Cindy@wallys 发表于 2023-2-22 10:50
Wallys|QCN9074/QCN6024/ 5G 802.11ax|Does QCN9074-5G module support W56?
In this article,we’ll introduce about the W56 at 802.11ax 5GHz.If you realized this article is helpful, kindly help re-post / comment blow/click like for help more reader to learn about W56)
There are 2 bandwidth for WIFI to use:2.4GHz and 5GHz.Strictly,there is another high speed 60GHz bandwidth,the usage for 60GHz bandwidth is quite limited and the price is more expensive,so the chance for use is not as wide as 2.4GHz and 5GHz.
Compare to 2.4GHz,the 5GHz bandwidth can achieve high speed,stable wireless communication,and suitable for video distribution services and so on.
IEEE802.11a/n/ac: 5 GHz (U.S. and Canada)
Different from the other channels,W56 can only used for outdoor,but W56 bandwidth may effected by marine and aviation radar.So it may could not be used in coastal areas and highlands because radio waves interfere,but it feature with less susceptible to interference outdoor compare to W53.
DR9074-5G
https://www.wallystech.com/Network_Card/DR9074-5G-PN02.1-Wifi-6-Qualcomm-QCN9074-Single-Band-5-GHz-4T4R-M.2-E-Key-Interface-802.11ax.html
​Features
■ Qualcomm Atheros http://www.wallystech.com/]QCN9074
■ 5GHz, max 23dBm per chain, up to 4949Mbps
■ Single Band 5GHz 4x4 http://www.wallystech.com/]WiFi 6 (802.11ax)
■ 4 spatial streams (4SS)
■ M.2 E Key Interface
■ PCI Express 3.0 Interface
■ Supports Dynamic Frequency Selection (DFS)
For more products pleasecontactme:sales2@wallystech.com
页: [1]
查看完整版本: Wallys|QCN9074/QCN6024/ 5G 802.11ax|Does QCN9074-5G module support W56?
