STM32H743 SPI DMA 数据收发问题
STM32H743 通过SPI DMA进行数据收发,在使用SP1/2时能够进入中断并进入回调函数,当改为SPI3/SPI4时出错,无法进入中断回调函数 附上SPI代码/*
* 时钟,引脚,DMA,中断等宏定义
#define SPIx SPI3
#define SPIx_CLK_ENABLE() __HAL_RCC_SPI3_CLK_ENABLE()
#define DMAx_CLK_ENABLE() __HAL_RCC_DMA2_CLK_ENABLE()
#define SPIx_FORCE_RESET() __HAL_RCC_SPI3_FORCE_RESET()
#define SPIx_RELEASE_RESET() __HAL_RCC_SPI3_RELEASE_RESET()
#define SPIx_SCK_CLK_ENABLE() __HAL_RCC_GPIOB_CLK_ENABLE()
#define SPIx_SCK_GPIO GPIOB
#define SPIx_SCK_PIN GPIO_PIN_3
#define SPIx_SCK_AF GPIO_AF5_SPI3
#define SPIx_MISO_CLK_ENABLE() __HAL_RCC_GPIOB_CLK_ENABLE()
#define SPIx_MISO_GPIO GPIOB
#define SPIx_MISO_PIN GPIO_PIN_4
#define SPIx_MISO_AF GPIO_AF5_SPI3
#define SPIx_MOSI_CLK_ENABLE() __HAL_RCC_GPIOB_CLK_ENABLE()
#define SPIx_MOSI_GPIO GPIOB
#define SPIx_MOSI_PIN GPIO_PIN_5
#define SPIx_MOSI_AF GPIO_AF5_SPI3
/* CS片选 */
#define SPIx_NSS_CLK_ENABLE() __HAL_RCC_GPIOG_CLK_ENABLE()
#define SPIx_NSS_GPIO GPIOG
#define SPIx_NSS_PIN GPIO_PIN_10
#define SPIx_NSS_AF GPIO_AF5_SPI3
#define SPIx_TX_DMA_STREAM DMA2_Stream3
#define SPIx_RX_DMA_STREAM DMA2_Stream2
#define SPIx_TX_DMA_REQUEST DMA_REQUEST_SPI3_TX
#define SPIx_RX_DMA_REQUEST DMA_REQUEST_SPI3_RX
#define SPIx_DMA_TX_IRQn DMA2_Stream3_IRQn
#define SPIx_DMA_RX_IRQn DMA2_Stream2_IRQn
#define SPIx_DMA_TX_IRQHandler DMA2_Stream3_IRQHandler
#define SPIx_DMA_RX_IRQHandler DMA2_Stream2_IRQHandler
#define SPIx_IRQn SPI3_IRQn
#define SPIx_IRQHandler SPI3_IRQHandler
enum {
TRANSFER_WAIT,
TRANSFER_COMPLETE,
TRANSFER_ERROR
* 变量
static SPI_HandleTypeDef hspi = {0};
static DMA_HandleTypeDef hdma_tx;
static DMA_HandleTypeDef hdma_rx;
static uint32_t s_BaudRatePrescaler;
static uint32_t s_CLKPhase;
static uint32_t s_CLKPolarity;
uint32_t g_spiLen;
uint8_tg_spi_busy; /* SPI忙状态,0表示不忙,1表示忙 */
__IO uint32_t wTransferState = TRANSFER_WAIT;
/* 查询模式 */
#if defined (USE_SPI_POLL)
uint8_t g_spiTxBuf;
uint8_t g_spiRxBuf;
/* 中断模式 */
#elif defined (USE_SPI_INT)
uint8_t g_spiTxBuf;
uint8_t g_spiRxBuf;
/* DMA模式使用的SRAM4 */
#elif defined (USE_SPI_DMA)
#if defined ( __CC_ARM ) /* IAR *******/
