灵动微 MM32F103CxT6硬件IIC
static void Config_I2cDevice ( uint32_t ulSpeed ){
GPIO_InitTypeDef xGPIO_InitStruct;
I2C_InitTypeDef xI2C_InitStruct;
/* Enable clock. */
RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOB, ENABLE );
RCC_APB1PeriphClockCmd( RCC_APB1Periph_I2C1, ENABLE );
/* Configure scl & sda GPIO parameters. */
xGPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF_OD;
xGPIO_InitStruct.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7;
xGPIO_InitStruct.GPIO_Speed = GPIO_Speed_10MHz;
GPIO_Init( GPIOB, &xGPIO_InitStruct );
/* Configure I2C parameters. */
xI2C_InitStruct.I2C_ClockSpeed = ulSpeed;
xI2C_InitStruct.I2C_Mode = I2C_Mode_MASTER;
xI2C_InitStruct.I2C_OwnAddress = 0x0;
if ( ulSpeed <= 100000 ) { /* Configure speed in standard mode */
xI2C_InitStruct.I2C_Speed = I2C_Speed_STANDARD;
} else { /* Configure speed in fast mode */
xI2C_InitStruct.I2C_Speed = I2C_Speed_FAST;
I2C_Init( I2C1, &xI2C_InitStruct );
/* Enable i2c1 port. */
I2C_Cmd( I2C1, ENABLE );
I2C 硬件驱动
(a)、 根据官方提供源码修改,并且将其封装在 HAL_i2c 库文件内;
(b)、 该OLED 仅需要 写操作;
(c)、 在发送 STOP 停止信号前需延时 5us 才能正常显示(后续再找原因)。
复制
* @briefWrites buffer of data to the I2C EEPROM.
* @parampxIO :typedef struct { GPIO_TypeDef* xPort; uint16_t usScl; uint16_t usSda; }I2C_GPIO_t;
* @parampBuffer : pointer to the buffercontaining the data to be written
* to the EEPROM.
* @paramWriteAddr : EEPROM's internal address to write to.
* @paramNumByteToWrite : number of bytes to write to the EEPROM.
* @retval None
ErrorStatus I2C_WriteBuffer( const I2C_GPIO_t* pxIO, I2C_TypeDef* I2Cx, uint8_t DeviceAddr, uint8_t WriteAddr, uint16_t NumByteToWrite, uint8_t* pBuffer)
uint32_t I2C_Timeout;
uint16_t write_Num;
xGPIO_InitStruct.GPIO_Pin= pxIO->usScl | pxIO->usSda;
xGPIO_InitStruct.GPIO_Mode = GPIO_Mode_IPU;
GPIO_Init( pxIO->xPort, &xGPIO_InitStruct );
I2C_Cmd(I2Cx, DISABLE);
I2C_Send7bitAddress( I2Cx, DeviceAddr, I2C_Direction_Transmitter );
I2C_Cmd(I2Cx, ENABLE);
I2C_SendData( I2Cx, WriteAddr );
I2C_Timeout = 0x1000;
while ( ( I2C_GetFlagStatus( I2Cx, I2C_STATUS_FLAG_TFE ) ) == RESET ) {
if ( ( I2C_Timeout-- ) == 0 ) {
return ERROR;
for ( write_Num=0; write_Num<NumByteToWrite; write_Num++ ) {
return ERROR;
I2C_SendData( I2Cx, *( pBuffer + write_Num ) );
/* 96MHz 工作频率下,延时5us. */
for ( uint16_t i=480; i>0; i-- );
I2C_GenerateSTOP( I2Cx, ENABLE );
while ( ( I2C_GetITStatus( I2Cx, I2C_IT_STOP_DET ) ) == RESET ) {
return ERROR;
/* If all operations OK, return sEE_OK (0) */
return SUCCESS;
使用硬件iic读取sht20怎么清除所有标志位 硬件I2C稳定吗 硬件I2C稳定吗 硬件II2C和软件I2C有什么区别 硬件iic应答失败如何自动恢复 如何直接利用MM32F103CxT6的硬件I2C操控 硬件I2C 到底是不是个坑 IIC从机地址为什么右移一位? 硬件I2C中断方式和查询方式有什么区别 模拟IIc总线如何设置总线传输速率 硬件IIC需要外围上拉电阻吗 模拟I2C的最大速率是多少 硬件IIC需要外围上拉电阻吗 硬件I2C中断方式和查询方式有什么区别 IIC从机地址为什么右移一位? 硬件IIC怎么接收不同字节的长度的数据 硬件I2C 到底是不是个坑 I2c总线一般拿来实现什么功能? I2C总线的地址是如何确定的?
页:
[1]
