等你下课 发表于 2023-1-15 19:23
lwip接收文件 stm32_LwIP+ STM32+HTTP例程参考
#include
#include
#include
#include
#include
// Http请求内容
static const char send_data[] =
"GET /v1.0/device/1949/sensor/2511/datapoints HTTP/1.1\r\n"
"U-ApiKey:\r\n"
"Host: api.yeelink.net\r\n\r\n";
void tcpclient(const char* host_name, int port)
(void)port;
char *recv_data;
int sock, bytes_received;
struct hostent *yeelink_host;
struct in_addr yeelink_ipaddr;
struct sockaddr_in yeelink_sockaddr;
recv_data = rt_malloc(1024);
if (recv_data == RT_NULL)
rt_kprintf("No memory\r\n");
return;
等你下课 发表于 2023-1-15 19:24
// 第一步 DNS地址解析
rt_kprintf("calling gethostbyname with: %s\r\n", host_name);
yeelink_host = gethostbyname(host_name);
yeelink_ipaddr.s_addr = *(unsigned long *) yeelink_host->h_addr_list;
rt_kprintf("Yeelink IP Address:%s\r\n" , inet_ntoa(yeelink_ipaddr));
yeelink_sockaddr.sin_family = AF_INET;
yeelink_sockaddr.sin_port = htons(80);
yeelink_sockaddr.sin_addr = yeelink_ipaddr;
rt_memset(&(yeelink_sockaddr.sin_zero), 0, sizeof(yeelink_sockaddr.sin_zero));
while(1)
等你下课 发表于 2023-1-15 19:26
// 第二步 创建套接字
if ((sock = socket(AF_INET, SOCK_STREAM, 0)) == -1)
rt_kprintf("Socket error\n");
rt_free(recv_data);
return;
等你下课 发表于 2023-1-15 19:27
// 第三步 连接yeelink
if (connect(sock, (struct sockaddr *)&yeelink_sockaddr, sizeof(struct sockaddr)) == -1)
rt_kprintf("Connect fail!\n");
lwip_close(sock);
rt_free(recv_data);
return;
// 第4步 发送Http请求
send(sock,send_data,strlen(send_data), 0);
// 第5步 获得Http响应
bytes_received = recv(sock, recv_data, 1024 - 1, 0);
recv_data = '\0';
// 响应内容为 {"timestamp":"2013-11-19T08:50:11","value":1}
// 截取“value”之后的内容
char* actuator_info = rt_strstr( recv_data , "\"value\"");
int offset = rt_strlen("\"value\":");
actuator_status = *(actuator_info + offset);
rt_kprintf("actuator status :%c\r\n",actuator_status);
// 获得开关状态,并设置LED指示灯
char actuator_status;
(actuator_status == '1')?rt_hw_led_on(0):rt_hw_led_off(0);
rt_memset(recv_data , 0 , sizeof(recv_data));
// 关闭套接字
closesocket(sock);
// 延时5S之后重新连接
rt_thread_delay( RT_TICK_PER_SECOND * 5 );
作者:Lolwuj
来源:CSDN
原文:https://blog.csdn.net/mikewu_helloworld/article/details/52769650
版权声明:本文为博主原创文章,转载请附上博文链接!
页: [1]
查看完整版本: lwip接收文件 stm32_LwIP+ STM32+HTTP例程参考