__attribute__((section (".RAM_D3"))) uint8_t g_spiTxBuf;
__attribute__((section (".RAM_D3"))) uint8_t g_spiRxBuf;
#elif defined (__ICCARM__) /* MDK ********/
#pragma location = ".RAM_D3"
uint8_t g_spiTxBuf;
uint8_t g_spiRxBuf;
#endif
#endif
* 函 数 名: bsp_InitSPIBus
* 功能说明: 配置SPI总线。
* 形 参: 无
* 返 回 值: 无
void bsp_InitSPIBus(void)
g_spi_busy = 0;
bsp_InitSPIParam(SPI_BAUDRATEPRESCALER_16, SPI_PHASE_1EDGE, SPI_POLARITY_LOW);
* 函 数 名: bsp_InitSPIParam
* 功能说明: 配置SPI总线参数,时钟分频,时钟相位和时钟极性。
* 形 参: _BaudRatePrescalerSPI总线时钟分频设置,支持的参数如下:
* SPI_BAUDRATEPRESCALER_2 2分频
* SPI_BAUDRATEPRESCALER_4 4分频
* SPI_BAUDRATEPRESCALER_8 8分频
* SPI_BAUDRATEPRESCALER_16 16分频
* SPI_BAUDRATEPRESCALER_32 32分频
* SPI_BAUDRATEPRESCALER_64 64分频
* SPI_BAUDRATEPRESCALER_128128分频
* SPI_BAUDRATEPRESCALER_256256分频
* _CLKPhase 时钟相位,支持的参数如下:
* SPI_PHASE_1EDGE SCK引脚的第1个边沿捕获传输的第1个数据
* SPI_PHASE_2EDGE SCK引脚的第2个边沿捕获传输的第1个数据
* _CLKPolarity 时钟极性,支持的参数如下:
* SPI_POLARITY_LOW SCK引脚在空闲状态处于低电平
* SPI_POLARITY_HIGH SCK引脚在空闲状态处于高电平
* 返 回 值: 无jiben
void bsp_InitSPIParam(uint32_t _BaudRatePrescaler, uint32_t _CLKPhase, uint32_t _CLKPolarity)
/* 提高执行效率,只有在SPI硬件参数发生变化时,才执行HAL_Init */
if (s_BaudRatePrescaler == _BaudRatePrescaler && s_CLKPhase == _CLKPhase && s_CLKPolarity == _CLKPolarity)
return;
s_BaudRatePrescaler = _BaudRatePrescaler;
s_CLKPhase = _CLKPhase;
s_CLKPolarity = _CLKPolarity;
/* 设置SPI参数 */
hspi.Instance = SPIx; /* 例化SPI */
hspi.Init.BaudRatePrescaler = _BaudRatePrescaler; /* 设置波特率 */
hspi.Init.Direction = SPI_DIRECTION_2LINES; /* 全双工 */
hspi.Init.CLKPhase = _CLKPhase; /* 配置时钟相位 */
hspi.Init.CLKPolarity = _CLKPolarity; /* 配置时钟极性 */
hspi.Init.DataSize = SPI_DATASIZE_8BIT; /* 设置数据宽度 */
hspi.Init.FirstBit = SPI_FIRSTBIT_MSB; /* 数据传输先传高位 */
hspi.Init.TIMode = SPI_TIMODE_DISABLE; /* 禁止TI模式*/
hspi.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE; /* 禁止CRC */
hspi.Init.CRCPolynomial = 7; /* 禁止CRC后,此位无效 */
hspi.Init.CRCLength = SPI_CRC_LENGTH_8BIT; /* 禁止CRC后,此位无效 */
hspi.Init.FifoThreshold = SPI_FIFO_THRESHOLD_16DATA; /* 设置FIFO大小是一个数据项 */
