N32WB031 SPI+DMA发送demo
本帖最后由 Afanx 于 2023-2-6 11:20 编辑例程附件:
GPIO配置:
void GPIO_Configuration(void)
GPIO_InitType GPIO_InitStructure;
RCC_EnableAPB2PeriphClk(SPI_MASTER_GPIO_CLK | RCC_APB2_PERIPH_AFIO, ENABLE);
GPIO_InitStruct(&GPIO_InitStructure);
/* Configure SPI_MASTER pins: SCK ,MISO and MOSI */
GPIO_InitStructure.Pin = SPI_MASTER_PIN_SCK | SPI_MASTER_PIN_MOSI;
GPIO_InitStructure.GPIO_Speed = GPIO_SPEED_HIGH;
GPIO_InitStructure.GPIO_Mode = GPIO_MODE_AF_PP;
GPIO_InitStructure.GPIO_Pull = GPIO_NO_PULL;
GPIO_InitStructure.GPIO_Alternate = SPI_MASTER_GPIO_AF;
GPIO_InitPeripheral(SPI_MASTER_GPIO, &GPIO_InitStructure);
}DMA配置:
void DMA_SPI_Configuration(void)
DMA_InitType DMA_InitStructure;
RCC_EnableAHBPeriphClk(SPI_MASTER_DMA_CLK, ENABLE);
/* SPI_MASTER_TX_DMA_CHANNEL configuration */
DMA_DeInit(SPI_MASTER_TX_DMA_CHANNEL);
DMA_InitStructure.PeriphAddr = (uint32_t)&SPI_MASTER->DAT;
DMA_InitStructure.MemAddr = (uint32_t)SPI_Master_Tx_Buffer;
DMA_InitStructure.Direction = DMA_DIR_PERIPH_DST;
DMA_InitStructure.BufSize = BUFFER_SIZE;
DMA_InitStructure.PeriphInc = DMA_PERIPH_INC_DISABLE;
DMA_InitStructure.DMA_MemoryInc= DMA_MEM_INC_ENABLE;
DMA_InitStructure.PeriphDataSize = DMA_PERIPH_DATA_SIZE_BYTE;
DMA_InitStructure.MemDataSize = DMA_MemoryDataSize_Byte;
DMA_InitStructure.CircularMode = DMA_MODE_NORMAL;
DMA_InitStructure.Priority = DMA_PRIORITY_HIGH;
DMA_InitStructure.Mem2Mem = DMA_M2M_DISABLE;
DMA_Init(SPI_MASTER_TX_DMA_CHANNEL, &DMA_InitStructure);
DMA_RequestRemap(SPI_MASTER_TX_DMA_REMAP, DMA, SPI_MASTER_TX_DMA_CHANNEL, ENABLE);
SPI配置:
void SPI_Configuration(void)
SPI_InitType SPI_InitStructure;
RCC_EnableAPB2PeriphClk(SPI_MASTER_CLK, ENABLE);
SPI_I2S_DeInit(SPI_MASTER);
/* SPI_MASTER configuration
SPI_InitStructure.DataDirection = SPI_DIR_DOUBLELINE_FULLDUPLEX;
SPI_InitStructure.SpiMode = SPI_MODE_MASTER;
SPI_InitStructure.DataLen = SPI_DATA_SIZE_8BITS;
SPI_InitStructure.CLKPOL = SPI_CLKPOL_HIGH;
SPI_InitStructure.CLKPHA = SPI_CLKPHA_SECOND_EDGE;
SPI_InitStructure.NSS = SPI_NSS_SOFT;
SPI_InitStructure.BaudRatePres= SPI_BR_PRESCALER_32;
SPI_InitStructure.FirstBit = SPI_FB_MSB;
SPI_InitStructure.CRCPoly = CRC_POLYNOMIAL;
SPI_Init(SPI_MASTER, &SPI_InitStructure);
/* Enable SPI_MASTER */
SPI_Enable(SPI_MASTER, ENABLE);
}封装SPI_DMA写函数:
void SPI_Write_DMA(SPI_Module* SPIx, uint8_t* writePtr, uint16_t len)
uint32_t timeOut = 0x1000;
while ((SPI_I2S_GetStatus(SPIx, SPI_I2S_BUSY_FLAG) != RESET) && (timeOut--)) __NOP();// Wait BUSY
// SPI_I2S_ReceiveData(SPIx);// CLear RNE
SPI_I2S_EnableDma(SPIx, SPI_I2S_DMA_TX, DISABLE);// Disable DMA request
DMA_EnableChannel(SPI_MASTER_TX_DMA_CHANNEL, DISABLE); // Disable DMA
SPI_MASTER_TX_DMA_CHANNEL->MADDR = (uint32_t)writePtr;
SPI_MASTER_TX_DMA_CHANNEL->TXNUM = len;
DMA_EnableChannel(SPI_MASTER_TX_DMA_CHANNEL, ENABLE);// Enable DMA
SPI_I2S_EnableDma(SPIx, SPI_I2S_DMA_TX, ENABLE);// DMA Start Work
主函数测试:
int main(void)
log_init();
log_info("\n this is a SPI master DMA Demo.\n");
GPIO_Configuration();
DMA_SPI_Configuration();
log_info("\n DMA Transfer start.\n");
for (int i = 0; i < 3; i++) {
SPI_Write_DMA(SPI_MASTER, SPI_Master_Tx_Buffer, BUFFER_SIZE);
while (!DMA_GetFlagStatus(SPI_MASTER_TX_DMA_FLAG, SPI_MASTER_DMA)) __NOP();
log_info("\n DMA Transfer end.\n");
while (1) {
}测试结果:
页:
[1]
