);
    stcAdcIrq.bAdcIrq = TRUE;                            //转换完成中断函数入口配置使能
    stcAdcIrq.bAdcRegCmp = FALSE;
    stcAdcIrq.bAdcHhtCmp = FALSE;
    stcAdcIrq.bAdcLltCmp = FALSE;
    stcAdcIrqCalbaks.pfnAdcContIrq = AdcContIrqCallback; //转换完成中断入口函数
    stcAdcIrqCalbaks.pfnAdcRegIrq = AdcRegIrqCallback;
    stcAdcIrqCalbaks.pfnAdcHhtIrq = AdcHhtIrqCallback;
    stcAdcIrqCalbaks.pfnAdcLltIrq = AdcLltIrqCallback;
    Adc_ConfigIrq(&stcAdcIrq, &stcAdcIrqCalbaks);      //转换中断入口函数配置
    Adc_EnableIrq();                                     //中断使能
    Adc_CmpCfg(&stcAdcIrq);                              //结果比较中断使能/禁止配置
    stcAdcContCfg.enAdcContModeCh = AdcAVccDiV3Input;      //通道0 P24
    stcAdcContCfg.u8AdcSampCnt = 0x09u;               //P24 连续累加次数(次数 = 0x09+1)
    stcAdcContCfg.bAdcResultAccEn = TRUE;               //累加使能
    Adc_ConfigContMode(&stcAdcCfg, &stcAdcContCfg);
    while(1)
      Adc_Start();      //ADC开始转换
      delay1ms(1000);
* EOF (not truncated)
caigang13 发表于 2023-1-4 22:03
你的中断回调函数呢?
tpgf 发表于 2023-2-1 14:30
模拟量采集除了可以通过采集是否完成来进行中断唤醒外还可以通过什么方式唤醒呢
qcliu 发表于 2023-2-1 14:39
中断向量配置 是否开启总中断 是否开启ad采集中断等
drer 发表于 2023-2-1 14:51
中断向量的配置那 是不是不小心给屏蔽掉了啊
coshi 发表于 2023-2-1 15:10
你这个没有进入低功耗 也没有开启中断使能啊
kxsi 发表于 2023-2-1 15:19
楼主只开启了ad中断使能 好像没有开启总的中断使能
wiba 发表于 2023-2-1 15:42
其实就是那些中断向量的指向中断的开启 模块的初始化配置
这个问题可能是由于 ADC 通道 AdcAVccDiV3Input 配置不正确导致的。您需要确保 ADC 通道已经正确配置并且通道中断已经被启用。您还可以检查 ADC 驱动代码中是否有任何错误,例如在 ADC 中断回调函数中缺少足够的代码来处理中断。
这段代码是一个ADC模块的例程,使用了模块库函数。它通过设置ADC的一些配置信息,如ADC的工作模式、采样时间、规则采样间隔时间等来实现ADC的功能。具体而言,它实现了以下功能:
[*]初始化系统时钟,使能GPIO外设时钟和ADCBGR外设时钟。
[*]配置BGR,使能BGR以保证ADC正常工作。
[*]初始化ADC模块,包括ADC的连续采样模式、采样时间、规则采样间隔时间等。
[*]设置ADC的中断回调函数,分别对于连续采样完成、规则采样完成、采样高于预设阈值和采样低于预设阈值的情况进行回调。
请注意,本例程并未配置ADC的规则采样,因此规则采样回调函数和高低阈值回调函数未使用。
页: [1]
查看完整版本: HC32L110的ADC通道AdcAVccDiV3Input不能中断问题