hspi.Init.NSS = SPI_NSS_HARD_OUTPUT; /*片选引脚 */
hspi.Init.NSSPMode = SPI_NSS_PULSE_DISABLE; /* 关闭脉冲输出 */
hspi.Init.NSSPolarity = SPI_NSS_POLARITY_LOW; /* 低电平有效 */
hspi.Init.MasterSSIdleness = SPI_MASTER_SS_IDLENESS_00CYCLE; /* MSS, 插入到NSS有效边沿和第一个数据开始之间的额外延迟,单位SPI时钟周期个数 */
hspi.Init.MasterInterDataIdleness = SPI_MASTER_INTERDATA_IDLENESS_10CYCLE; /* MIDI, 两个连续数据帧之间插入的最小时间延迟,单位SPI时钟周期个数 */
hspi.Init.MasterKeepIOState = SPI_MASTER_KEEP_IO_STATE_ENABLE; /* 禁止SPI后,SPI相关引脚保持当前状态 */
hspi.Init.Mode = SPI_MODE_MASTER; /* SPI工作在主控模式 */
/* 复位配置 */
if (HAL_SPI_DeInit(&hspi) != HAL_OK)
Error_Handler(__FILE__, __LINE__);
/* 初始化配置 */
if (HAL_SPI_Init(&hspi) != HAL_OK)
* 功能说明: 配置SPI总线时钟,GPIO,中断,DMA等
* 形 参: SPI_HandleTypeDef 类型指针变量
* 返 回 值: 无
void HAL_SPI_MspInit(SPI_HandleTypeDef *_hspi)
/* 配置 SPI总线GPIO : SCK MOSI MISO */
GPIO_InitTypeDefGPIO_InitStruct;
/* SPI和GPIP时钟 */
SPIx_SCK_CLK_ENABLE();
SPIx_MISO_CLK_ENABLE();
SPIx_MOSI_CLK_ENABLE();
SPIx_CLK_ENABLE();
/* SPI SCK */
GPIO_InitStruct.Pin = SPIx_SCK_PIN;
GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
GPIO_InitStruct.Pull = GPIO_PULLUP;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
GPIO_InitStruct.Alternate = SPIx_SCK_AF;
HAL_GPIO_Init(SPIx_SCK_GPIO, &GPIO_InitStruct);
/* SPI MISO */
GPIO_InitStruct.Pin = SPIx_MISO_PIN;
GPIO_InitStruct.Alternate = SPIx_MISO_AF;
HAL_GPIO_Init(SPIx_MISO_GPIO, &GPIO_InitStruct);
/* SPI MOSI */
GPIO_InitStruct.Pin = SPIx_MOSI_PIN;
GPIO_InitStruct.Alternate = SPIx_MOSI_AF;
HAL_GPIO_Init(SPIx_MOSI_GPIO, &GPIO_InitStruct);
/* SPI NSS */
GPIO_InitStruct.Pin = SPIx_NSS_PIN;
GPIO_InitStruct.Alternate = SPIx_NSS_AF;
HAL_GPIO_Init(SPIx_NSS_GPIO, &GPIO_InitStruct);
/* 配置DMA和NVIC */
#ifdef USE_SPI_DMA
/* 使能DMA时钟 */
DMAx_CLK_ENABLE();
/* SPI DMA发送配置 */
hdma_tx.Instance = SPIx_TX_DMA_STREAM; /* 例化使用的DMA数据流 */
hdma_tx.Init.FIFOMode = DMA_FIFOMODE_ENABLE; /* FIFO*/
hdma_tx.Init.FIFOThreshold = DMA_FIFO_THRESHOLD_FULL; /* 禁止FIFO此位不起作用,用于设置阀值 */
hdma_tx.Init.MemBurst = DMA_MBURST_SINGLE; /* 禁止FIFO此位不起作用,用于存储器突发 */
hdma_tx.Init.PeriphBurst = DMA_PBURST_SINGLE; /* 禁止FIFO此位不起作用,用于外设突发 */
hdma_tx.Init.Request = SPIx_TX_DMA_REQUEST; /* 请求类型 */
hdma_tx.Init.Direction = DMA_MEMORY_TO_PERIPH; /* 传输方向是从存储器到外设 */
hdma_tx.Init.PeriphInc = DMA_PINC_DISABLE; /* 外设地址自增禁止 */
hdma_tx.Init.MemInc = DMA_MINC_ENABLE; /* 存储器地址自增使能 */
hdma_tx.Init.PeriphDataAlignment = DMA_PDATAALIGN_BYTE; /* 外设数据传输位宽选择字节,即8bit */
hdma_tx.Init.MemDataAlignment = DMA_MDATAALIGN_BYTE; /* 存储器数据传输位宽选择字节,即8bit */
hdma_tx.Init.Mode = DMA_NORMAL; /* 正常模式 */
hdma_tx.Init.Priority = DMA_PRIORITY_LOW; /* 优先级低 */
/* 复位DMA */
if(HAL_DMA_DeInit(&hdma_tx) != HAL_OK)
/* 初始化DMA */
if(HAL_DMA_Init(&hdma_tx) != HAL_OK)
/* 关联DMA句柄到SPI */
__HAL_LINKDMA(_hspi, hdmatx, hdma_tx);
/* SPI DMA接收配置 */
hdma_rx.Instance = SPIx_RX_DMA_STREAM; /* 例化使用的DMA数据流 */
hdma_rx.Init.FIFOMode = DMA_FIFOMODE_ENABLE; /* FIFO*/
hdma_rx.Init.FIFOThreshold = DMA_FIFO_THRESHOLD_FULL;/* 禁止FIFO此位不起作用,用于设置阀值 */
hdma_rx.Init.MemBurst = DMA_MBURST_SINGLE; /* 禁止FIFO此位不起作用,用于存储器突发 */
hdma_rx.Init.PeriphBurst = DMA_PBURST_SINGLE; /* 禁止FIFO此位不起作用,用于外设突发 */
hdma_rx.Init.Request = SPIx_RX_DMA_REQUEST; /* 请求类型 */
hdma_rx.Init.Direction = DMA_PERIPH_TO_MEMORY; /* 传输方向从外设到存储器 */
hdma_rx.Init.PeriphInc = DMA_PINC_DISABLE; /* 外设地址自增禁止 */
hdma_rx.Init.MemInc = DMA_MINC_ENABLE; /* 存储器地址自增使能 */
hdma_rx.Init.PeriphDataAlignment = DMA_PDATAALIGN_BYTE; /* 外设数据传输位宽选择字节,即8bit */
hdma_rx.Init.MemDataAlignment = DMA_MDATAALIGN_BYTE; /* 存储器数据传输位宽选择字节,即8bit */
hdma_rx.Init.Mode = DMA_NORMAL; /* 正常模式 */
hdma_rx.Init.Priority = DMA_PRIORITY_HIGH; /* 优先级高 */
/* 复位DMA */
if(HAL_DMA_DeInit(&hdma_rx) != HAL_OK)
/* 初始化DMA */
if(HAL_DMA_Init(&hdma_rx) != HAL_OK)
/* 关联DMA句柄到SPI */
__HAL_LINKDMA(_hspi, hdmarx, hdma_rx);
/* 配置DMA发送中断 */
HAL_NVIC_SetPriority(SPIx_DMA_TX_IRQn, 1, 0);
HAL_NVIC_EnableIRQ(SPIx_DMA_TX_IRQn);
/* 配置DMA接收中断 */
HAL_NVIC_SetPriority(SPIx_DMA_RX_IRQn, 1, 0);
HAL_NVIC_EnableIRQ(SPIx_DMA_RX_IRQn);
/* 配置SPI中断 */
HAL_NVIC_SetPriority(SPIx_IRQn, 1, 0);
HAL_NVIC_EnableIRQ(SPIx_IRQn);
#endif
#ifdef USE_SPI_INT
/* 配置SPI中断优先级并使能中断 */
#endif
* 函 数 名: bsp_spiTransfer
* 功能说明: 启动数据传输
* 形 参: 无
* 返 回 值: 无
void bsp_spiTransfer(void)
if (g_spiLen > SPI_BUFFER_SIZE)
return;
/* DMA方式传输 */
#ifdef USE_SPI_DMA
if(HAL_SPI_TransmitReceive_DMA(&hspi, (uint8_t*)g_spiTxBuf, (uint8_t *)g_spiRxBuf, g_spiLen) != HAL_OK)
// if(HAL_SPI_Transmit_DMA(&hspi, (uint8_t*)g_spiTxBuf, g_spiLen) != HAL_OK)
// Error_Handler(__FILE__, __LINE__);
while (wTransferState == TRANSFER_WAIT)
#endif
/* 中断方式传输 */
#ifdef USE_SPI_INT
if(HAL_SPI_TransmitReceive_IT(&hspi, (uint8_t*)g_spiTxBuf, (uint8_t *)g_spiRxBuf, g_spiLen) != HAL_OK)
#endif
/* 查询方式传输 */
#ifdef USE_SPI_POLL
if(HAL_SPI_TransmitReceive(&hspi, (uint8_t*)g_spiTxBuf, (uint8_t *)g_spiRxBuf, g_spiLen, 1000000) != HAL_OK)
#endif
* 函 数 名: HAL_SPI_TxRxCpltCallback,HAL_SPI_ErrorCallback
* 功能说明: SPI数据传输完成回调和传输错误回调
* 返 回 值: 无
void HAL_SPI_TxRxCpltCallback(SPI_HandleTypeDef *hspi)
HAL_SPI_DMAStop(hspi);
HAL_SPI_DMAPause(hspi);
wTransferState = TRANSFER_COMPLETE;
//void HAL_SPI_TxCpltCallback(SPI_HandleTypeDef *hspi)
// wTransferState = TRANSFER_COMPLETE;
void HAL_SPI_ErrorCallback(SPI_HandleTypeDef *hspi)
wTransferState = TRANSFER_ERROR;
* 函 数 名: bsp_SpiBusEnter
* 功能说明: 占用SPI总线
* 形 参: 无
* 返 回 值: 0 表示不忙1表示忙
void bsp_SpiBusEnter(void)
g_spi_busy = 1;
* 函 数 名: bsp_SpiBusExit
* 功能说明: 释放占用的SPI总线
* 形 参: 无
* 返 回 值: 0 表示不忙1表示忙
void bsp_SpiBusExit(void)
g_spi_busy = 0;
* 函 数 名: bsp_SpiBusBusy
* 功能说明: 判断SPI总线忙,方法是检测其他SPI芯片的片选信号是否为1
* 形 参: 无
* 返 回 值: 0 表示不忙1表示忙
uint8_t bsp_SpiBusBusy(void)
return g_spi_busy;
* 函 数 名: SPIx_IRQHandler,SPIx_DMA_RX_IRQHandler,SPIx_DMA_TX_IRQHandler
* 功能说明: 中断服务程序
* 形 参: 无
* 返 回 值: 无
#ifdef USE_SPI_INT
void SPIx_IRQHandler(void)
HAL_SPI_IRQHandler(&hspi);
#endif
#ifdef USE_SPI_DMA
void SPIx_DMA_RX_IRQHandler(void)
HAL_SPI_DMAStop(&hspi);
HAL_SPI_DMAPause(&hspi);
HAL_DMA_IRQHandler(hspi.hdmarx);
void SPIx_DMA_TX_IRQHandler(void)
HAL_DMA_IRQHandler(hspi.hdmatx);
#endif
具体的话楼主修改哪方面的代码了呢 改串口之后存在引脚功能上的冲突吗 需要注意一下这方面 我不是很明白 楼主是一下子就使用了两个串口同时进行通讯吗 在中断向量的里边是不是指向的地址不相符啊 软件更改配置的话要确认硬件上是否已经同步更改 肯定是小细节没有处理好啊硬件和软件都要检查 软件更改配置的话,检查一下硬件有没有更改
页:
[1]
